  4. My 1997 M3 (That I'm not going to part out anymore)
119 Posts 21 Posters 0 Views 1 Watching
    ChrisO said:
    Last year I saw someone at Culvers off Brackett Ave with a WIBIMMERS T-shirt on that wasn't @Rekpoint 🤔
    I live off water street
    O rly, I’m not too far away!
    • ChrisOC
      ChrisOC
      ChrisO
      (˵ ͡☉ ͜ʖ ͡☉˵)ᓄ✂
          Hey when was the last time you were at C&C? o wait... 😛 to be fair the same people show up every-time essentially. Besides you... 😁
            Accurate.
              You live off of Water within walking distance of Mogies and Dooleys and you went to Mondovi for food?  Come on!  If you're going to travel I'd go to Norske Nook in Osseo.  53 is a nice little drive from Eau Claire.
                 Mogies and Dooleys and you went to Mondovi to Norske Nook in Osseo.
                Image result for steve carell gibberish gif
                  I'm so stoked you did that for me Jason ^
                  I read it and felt the same way.
                    Up nort things
                      ChrisO said:
                      I'm an absolute idiot
                      When are we getting a 10 month update?
                      • ChrisOC
                        ChrisOC
                        ChrisO
                        Heres my year and a half update lmao
                        This past summer I basically did nothing to the car, my Passat sat dead in the street and I just daily drove the M3 in near stock form.
                        In early November I got the Passat going and the M3 went into hibernation, I've slowly been doing random things here and there and put in a big order recently
                        My goals for the spring are to have the suspension completely sorted, lose a ton of weight and do some engine upgrades to try and make a little more power, I really want to get into doing some autocross and make a all around nice street car for the weekends that feels a little bit more raw to drive
                        The first thing I did was a deep clean, the interior and engine bay got pretty dirty driving the car every day last summer
                        The LTW seats are going to be washed and extracted soon. For a while I really wanted bucket seats but I decided the best thing to do for the car is to just keep the full factory airbags and restraints in place.
                        Pulled out my broken SAP and got the delete plates
                        The harness for my HK amp was cut when I got the car, and the radio was missing. All of the speakers were replaced with cheap Infinity ones so I just pulled them all out. I dont really ever listen to music when I drive the car, and believe it or not I probably saved about 40lbs between all of the speakers, the amp and the cassette player
                        Factory LTW radio delete panel
                        Next I wanted to pull some more weight, so I moved to the rear of the car to pull out all of the trunk carpet, sound deadening and rear seats. I want to keep this clean, so the factory wires will all be loomed and I'm thinking the rear seat area and trunk will be sprayed and glossed in the factory color by a friend of mine at a body shop in the spring
                        everything forward interior wise I'm keeping, all of the carpet and interior panels
                        I've been looking into light weight batteries so I can shed another 25lbs from the rear
                        I'm going back to plastic headlights because they weigh a lot less then my glass ones, and they also look gross missing all of the inside covers
                        Brand new floormats
                        New flex disc, center support bearing, fuel filter, all the bolts and exhaust hangers etc.
                        For power upgrades I picked up a bimmerworld 3.5" intake elbow and got rid of the asc throttle body.
                        I also picked up a AFE intake used, but unfortunately the head shield weighs like 20lbs, is rusty af and it doesn't fit quite right with the 3.5" maf even with trimming the bimmerworld elbow a ton. The intake is for a 3" setup, but the inside diameter of the pipe is close to 3.5", it bottle necks right before it to probably around 3.25", but I don't think it'll make a noticeable difference? As long as I can prevent heat soak
                        Picked up a M50 manifold kit from bimmerworld, and Gibsons came through with a absolutely perfect M50 manifold for like $10
                        Soon I'll be looking into getting some headers and a tune of some sort
                        I also picked up a UUC clutch stop, poly trans mounts, shifter rebuild parts and the bimmerworld pedal cover set in black (that I forgot to take pictures of installed)
                        I'd couldn't recommend the covers more, they are super grippy, not flashy and improve the pedal feel so much
                        After 2 months, my custom race height RTD V2 shifter and DSSR came in the mail, so I'm really excited with how it's gonna feel
                        Another thing that I had to wait for and got lucky with, a factory BMW motorsport shift knob to go with the RTD shifter.
                         @Rekpoint sold me some kind of GT style low rise wing, probably gonna try and get risers for it
                        Also tracked down a pacific BMW plate frame, from the dealership that my car was sold new at
                        Andddd on Saturday I'll be picking up a first gen Max Velocity Evo splitter from the Plymouth area!
                        Sorry this update is all over and I'm a incompetent writer
                          https://antigravitybatteries.com/
                          Good luck on your hypermiling adventures
                            Nice touch on the license plate frame 👍
                              You sir need a cool momo steering wheel.
                                Nice update, great things are happening!
                                  Looking good!  I like all of the little touches.
                                    Golfball gang!!
                                    • ChrisOC
                                      ChrisOC
                                      ChrisO
                                      Small update
                                      Old shift linkage is out, new dssr and RTD shifter are in! This shifter is absolutely worth the money and it feels great
                                      I also wanted to make sure everything lined up good so I put in the poly trans mounts first. Really pleased that they only took about 5 minutes to put in
                                      Crawling around under a car really takes a lot of energy 🥵
                                       last weekend I picked up the Max Velocity Evo front lip and will be messing around with that tomorrow
                                      • ChrisOC
                                        ChrisOC
                                        ChrisO
                                        The weather has been great the last few days, not ready to hit the roads but I was able to pull the car out and give it a wash
                                        Super happy with how the car looks
                                        Heres a shot of the black Bimmerworld pedals up close
                                        And a closer shot of the shifter set up
                                          Looks great. Did you use the boot trick when installing the RTD? People take the stock rubber boot that seals off the trans tunnel and they turn it upside down and install it with the RTD
