Non-BMW Stuff on a BMW Forum
    gilber33 said:
    I should be able to start the car tonight, but I don't want to take it out for its first shakedown to seat the rings when it's dark out. Does anyone see any issues with me starting it tonight and bleeding the cooling system but not taking it out right away?
    Yes,  you could be kidnapped and never know how it drives.
      Started it and bled the cooling system. Sounded great.
      0780933E-7A4B-4254-B6EC-A38FEADBF48D.MOV
      • 0780933E-7A4B-4254-B6EC-A38FEADBF48D.MOV
        Drove it to work for the first time for the third time. 😑
        Also, I’m sure you’re all dying for an update on the playhouse. It’s drywalled, taped, mudded, and painted. Other than staining the floor and interior accessories, it’s pretty much done. Put these adorable solar lights on it.
        And my shed is almost done! Wrapping these up is a huge relief.
          Impressive! Me and wood do not get along.
          Playhouse doesn’t appear to meet required egress codes as the grass could obstruct the door in the event of a fire. Also  Wis. Stat. M20.b25(e)(30) states that “No external structure shall take precedence over completion of any existing E30 builds, and something something about culverts.. or culvers...”
           I’ll give it a B+
            Condor tall knob. Felt it fit the time period of the car better than the ZHP knob. I love it.
            And the shed and playhouse are done (other than putting stuff in it for her to play with). It is such a relief to be done.
              I like the look of those knobs, but they can be kind of pricey.
              I do need to change up my current one though. I tried my Nardi on and it felt so sloppy because the knob is so light.
              I am debating getting one of those IRP short shifter centering shifting deals as @suspenceful's feels like an bolt action shifter. Granted, these can be very pricey. But for how much you use it, I feel it's worth the price.
                $114 for a shift knob is more than I wanted to pay, but I was willing to pay a little more something that worked well and that fit the era of the car.
                I would say the extra height gives it a little more “slop”, but I haven’t had an issue with missing a gear.
                  Your knob looks great
                    That’s the nicest thing anyone has ever said about my knob. Thank you.
                      An e30 in a sea of minivans and SUVs. Took the girls to Bookworm Garden in Sheboygan. Excellent day for a drive in the bimmer. And both kids fell asleep in it on the way home - which I always consider an accomplishment.
                        I know it always fees like an accomplishment when I have my kids in the BMW and am running errands. Makes the car’s existence feel more legitimate and justifiable
                          I totally agree. I wanted this to be my fun car, but I also did things in a way that we could use it for day trips and everyone would still be comfortable. It’s a really good feeling when my family is in it.
                          Ive also been dailying it for the past week while I give the wagon a tune up and repair the AWD. It’s been very pleasant.
                            Got a box of stuff for the next little project for the e30. I’m going to attempt to spray the trunk lid and bumper. If it turns out okay I will probably gradually work my way down the car panel by panel.
                            Non bmw but I replaced the module and pump that operates the awd on my XC70. Gave me a renewed appreciation for older cars. It was an expensive repair.
                              Im sure it’ll turn out ok on each panel. The color match/blending might be the issue.
                              I’ve seen your playhouse skills so I have full confidence in you
                                If I go beyond the trunk lid I would only paint sections where there is a seam so I’m not blending anything. Even if the color is slightly off between say a door and a fender, it will still look better than the paint that’s on it now.
                                  Looks the same as the P2R Haldex unit.  Worst design ever!  Why would it be designed so that you have to remove the driveshaft and input flange to get the 1/4" of clearance to remove the pump????  And why is the filter in such a difficult spot???  Also no drain plug for Haldex or the rear differential.  I added 1/8" NPT drain plugs to both on mine when I had it.  There is no way to properly remove all of the fluid with the suction method.  Oh and the price for parts is insane.  A new pump is over 300$ for that tiny little thing.  Luckily mine failed open, probably due to the brushes being worn out but if it shorts then it will ruin the DEM and then you are out 400$ for that too.  And the special fluid is 30$ / liter.  I don't miss that car.  ;)
                                  As for the painting, see how it goes with the spray cans but I am a novice and had good results painting some parts on my van after a deer accident with an old HVLP gun.  The spray cans will be very expensive to do a large area with.  Mine turned out good and it was Toyota Beige with metal flake which made it trickier than just a regular color.  The metal flake takes practice to lay down evenly but even that I figured out pretty quick how to make it look right.  I tested on a piece of cardboard to get the gun set up.  That looks like the 2k clear coat in a can.  Huge sticky mess on everything.  Make sure to protect everything, the over spray goes everywhere.  It is different than paint over spray, somehow it coats everything in the room.
                                    Kind of like @jc43089 said, cans are expensive for areas larger than a trunk or smaller panel. If you want to not spend a lot, the Harbor Freight guns are good for one day of use. I.e. don't clean them and use them again. If you want some more confidence in the gun, you can get something decent for not a ton of money and will get a lot more even coating of paint with a proper gun over an aerosol.
                                    Painting sucks, painting cars is worse.
                                      They are the same. Since I replaced the pump all of the fluid was able to drain out, but the yes, the pump was $300 and the rebuilt DEM was $700. I have no knowledge of being able to purchase a DEM for $400 - since they are coded to your car.
                                      And then you have to take it for a drive, top off the haldex fluid, and then suck out 40ml. 😒 Once I get it cleaned up I will probably list it for sale and look for an 850 wagon.
                                      It's not the 2k clear coat, it's the more basic one. I intend to close my garage door just enough to wedge my box fan under the door and then seal off the gap and run the fan to create negative pressure. I'm hoping most overspray gets sucked out then. I have a cheap HVLP gun, however, I have a relatively small air compressor that I bought primarily to run air nailers and fill up tires, so I don't know how it will work with a gun. But I might get some of their premixed paint to give it a shot.
                                      I like the idea of painting, but it's not my favorite thing to do. The paint is in such bad shape that even if I get it to look OK, I'll be satisfied. But if this turns out fine, I'll also try their premixed paint assuming my air compressor can handle it.
                                        I forgot the coding part, did you get it from Xemodex?  I'm glad I didn't need to deal with that as mine was fine, my pump would run intermittently and it sounded weak when it was running, you can activate the pump with VIDA and watch the pump current draw and the output pressure.  Do you have a VIDA/DICE setup?  It is the most important thing for troubleshooting on a Volvo.
                                        You need a decent air compressor for an HVLP gun but not a huge one.  I think my little one I used for painting is around 2hp, 4.5 CFM at 90PSI.  My compressor has a 4 gallon tank and then after the dryer was another 30 gallon tank.  It was losing ground slowly as I painted but I gave it 30 seconds between parts to catch up and never had a problem.  You need very dry air though, I made an ice powered air dryer that works really well for cheap, let me know if you want details on it.  It worked so well that the dessicant final dryer never even had any color change.
                                        I made a "booth" with tyvek wrap and had 3 box fans exhausting under the garage door and everything inside the booth had clear coat on it.
                                          i also made a 'negative pressure paint booth' with a box fan inside a small room. it does not keep the paint off of surfaces as well as you think it might. it does help keep the cloud of paint from being super obnoxious and helps with exhausting the fumes. you should still be prepared to cover things you don't want to get speckled.
                                          i also deployed that 2k clear for painting a bicycle frame once. the extra nastiness of the paint wasnt worth the hassle for the finish it created. i wouldnt use it again. YMMV
