Partiallypurplevisuallyviolet - Daytona M3 Build Thread
Love all the details! That steering wheel is really cool.
Thanks man! Super happy with it and lucky to find such a clean example
Love it! If I were ever to do up an E36, I'd be something like this (but with an N54 instead of a 1JZ
)You right
Yeah those seats are proper. I bet this thing will hoon pretty well. The welds on the half cage look decent too, hopefully it won't kill you in the event of a crash.
i love purple. excited for the project!
I had the cage made by Structure Fab and Design in West Allis and they did an amazing job. I would highly recommend them to anyone who needs any metal work done
Smelt clutch driving the car around yesterday. Hit boost a few times, and nothing felt out of the ordinary. Clutch release point was perfect as always, so I was confused.
Ended up losing the pedal randomly going about 10 mph when I tried to shift to second. Pedal stick to the floor and I have to pull it back up. No pressure. Can’t put car in gear with the car running.
Opened bleed screw on the slave and pressed pedal and fluid shot out. (Master seems fine, still connected to pedal, no leaks)
Took slave off and checked the pressure on the rod. Rod is super hard to push in, nothing like my other bad slave in my 323 from last winter. Clamped it shut and tried pressing the pedal and the pedal was rock solid. No leaks on the slave. (Assuming slave is not a problem)
Tried pushing fork in with screwdriver and it still has pressure but is sitting high up out of place.
I’m assuming the clutch pivot pin is completely worn out of failed in someway. Going to take tranny out next weekend. Still confused on why I got the clutch smell, and I find it weird for my clutch to feel fantastic and then to lose my pedal randomly.
In good news my new part should be here this week and you have to lower the tranny for it so I can knock two stones out in one day. Hope it’s just the pivot pin, ordering a stainless one today from bimmerworld.
This ones only 50% bmw and I still have to have to have the tow truck on speed dial
Well this thing is beautiful.... Cannot wait to money shift and blow my motor. Jk, super excited. Quality is amazing, I’ve been wanting one of these for a very long time.
I’m really trying to not cut any corners in this interior. The cockpit of the car is where you spend all of your time, and it’s very important that it’s done right. It’s all about the driving experience! I feel that so many people overlook the interior of a car and only focus on the exterior. I want to love driving my car as much as I love looking at it
fuuuuuuuuuuu
After feeling a self centering shifter, I need one.
So went to remove trans yesterday. Had a hell of a time with the 1JZ starter. Was not fun to reach. Got it off and the problem was just what I expected. A worn pivot pin. After spending all day in the rain removing the trans and putting it back in I was nearing completion.. installing the slave ready to be done. Pressed the clutch and the slave blew it’s been piston and rod into the trans. Had to take it off and put it back on again. Hopefully today the slave will decide to line up properly
