<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Brief burnt oil smell this morning.]]></title><description><![CDATA[<p dir="auto">Seems my issues will never end:( This morning I was parked at a slight incline. I turned the engine off and ran inside for less than a minute. I came back out and started the car and got a waft of burnt oil smell from the vents. It dissipated in less than a block and never came back after that.</p>
<p dir="auto">Now if you have been following my other threads over on E90post I recently had the water pump replaced after it failed on the way into work. Could my little incident be related? Could it just be the valve cover gasket at 80k? All input is appreciated.</p>
<p dir="auto">I would like to mention that the plugs were replaced in the last couple of months with the old ones looking fantastic for having 70k+ on them. I also changed the oil filter housing gasket last year.</p>
]]></description><link>https://wibimmers.com/topic/923/brief-burnt-oil-smell-this-morning.</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 04:53:37 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/923.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 08 Nov 2012 15:49:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Brief burnt oil smell this morning. on Fri, 16 Nov 2012 16:53:50 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong>240sxguy said:</strong></p>
<p dir="auto">Sounds like they haven't improved the VCG's very much since the E39! Ill make room in the garage if you get over to my house on Monday and we can see what all is involved.</p>
<p dir="auto"><a href="http://www.e90post.com/forums/showthread.php?t=697252" rel="nofollow ugc">http://www.e90post.com/forums/showthread.php?t=697252</a></p>
<p dir="auto">Thanks for the link. I will bring my Bentley manual as well.</p>
]]></description><link>https://wibimmers.com/post/11470</link><guid isPermaLink="true">https://wibimmers.com/post/11470</guid><dc:creator><![CDATA[Snyperx]]></dc:creator><pubDate>Fri, 16 Nov 2012 16:53:50 GMT</pubDate></item><item><title><![CDATA[Reply to Brief burnt oil smell this morning. on Thu, 15 Nov 2012 18:27:16 GMT]]></title><description><![CDATA[<p dir="auto">Sounds like they haven't improved the VCG's very much since the E39! Ill make room in the garage if you get over to my house on Monday and we can see what all is involved.</p>
]]></description><link>https://wibimmers.com/post/11430</link><guid isPermaLink="true">https://wibimmers.com/post/11430</guid><dc:creator><![CDATA[240sxguy]]></dc:creator><pubDate>Thu, 15 Nov 2012 18:27:16 GMT</pubDate></item><item><title><![CDATA[Reply to Brief burnt oil smell this morning. on Thu, 15 Nov 2012 18:13:35 GMT]]></title><description><![CDATA[<p dir="auto">tsweers89,</p>
<p dir="auto">What is the most problematic aspect of changing out the VCG? I really need to look at doing this myself since I have no funds to pay a shop.</p>
]]></description><link>https://wibimmers.com/post/11428</link><guid isPermaLink="true">https://wibimmers.com/post/11428</guid><dc:creator><![CDATA[Snyperx]]></dc:creator><pubDate>Thu, 15 Nov 2012 18:13:35 GMT</pubDate></item><item><title><![CDATA[Reply to Brief burnt oil smell this morning. on Fri, 09 Nov 2012 04:08:43 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong>tsweers89 said:</strong></p>
<p dir="auto">LoL wow. Well its not 2 years. its 12 month part warranty. But even if a indi shop does it and uses bmw factory parts the parts are still covered 12 months. Bet you just did a water pump and not a thermostat also correct? I could of done the job for about half that.</p>
<p dir="auto">Yeah I am sure you could of saved me some money, but considering I had broken down on the side of the road and the dealer was the best option. I had no alternate transportation either. They did in fact replace both the pump and stat.</p>
]]></description><link>https://wibimmers.com/post/11191</link><guid isPermaLink="true">https://wibimmers.com/post/11191</guid><dc:creator><![CDATA[Snyperx]]></dc:creator><pubDate>Fri, 09 Nov 2012 04:08:43 GMT</pubDate></item><item><title><![CDATA[Reply to Brief burnt oil smell this morning. on Fri, 09 Nov 2012 03:47:11 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong>Snyperx said:</strong></p>
<p dir="auto">Yes. $1200, but have a 2 year dealer warranty.</p>
<p dir="auto">Sent from my SCH-R760 using Tapatalk 2</p>
]]></description><link>https://wibimmers.com/post/11190</link><guid isPermaLink="true">https://wibimmers.com/post/11190</guid><dc:creator><![CDATA[tsweers89]]></dc:creator><pubDate>Fri, 09 Nov 2012 03:47:11 GMT</pubDate></item><item><title><![CDATA[Reply to Brief burnt oil smell this morning. on Fri, 09 Nov 2012 02:50:15 GMT]]></title><description><![CDATA[<p dir="auto">Yes. $1200, but have a 2 year dealer warranty.</p>
]]></description><link>https://wibimmers.com/post/11188</link><guid isPermaLink="true">https://wibimmers.com/post/11188</guid><dc:creator><![CDATA[Snyperx]]></dc:creator><pubDate>Fri, 09 Nov 2012 02:50:15 GMT</pubDate></item><item><title><![CDATA[Reply to Brief burnt oil smell this morning. on Fri, 09 Nov 2012 00:56:22 GMT]]></title><description><![CDATA[<p dir="auto">I assume you got raped on the water pump lol.</p>
]]></description><link>https://wibimmers.com/post/11183</link><guid isPermaLink="true">https://wibimmers.com/post/11183</guid><dc:creator><![CDATA[tsweers89]]></dc:creator><pubDate>Fri, 09 Nov 2012 00:56:22 GMT</pubDate></item><item><title><![CDATA[Reply to Brief burnt oil smell this morning. on Fri, 09 Nov 2012 00:55:21 GMT]]></title><description><![CDATA[<p dir="auto">Its very easy to open the hood and inspect to see if the v.c gasket is leaking onto the exhaust. Also your going to have a fun time doing that to if that is.indeed it.</p>
]]></description><link>https://wibimmers.com/post/11182</link><guid isPermaLink="true">https://wibimmers.com/post/11182</guid><dc:creator><![CDATA[tsweers89]]></dc:creator><pubDate>Fri, 09 Nov 2012 00:55:21 GMT</pubDate></item><item><title><![CDATA[Reply to Brief burnt oil smell this morning. on Thu, 08 Nov 2012 17:57:24 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong>wasnt m3 said:</strong></p>
<p dir="auto">Valve cover gasket</p>
<p dir="auto">What pointed you to that conclusion? Just trying to learn as much as I can.</p>
<p dir="auto">P.S. My winter wheel/tires I got from you have been serving me well.</p>
]]></description><link>https://wibimmers.com/post/11160</link><guid isPermaLink="true">https://wibimmers.com/post/11160</guid><dc:creator><![CDATA[Snyperx]]></dc:creator><pubDate>Thu, 08 Nov 2012 17:57:24 GMT</pubDate></item><item><title><![CDATA[Reply to Brief burnt oil smell this morning. on Thu, 08 Nov 2012 16:41:38 GMT]]></title><description><![CDATA[<p dir="auto">Valve cover gasket</p>
]]></description><link>https://wibimmers.com/post/11151</link><guid isPermaLink="true">https://wibimmers.com/post/11151</guid><dc:creator><![CDATA[wasnt m3]]></dc:creator><pubDate>Thu, 08 Nov 2012 16:41:38 GMT</pubDate></item></channel></rss>
