Took it for a little test drive yesterday afternoon after bleeding the brakes again while activating the ABS/DSC pumps. It stops!!
While on test drive I took the dirty girl through the car wash! It feels good to see this outside!
Last night, we popped in the M5 fuel pump. Had to swap over the 540i top to keep the barbed fitting as the M5 has a quick disconnect.
Swapped the mirror motor pins on the driver's side so pin 1 has the blue wire and pin 2 has the white wire so both door modules matched pin locations. This corrected the mirrors folding opposite ways when you hit the button.
Bled the clutch again, The feel is still not 100% but it drives.
Felt it was time to add the fresh M badge on the motor!
Counting down the days to the exhaust shop!
Dude, you guys absolutely hammered through this. I love your evil laughter in the videos!!
I vote high flow cats and dual resonators. If that's too loud then delete the resonators and run high flow mufflers. As long as the tips go out past the rear bumper and dont turn down, it wont be as loud in the cabin.
Chubs has built some nice exhaust set ups, im sure you will figure out the best option.
Family road trip car so I want it pretty stealthy. Excited to get a gameplan in place and get this DONE!
Did some coding to get the DSC light off and threw on the summer wheels!
Had to switch 2 sensitivity settings to S62B50 and the light went off! Went from 10 to 13 on one and 3 to 2 on the other.
I still need to get the dsc/abs module to think it is a manual but that needs to be done through the IKE (cluster) but I already popped in the M5 cluster so the VINs don't match up. Might need to pop in the 540i cluster to code it to manual then swap back to the M5 cluster. Need to look into this further.
This is so fucking practical. I love this.
Wow! That looks gorgeous!
Loving the tone! Quiet but sporty!
Im here just waiting for sound clip.......
First, family of 4, road trip to Door County was a success!
Need to work out a few bugs and find & fix a new slow leak in the rear air suspension.
Bugs include:
- Code IKE to S62 coolant temp. Getting an engine light due to coolant temp mismatch. (Need to swap back in 540i cluster to get the NCS software to work then swap back M5 cluster. Need all VIN numbers to match in the modules otherwise I can't code.)
- Look into fuel tank purge valve. Getting a code from that not doing it's job for one reason or another.
- Adjust headlights.
This is so fucking practical that it makes me smile. Glad you guys are enjoying it!
so much win.
