Non-BMW Stuff on a BMW Forum
1.2k Posts 29 Posters 20.3k Views 2 Watching
    Check out "wedo bmw etm" to find the right electrical manual for your exact month/year.  The wire colors will be spot on and it will have pinouts for every plug.  If you need help interpreting the schematics let me know.
      Thank you! I will look into that. I’ve been able to deduce what each connector is, but I think there’s one more that is supposed to be in that area that I didn’t see last night.
        It should be easyish to figure out because all of the A/C stuff will be in one spot.
          My fear is more that  when it was removed, wires were cut rather than unplugged. Like the aux fan connector was cut instead of unplugged.
            Right, you will be able to tell by the wire colors what they are/were for even when the plug is gone.  And you can find what plugs/connectors you need.  I might have some spare plugs depending what you need.  The wire colors in the ETM are usually very accurately documented and reliable unlike wiring schematics in books like chiltons, and even the Bentley is not always right.  BMW ETMs usually cover a specific model year like 08/89 to 07/90 so look for the right month/year.
              These wire colors should be checked on your car and in the ETM.  The ETM actually has some of its own helpful diagnostic information for the AC system.
              compressor - 3 prong round  (Red/Black, ?, ?)
              drier - (the one with the rubber boot)
              radiator temp switch - 3 prong round (Black/Brown, Black/Green, Black)
              aux fan  - 3 prong (you are missing the plug?) (Black/Green, Black/Blue, Brown)
              you might as well use a better aftermarket fan instead of the factory aux fan in which case you'd use your own plug/wiring anyways.
                I found the plug. Whoever removed the fan just cut its harness instead if unplugging it.
                But it appears I have everything I need to install the AC system. Now to find it all. Haha
                  After my welder went out and I was able to meet my dad so I could borrow his, I finally was able to patch the other rust hole in the rear bumper. You can kind of see it here:
                  I cut it out and welded in some new metal and the primed it for now. It’s not the prettiest, but I did it myself with my own tools, and that was what I really wanted to accomplish
                  I need to get some type of seam sealer to go around the patch and then I need to bring the area back up to the thickness of the existing bumper. My guess is a truck bed liner will give me the depth and texture of the bumper coating.
                    Look around for bed liners. Some have a much finer pattern than the one you are looking for. I'm sure there are ways to manipulate that tho.
                    Or as long as the surface is even and matches the lines of the valence, no ones gonna know as its black and so low on the car.
                      I want it to blend in, but doesn’t need to be perfect. I also plan to spray the valance when I spray the trunk lid and get rid on the lower black portion.
                        Any auto body supply store should have a textured rock chip spray in an aerosol can. that will be your best bet for an even texture. Otherwise basic autoparts bedliner works. you can vary the thickness of the spray pattern depending on how clost you spray to the surface.
                          The color match is very good. The aerosol cans were okay. They didn’t cover very good and weren’t great on the horizontal surfaces. It’s good for and I think I learned some good things with prep and spraying. But I’m excited to do this again with an hvlp gun.
                          Letting dry and then I’ll mask it back off and do clear coat.
                            After dinner with the family I took a quick drive down to Roselle, IL where there was a guy parting out an 89 325ix. Ended up being a BMW hobby shop that had probably 6-7 e30s and a handful of other models in various stages of repair and parked.
                            I picked up a straight hood, straight trunk lid with a spoiler, and the full AC system under the hood. Both the trunk lid and hood need some cleaning up, but all in all, for $250 I think I did okay.
                              Paint looks good from here 👍🏼 excited to see it with the clear on. Good deal on the parts too.
                                Thank you. Tonight it gets clear coat.
                                I also dug into the AC parts some more and having everything in front of me definitely helped understand how it's all routed. From the looks of it I will need to replace the suction hose, the condenser, and will get a new dryer.
                                Does anyone know the quality of the hoses by "4 Seasons"? They carry the suction hose for SIGNIFICANTLY cheaper than the OEM hose and seem to be the only aftermarket manufacturer of the hoses.
                                  Well, the bumper turned out great, the trunk lid not so much. I think two things happened - the aerosol cans did not cover very well when using them on a horizontal surface and I think I was making my passes too quickly so the clear didn’t cover as well as it should have. I’ll wetsand and polish it, but since the other trunk lid will be going on, I’m taking this as a learning experience and leaving it at that.
                                    Did you wetsand the base coat before laying the clear?
                                      Its too large of a surface to get an even "wetcoat" using a small aerosol can. You might be able to polish it out, but it will be much less work to just shoot it with a gun.
                                        Everything I read said to not touch the base coat before clear as it will mess it up. That if you were to wetsand the base coat then you need to shoot another coat of base over that.
                                        I’ll polish and it will look fine for now. I’m looking forward to doing it with a gun. The more I read into it the more I see people with little experience achieving great results.
                                        Gives me hope. Haha
                                          Gives me hope. Haha
                                          Correct, sanding the base coat if it has metal flake will mess it up.
                                          Yes it seems that you were not able to maintain the wet edge which allows the clear coat to flow over the surface evenly and smooth out.
                                          Watch some videos on youtube with the guy from Eastwood, I found them very helpful to watch before I painted.  It helped me know what to look for and what to do about it so I wasn't stuck with a problem after the gun was full of paint.
