<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[E30 alpine  CM5908 Radio]]></title><description><![CDATA[<p dir="auto">Hi Everyone! </p>
<p dir="auto">I recently bought a 1990 E30 convertible which has the CM5908 radio.</p>
<p dir="auto">it was working fine when i first got it but now it turns on but i get no sound.</p>
<p dir="auto">i did buy a used amp and replaced the old one but still no sound. I'm really not </p>
<p dir="auto">sure what's wrong or what to check next any help would be greatly appreciated.</p>
]]></description><link>https://wibimmers.com/topic/9893/e30-alpine-cm5908-radio</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 04:03:58 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/9893.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 07 Sep 2023 14:25:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to E30 alpine  CM5908 Radio on Thu, 14 Sep 2023 18:04:09 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/116767">Boris3 said:</a></strong></p>
<p dir="auto">This might be useful:</p>
<p dir="auto"><a href="https://www.r3vlimited.com/board/forum/e30-technical-forums/car-audio-electronics/387356-understanding-e30-speaker-and-amp-wiring" rel="nofollow ugc">Understanding E30 speaker and amp wiring - R3VLimited Forums</a></p>
<p dir="auto">This is really useful! Thank You!</p>
]]></description><link>https://wibimmers.com/post/116785</link><guid isPermaLink="true">https://wibimmers.com/post/116785</guid><dc:creator><![CDATA[odysseyuk]]></dc:creator><pubDate>Thu, 14 Sep 2023 18:04:09 GMT</pubDate></item><item><title><![CDATA[Reply to E30 alpine  CM5908 Radio on Sat, 09 Sep 2023 18:46:04 GMT]]></title><description><![CDATA[<p dir="auto">This might be useful:</p>
]]></description><link>https://wibimmers.com/post/116767</link><guid isPermaLink="true">https://wibimmers.com/post/116767</guid><dc:creator><![CDATA[Boris3]]></dc:creator><pubDate>Sat, 09 Sep 2023 18:46:04 GMT</pubDate></item><item><title><![CDATA[Reply to E30 alpine  CM5908 Radio on Sat, 09 Sep 2023 18:24:00 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/116755">P_Roloff said:</a></strong></p>
<p dir="auto">Also, seems stupid, but did you check all the inputs to make sure it isn’t just one of them that failed; I.e. a bad auxiliary input cable </p>
<p dir="auto">This vehicle does have a CD changer in the back. I did unplug everything at the back of the deck and plug back in. </p>
<p dir="auto">This is my first BMW and I don't know much about wiring. Any advice would be a great help.</p>
]]></description><link>https://wibimmers.com/post/116766</link><guid isPermaLink="true">https://wibimmers.com/post/116766</guid><dc:creator><![CDATA[odysseyuk]]></dc:creator><pubDate>Sat, 09 Sep 2023 18:24:00 GMT</pubDate></item><item><title><![CDATA[Reply to E30 alpine  CM5908 Radio on Sat, 09 Sep 2023 15:50:39 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/116752">Jdesign said:</a></strong></p>
<p dir="auto">I think we need more information.</p>
<p dir="auto">Have you checked fuses?</p>
<p dir="auto">Have you checked grounds? </p>
<p dir="auto">Have you checked if its getting 12v at the back of the head unit?</p>
<p dir="auto">Did it make scratching or odd noise before it failed?</p>
<p dir="auto">Was it just dead on power up one day? </p>
<p dir="auto">Is there static coming from the speakers now? </p>
<p dir="auto">Do you know if the Amp was tested? Are the capacitors on the amp board good? </p>
<p dir="auto">Are the Output Capacitors good? &lt; based on a quick internet search, I would guess this is your issue.</p>
<p dir="auto">Thanks for the quick response. The radio comes on but no sound from the speakers front or back. </p>
<p dir="auto">I thought it was the amp because i replaced it and the deck started working but then i put the old amp in </p>
<p dir="auto">and that worked too. It would come on randomly but recently it doesn't work at all. There is power at the </p>
<p dir="auto">amp (white wire) and i pulled the tape deck and there is power there too. fuse at the deck and amp are good.</p>
<p dir="auto">Not sure where to go now. This car did have a power antenna but it had been removed i'm not sure if this has anything </p>
<p dir="auto">to do with the radio not working. where would i check the grounds ?</p>
]]></description><link>https://wibimmers.com/post/116765</link><guid isPermaLink="true">https://wibimmers.com/post/116765</guid><dc:creator><![CDATA[odysseyuk]]></dc:creator><pubDate>Sat, 09 Sep 2023 15:50:39 GMT</pubDate></item><item><title><![CDATA[Reply to E30 alpine  CM5908 Radio on Thu, 07 Sep 2023 19:38:41 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Also, seems stupid, but did you check all the inputs to make sure it isn’t just one of them that failed; I.e. a bad auxiliary input cable</p>
]]></description><link>https://wibimmers.com/post/116755</link><guid isPermaLink="true">https://wibimmers.com/post/116755</guid><dc:creator><![CDATA[P_Roloff]]></dc:creator><pubDate>Thu, 07 Sep 2023 19:38:41 GMT</pubDate></item><item><title><![CDATA[Reply to E30 alpine  CM5908 Radio on Thu, 07 Sep 2023 18:45:04 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/116750">odysseyuk said:</a></strong></p>
<p dir="auto">sure what's wrong or what to check next any help would be greatly appreciated. </p>
]]></description><link>https://wibimmers.com/post/116752</link><guid isPermaLink="true">https://wibimmers.com/post/116752</guid><dc:creator><![CDATA[Jdesign]]></dc:creator><pubDate>Thu, 07 Sep 2023 18:45:04 GMT</pubDate></item></channel></rss>
