  4. 540i Swapped Rat rod Build thread
91 Posts 14 Posters 0 Views 1 Watching
  • ThatRatRodProjectT
    ThatRatRodProjectT
    ThatRatRodProject
    What management are you planning on using? Wiring always sucks.
    Stock Ecu and custom fuse box. Currently making one right now
      ThatRatRodProjectT
      ThatRatRodProject
      Great progress and success today with my custom wiring box. I have an official standalone engine management system for my M60b40.
      After reading a lot of wire diagrams and taking a step out of my comfort zone. it all worked out in the end. This is the first time I've done any really serious wiring on a car.
      --Ill let the pictures do the talking
      Before
      8674510300d995c4361027a8446aabc0.jpga0fa43dfc84129cc22d7df55cc7bcc2a.jpgcce19b723cccc2b56905aa19b5585e49.jpg
      After
      9911e0693ce0150c15d46656e9bb3f55.jpgc315b8fd0406b786f763eb9a81db6eaa.jpgbc72aac7b686c6adf7ae172e8406031b.jpg
        ThatRatRodProjectT
        ThatRatRodProject
        Another update. I recently order a lot of supplies to get my project. This is going to be a picture update. And I designed up some clutch and brake pedals. c67fd5b5870139c3bfda1c960924c0a5.jpg324ba597ca69eab1111a039e873172d1.jpge61d27c4399f27cb14e8472bce291862.jpg06666f46129316f0754f44d23889ff4f.jpg0f173864db59624d22b7d4fb895d4198.jpg76816f66bad226793882ac73a01186f1.jpga1a91aa034aa1542decd8aa4bc6b3c96.jpgd0b0a4002b60390f0bf90012cf20a27c.jpg5dc0d83118bcc6785e0b7bf3b9b2514b.jpg
        Not ordered yet but soon will be the tires
        I am looking for a 3.73 or 4.11 medium case diff.
          Awesome parts order! All top quality stuff!
            Break that bank!! Glad to see the parts pile growing!!
              Lame updates. Get back to work!
                ThatRatRodProjectT
                ThatRatRodProject
                So it’s been some time but this project is not dead. Updates will be coming. Re-designed front frame section sneak peak.
                  Nice work! Solidworks?
                  I have so many questions.(Sorry) Is there a reason you are going with a cantilever set up? How did you calculate the the pivot arm length? Are there any shear concerns with the shock mounted on the top of the tube like that without any linear support? You obviously peaked my interest. I like what I see and I am very glad this isn't a dead thread.
                    very cool!
                    seconded. it appears there is room for the coilover where you've placed that yellow connecting rod. are you using an undersized spring/shock and but increasing its effectiveness with the pivot arm?
                    what is the connecting rod coming forward from the pivot arm?
                      Sway bar link maybe?
                      Looks great! I'm glad this project is still happening
                        ThatRatRodProjectT
                        ThatRatRodProject
                        Yes Sway Bar Link Set up will be coming off the cantilever toward the front of the frame.
                        Linked Will Be the Sway Bar I'm Using. Haven't Modeled It in yet.
                        https://www.summitracing.com/parts/rhc-19-0001
                          ThatRatRodProjectT
                          ThatRatRodProject
                          very cool!
                          There is a couple reasons why i have the coil-over mounted horizontally .
                          1. Keep it Clear of road Hazards like Dirt, rocks, Ect.
                          2. I am using a under rated spring. So with the Cantilever allows me to achieve my desired spring rate with some sacrifice of overall suspension Travel.  Because i honestly don't know what the project will weigh in at.  I may have to re-fabricate the Cantilever Section. But This may be to stiff.
                            Yeah this project was always intriguing, but has certainly caught more of my interest seeing things being modeled!
                            The shear area on that upper shock mount seems reasonable if you've got good penetration welds on both plates.
                            I think I saw the knuckles in a picture on a previous page, but are those a standard purchased component?
                            I've always thought it would be cool to do a ground up build like this, so I really look forward to the continuation of this!
                              ThatRatRodProjectT
                              ThatRatRodProject
                              Yes the Cad software i use is Solid-works.
                              There is a couple reasons why I'm using a cantilever.
                              1. I have the coil-over mounted horizontally To Keep it Clear of road Hazards like Dirt, rocks, Ect.
                              Attached is a image of a section View of the Cantilever.
                              The stack up is From the top Down.
                              Stripper Bolt (Shear Strength of  82,000 Psi (Roughly 28,000 Pounds or shear force))
                              Harden Washer
                              Thrust Bearing
                              Harden Washer
                              Normal Ball Bearing
                              Mounting piece (Gets Welded into the Cantilever)
                              Normal Ball Bearing
                              Harden Washer
                              Thrust Bearing
                              Harden Washer
                              Mounting Blacking (will get mounted to the end of the tubing, (Tubing will likely be gusseted in the future)
                              • Quote
                              • Edit
                                ThatRatRodProjectT
                                ThatRatRodProject
                                The Knuckle is a ford Pinto Spindle. Primarily Used in circle track applications.
                                  ThatRatRodProjectT
                                  ThatRatRodProject
                                  Quick update. with some actual fab work being done.
                                  The past couple weeks I have been putting in some hours gettin some of the front frame done. I’m gonna attach some photos if you have any questions let me know. I’ll try to explain.
                                  68146F60-B7C9-405D-9388-5EEEE2580392.MP4
                                  3313FB85-223C-4B49-A9BD-F9EC8D2293C1.MOV 65AD28E0-186E-4B34-8577-045E1CC9E60F.MP4 9070B11F-FE72-4710-8BD4-5062AADA8845.MP4 BC8E10B8-81C0-4EF0-8CC0-98251DCCA8DB.MP4
                                    ThatRatRodProjectT
                                    ThatRatRodProject
                                    87C94C13-2CBA-459A-B93C-C9D60E18578E.MOV
                                    • 87C94C13-2CBA-459A-B93C-C9D60E18578E.MOV
                                    • RobZRR
                                      RobZRR
                                      RobZR
                                      ThatRatRodProject said:
                                      I would not recommend using a stripper bolt in this manner. They are not intended to handle lateral forces and have a inherent stress riser at the base of the thread that is prone to failure.
                                      Ideally you would support both sides of the pivot point from the subframe.  if you must support it from one side a spool and bolt design will bend before failure, since it keeps the bolt in tension.
                                        ThatRatRodProjectT
                                        ThatRatRodProject
                                        I 100% agree with you. If you are using a Harden alloy shoulder bolt. But with that being said I will be mostly turning up a custom shoulder bolt . But any side load should be transferred to linear load with the thrust bearings. Not 100% transferred but lessened a great deal. I’m not saying you wrong in anyway and I will take any input I can.
                                          CAD to Metal overnight. I like your fast pace.
                                          What did you use to cut the parts? Waterjet?
