Non-BMW Stuff on a BMW Forum
    The color match is very good. The aerosol cans were okay. They didn’t cover very good and weren’t great on the horizontal surfaces. It’s good for and I think I learned some good things with prep and spraying. But I’m excited to do this again with an hvlp gun.
    Letting dry and then I’ll mask it back off and do clear coat.
      After dinner with the family I took a quick drive down to Roselle, IL where there was a guy parting out an 89 325ix. Ended up being a BMW hobby shop that had probably 6-7 e30s and a handful of other models in various stages of repair and parked.
      I picked up a straight hood, straight trunk lid with a spoiler, and the full AC system under the hood. Both the trunk lid and hood need some cleaning up, but all in all, for $250 I think I did okay.
        Paint looks good from here 👍🏼 excited to see it with the clear on. Good deal on the parts too.
          Thank you. Tonight it gets clear coat.
          I also dug into the AC parts some more and having everything in front of me definitely helped understand how it's all routed. From the looks of it I will need to replace the suction hose, the condenser, and will get a new dryer.
          Does anyone know the quality of the hoses by "4 Seasons"? They carry the suction hose for SIGNIFICANTLY cheaper than the OEM hose and seem to be the only aftermarket manufacturer of the hoses.
            Well, the bumper turned out great, the trunk lid not so much. I think two things happened - the aerosol cans did not cover very well when using them on a horizontal surface and I think I was making my passes too quickly so the clear didn’t cover as well as it should have. I’ll wetsand and polish it, but since the other trunk lid will be going on, I’m taking this as a learning experience and leaving it at that.
              Did you wetsand the base coat before laying the clear?
                Its too large of a surface to get an even "wetcoat" using a small aerosol can. You might be able to polish it out, but it will be much less work to just shoot it with a gun.
                  Everything I read said to not touch the base coat before clear as it will mess it up. That if you were to wetsand the base coat then you need to shoot another coat of base over that.
                  I’ll polish and it will look fine for now. I’m looking forward to doing it with a gun. The more I read into it the more I see people with little experience achieving great results.
                  Gives me hope. Haha
                    Gives me hope. Haha
                    Correct, sanding the base coat if it has metal flake will mess it up.
                    Yes it seems that you were not able to maintain the wet edge which allows the clear coat to flow over the surface evenly and smooth out.
                    Watch some videos on youtube with the guy from Eastwood, I found them very helpful to watch before I painted.  It helped me know what to look for and what to do about it so I wasn't stuck with a problem after the gun was full of paint.
                      I’ll watch some more videos. Part of my problem was the aerosol cans. They just didn’t seem to do well on the flat surface. Once I get an hvlp setup, I’ll do some more practicing and watch some more videos. The bumper turned out great though.
                        Anyone familiar with Coleman Powermate brand air compressors? I found one while casually perusing Marketplace that is 7.7scfm at 40psi for $100. Eastwood sells a gun that operates at 4.25scfm at 30psi.
                        It sounds like these two would pair together really well.
                        I don't need a larger air compressor for a while, but this seems like a good deal that could save me some money in the long run.
                          Gives me hope. Haha
                          Its super easy, you could buy a cheap harbor freight gun and compressor and get great results.
                          That "should be" efficient to get a small job like a trunk done, but it will be running the entire time. If you are looking for a used unit you can get much larger ones for the same price if you have the room.
                            The only issues is most large compressors that I have seen require 240 - which I do not have. The compressor I found on Marketplace is a 21 gallon compressor which is in the same size arena I'd be buying new - but this one pumps out a lot more air than the new ones I've put on my list.
                            I'm just not familiar with that brand of compressor.
                            It's been fun reading about how the compressor and gun work together and what to look for. There's way more to it than I thought, but from what I gathered the HF gun uses 6scfm @ 40psi. The Eastwood gun that's 4.25scfm @ 30psi would use less air and work better with the 20-30gallon tanks that are in my <$300 price range.
