  3. Parts For Sale
  4. Shop flooring stupid cheap
16 Posts 5 Posters 152 Views 2 Watching
    You'd most likely have to use something under a jack/stand to protect the point loads from cracking the floor, i.e. piece of plywood or sheet metal.
    Would pulling into a garage and backing in and out turning the wheels on these cause them to shift or move at all? One of our garage stalls will eventually be a little tricky to get into and would require some maneuvering.
      josepilove said:
      Where are these located?
      Cottage Grove, Wisconsin
      gilber33 said:
      The pictures aren't working for me. Are they for anyone else?
      Also, are these just for parking cars on? I assume with them being plastic you couldn't use a jack or jackstands on these?
      You can use jack stands, floor jacks, etc. they are strong.
      @Jdesign I'm still in. I have to do some maths to see what I need and how big of a pile that will be for me to pickup, but around 500 tiles.
      FYI for everyone, I talked to the rep for Wisconsin (Chase) from the company that makes these and they will sell small amounts of the ramp edges to anyone. They are $2/piece and are 2"x 9.8425" available in grey or black.
      I will save you some! Can you send me Chases info? I would love to get some ramp edges.
      Yes and no. typically these should have an underlayment, but I have then down with just concrete under them. you can turn on them just fine but obviously the bigger the area the less likely you will see shifting.
      ** Note that my E36 has a welded diff and I tried turning on them with the rear tires near an edge of about 1200sqft and it just twisted a few tiles apart. I had to get out and snap them back together.**
        Let me know if this helps:
        https://www.facebook.com/marketplace/item/410129909663903/?ref=messenger_banner
        https://madison.craigslist.org/for/d/cottage-grove-garage-shop-gym-suspended/7014065612.html
          @gilber33
          you could always mechanically fasten trouble spots or tiles near edges. if you don't mind a hole or two in your floor, a modified truss head screw and a wedge anchor could work.
            just call the 800 number and ask for the Wisconsin sales rep named Chase. That's how he suggested I call him back.  800-664-3865
              UPDATE.
              This is going faster than I expected. I sold about 3,000 SqFt already. That means I 'only' have about 15,000 SqFt left.
              GET IT WHILE IT'S HOT!
                doing my maths...are these a 10" nominal tile?
                  For the most part, yes.
                  9.8425" x 9.8425" x 3/4" (250mm x 250mm x 19mm)
                  They are metric.
                  But I can give you a bunch extra, just get the rough area.
                    *  *  U P D A T E  *  *
                    I have roughly about 10,000 square feet of suspended modular flooring LEFT.
                    I am selling them at
                    •••$0.75 a tile•••  OR LESS
                    •••$0.25 a tile•••  OR LESS
                    •••$0.20 a tile•••  OR LESS
                    Come get yours today before I run out 😄
                      SO..... I am finally down to about 2000 sqft.
                      If you have held off this far, now is your last chance to com get some for CHEAPPPPPP.
