Non-BMW Stuff on a BMW Forum
My clunky drivetrain is getting a little clunkier.
Gonna jack it up and check the mounts and make sure nothing’s loose. If there’s nothing obvious then looks like I’ll be tackling guibo, CSB, and diff bushing.
Edit - checked the engine mounts, transmission mounts, guibo bolts... all tight. So, I’m not sure. It has gotten progressively worse. It used to be a single clunk where now it several. Happens when I’m rolling slow and push the clutch pedal in. Really sounds like it’s coming from the transmission/clutch.
Axles? CSB is backwards? Diff is loose? My diff was backing the bolts out all the time and then I realized the CSB was backwards.
Sounds like it’s coming from the front, I’m going to assume it’s not axles.
It happens when I push clutch in while rolling slowly, so the only “jerky” movements happening to the car is the clutch. It’s not like I’m engaging the clutch and the car jerks where there could be noises generated from play in axles or something.
If that makes sense. That’s why I think it’s something with the clutch. Flywheel coming loose or something.
Guess everyone’s dropping their transmissions this summer
I just wanted to be like the cool kids.
Has anyone done a removable core support on their e30? As I get ready to pull the engine for the 3rd time to check the clutch and to put in the rebuilt m20, a removable core support sounds awfully tempting.
I think @Sam_Holzmann has?
Well if any one can chime in with some pointers or if it's worth the work that would be greatly appreciated.
From what I could dig up it doesn't look like there's one way to do it and you kinda have to dive in, cut it out, and then figure it out from there.
blast from the past
blast from the past
winner winner chicken dinner. Thank you! This doesn't seem too bad.
Two suggestions
#1 Use rivnuts on the chassis side to bolt the core support back in with. It's handy as hell
#2 Make sure to slice things to you can remove your core support without needing to pull the fenders.
#2.5 Have a couple beers, slicing into your core support feels like it should be more calculated than it really is, and a little grinder operation lubricant never hurts.I used a new core support because mine was bent, so I had the luxury of truly destroying it.
I was planning on using rivnuts. Seems much easier than welding nuts for bolts.
I would much rather cut it out without having to pull the fenders. I assume that if I am slicing it so it can ultimately be removed without needing to pull the fenders I shouldnt need to pull the fenders off to do the initial cuts?
I will make sure the mini fridge in the garage is stocked before I start cutting.
The joints need to move smoothly with no grit, binding, or increase in resistance. When you grab the yoke and the shaft and check it for freeplay, there should be none.
CSB should have no cracks in the rubber and the bearing should be tight and quiet as it rotates.