                            Unless I get a compressor with a 60 gallon tank, the compressor is going to be running off and on quite a bit - but if I can get a used compressor to justify spending a little more on a gun that's more efficient, I'm OK with that. Regardless, I'll be spraying the car in sections to minimize the continuous run time of the compressor. Because ANOTHER thing I read is the more it runs, the hotter it gets, the more condensation there is, and the more water you get in your lines (I'll still have in-line water separators).
                            ***Sorry I beat topics to death, but I like talking about it and learning new things and how it all works together. And painting cars is new to me, so it's fun***
                              Painting metallic panels one at a time is not always the best. There are a bunch of variables to take into account that can cause uniformity issues.
                              For example;
                              Humidity and temp percentages can vary unless you have a controlled booth. This can cause differences in the curing and the overall density of the paint, thus a lighter or darker tone.
                              The angle in which your spray pattern occurs naturally. Let's say you spray a fender and a door on the same side of the car at the same time. If you paint the fender hanging from the ceiling upside down but the door right side up, the metallic will "lay" in a different direction causing the two to appear as slightly different colors/tones when the light hits them and they are right next to each other.
                              FYI I am not a painter by any means, so take this info with a grain of salt 😄.
                                That all makes sense. I’m working with what I got within my parameters - and that includes a sub $300 compressor and making the best of it. I think if I’m careful and take my time and I’m consistent with what I do, my results will be halfway decent.  The car is no clear coat on most of it now, so it won’t take much for it to be better than what it is now.
                                  As long as you get a compressor that is not "oil free" you should be ok running it pretty hard.  Steer clear of the oil free ones, they are pretty flimsy and not intended for running long duty cycles.  I can show you how to make an extremely effective air dryer for really cheap so although the air in the compressor will be very wet you will have excellent dry air at the gun.  Keep an eye out for a second tank, mine came from an old compressor that had failed, I think it is a 30gal upright with wheels so I can fill it and move it around for topping off tires etc but there are also small ones around 5 or 10 gallon portable ones also that would work well.  I go from the compressor to the dryer, then to a second "dry" tank, then to a regulator to drop the pressure for the HVLP.
                                    I cannot find any non oil-free ones within what I want to spend. Those seem to be in the more expensive range of compressors.  I’ll keep looking  though.
                                      You should look into a used one.  I bought mine used for 60$ I think.
                                      Here are a couple in my area, just watch craigslist.  You can get a lot more for your money.  Then you will have some money left for a filter/regulator setup.  An oil free compressor will not last long under hard usage like painting.
                                      https://wausau.craigslist.org/for/d/stevens-point-air-compressor/6972619791.html
                                      https://wausau.craigslist.org/tls/d/port-edwards-roll-air-compressor/6949521027.html
                                      Why can you not do a 240V unit?  You can buy used ones for cheap and they are so much more powerful.  If you need advice about wiring it I am a master electrician, it's not hard at all.
                                        Because my garage is wired for 120v and it’s detached from the house.
                                        There’s this one locally to me:
                                        https://milwaukee.craigslist.org/tls/d/waukesha-speedaire-air-compressor/6966869481.html
                                        I assume that 4.9 scfm @ 100psi would mean that it’s well above 6 scfm @ 40psi
                                          Perfect time to bury a feeder for 40-60 amps and have MORE POWAAAAAAAA!  ;)
                                          That looks alright, maybe on the high side of price for a used compressor.
                                          Check this one out.  My small one is a Puma and it has been working great for many years.  This one is belt drive which means it will be quieter than the direct drive units.
                                          https://milwaukee.craigslist.org/tls/d/germantown-puma-air-compressor/6963043391.html
                                          Here is a listing for a new one 450$.  It says 3.8 @ 40 and 3 @ 90.  It seems like it would pump more than that but with additional storage it would work well.  I think Napa also sells Puma compressors.
                                          https://www.aircompressorsdirect.com/Puma-PK2011VP-Air-Compressor/p11112.html
