<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[AC and washer delete, now no interior lights, power locks,hazards or 13button OBC]]></title><description><![CDATA[<p dir="auto">Like the title says, ever since I deleted my AC, the windshield washer setup, and my right high beam (For more air flow to turbo stuff) My interior dome lights wont light up, hazards won't work, power locks don't work, any of them, my 13 button OBC doesn't show anything. I'm sure there is more. Car runs, windows go up down, power seats work etc. I just don't know what it is that's not working. Any idea's?</p>
]]></description><link>https://wibimmers.com/topic/849/ac-and-washer-delete-now-no-interior-lights-power-locks-hazards-or-13button-obc</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 04:01:32 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/849.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 01 Oct 2012 23:30:11 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to AC and washer delete, now no interior lights, power locks,hazards or 13button OBC on Sat, 13 Oct 2012 05:12:09 GMT]]></title><description><![CDATA[<p dir="auto">Moved to general technical for future reference.</p>
]]></description><link>https://wibimmers.com/post/10349</link><guid isPermaLink="true">https://wibimmers.com/post/10349</guid><dc:creator><![CDATA[need4speed1299]]></dc:creator><pubDate>Sat, 13 Oct 2012 05:12:09 GMT</pubDate></item><item><title><![CDATA[Reply to AC and washer delete, now no interior lights, power locks,hazards or 13button OBC on Fri, 12 Oct 2012 22:20:17 GMT]]></title><description><![CDATA[<p dir="auto">I've seen loose main relays and fuses cause all sorts of problems. Checking them to see if they are loose or blown is always a good starting point.</p>
<p dir="auto">Glad it all worked out.</p>
]]></description><link>https://wibimmers.com/post/10343</link><guid isPermaLink="true">https://wibimmers.com/post/10343</guid><dc:creator><![CDATA[Boris3]]></dc:creator><pubDate>Fri, 12 Oct 2012 22:20:17 GMT</pubDate></item><item><title><![CDATA[Reply to AC and washer delete, now no interior lights, power locks,hazards or 13button OBC on Fri, 12 Oct 2012 21:36:38 GMT]]></title><description><![CDATA[<p dir="auto">I did it wasn't blown just lose</p>
]]></description><link>https://wibimmers.com/post/10342</link><guid isPermaLink="true">https://wibimmers.com/post/10342</guid><dc:creator><![CDATA[Brian.]]></dc:creator><pubDate>Fri, 12 Oct 2012 21:36:38 GMT</pubDate></item><item><title><![CDATA[Reply to AC and washer delete, now no interior lights, power locks,hazards or 13button OBC on Fri, 12 Oct 2012 19:07:00 GMT]]></title><description><![CDATA[<p dir="auto">If only you had listened to Boris3</p>
<p dir="auto">tsk tsk</p>
]]></description><link>https://wibimmers.com/post/10341</link><guid isPermaLink="true">https://wibimmers.com/post/10341</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Fri, 12 Oct 2012 19:07:00 GMT</pubDate></item><item><title><![CDATA[Reply to AC and washer delete, now no interior lights, power locks,hazards or 13button OBC on Fri, 12 Oct 2012 18:45:29 GMT]]></title><description><![CDATA[<p dir="auto">So, I checked everything, fuses, grounds, plugged all the electrical that I removed back in, still nothing! At this point I was like, fuck it. I guess I won't have those luxuries of what most of my previous vehicles didn't have anyways. I moved on. Well like 5 day's ago, I blew a fuse. (I check ALL fuses religiously dunno why). Come to find out, the fuse for all the things that didn't work, was lose, the prongs got lose, so I just rebent them back together, and VIOLA. ERRYTHING WORKS.</p>
]]></description><link>https://wibimmers.com/post/10340</link><guid isPermaLink="true">https://wibimmers.com/post/10340</guid><dc:creator><![CDATA[Brian.]]></dc:creator><pubDate>Fri, 12 Oct 2012 18:45:29 GMT</pubDate></item><item><title><![CDATA[Reply to AC and washer delete, now no interior lights, power locks,hazards or 13button OBC on Tue, 02 Oct 2012 19:32:26 GMT]]></title><description><![CDATA[<p dir="auto">It checks out good. Put My hood ground back on. Still nothing.</p>
]]></description><link>https://wibimmers.com/post/9996</link><guid isPermaLink="true">https://wibimmers.com/post/9996</guid><dc:creator><![CDATA[Brian.]]></dc:creator><pubDate>Tue, 02 Oct 2012 19:32:26 GMT</pubDate></item><item><title><![CDATA[Reply to AC and washer delete, now no interior lights, power locks,hazards or 13button OBC on Tue, 02 Oct 2012 14:07:47 GMT]]></title><description><![CDATA[<p dir="auto">^ thank you. I'll give that a try, although I didn't mess with that side, never know!</p>
]]></description><link>https://wibimmers.com/post/9989</link><guid isPermaLink="true">https://wibimmers.com/post/9989</guid><dc:creator><![CDATA[Brian.]]></dc:creator><pubDate>Tue, 02 Oct 2012 14:07:47 GMT</pubDate></item><item><title><![CDATA[Reply to AC and washer delete, now no interior lights, power locks,hazards or 13button OBC on Tue, 02 Oct 2012 12:46:53 GMT]]></title><description><![CDATA[<p dir="auto">I checked through the wiring diagrams for those components and they all share a common ground "G200" which is under the dash by the pedals.</p>
<p dir="auto">Reference: <a href="http://wedophones.com/Manuals/BMW/1986%20BMW%20528e%20-%20535i%20Electrical%20Troubleshooting%20Manual.pdf" rel="nofollow ugc">http://wedophones.com/Manuals/BMW/1986%20BMW%20528e%20-%20535i%20Electrical%20Troubleshooting%20Manual.pdf</a></p>
<p dir="auto"><img src="http://mysite.verizon.net/vze7aq8e/sitebuildercontent/sitebuilderpictures/g200gnd.jpg" alt="Posted Image" class=" img-fluid img-markdown" /></p>
<p dir="auto">Inspect/clean-up that ground point and use it to check for continuity with the ground wires on the harness for the components that aren't working. If they check out good then you know the wiring harness is good. Also check the resistance of the ground point with the negative terminal on the battery. If those items checkout good then there is a bad common +12V somewhere in the circuit.</p>
]]></description><link>https://wibimmers.com/post/9988</link><guid isPermaLink="true">https://wibimmers.com/post/9988</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Tue, 02 Oct 2012 12:46:53 GMT</pubDate></item><item><title><![CDATA[Reply to AC and washer delete, now no interior lights, power locks,hazards or 13button OBC on Tue, 02 Oct 2012 05:04:21 GMT]]></title><description><![CDATA[<p dir="auto">Was the first thing I did. They're all fine..</p>
]]></description><link>https://wibimmers.com/post/9983</link><guid isPermaLink="true">https://wibimmers.com/post/9983</guid><dc:creator><![CDATA[Brian.]]></dc:creator><pubDate>Tue, 02 Oct 2012 05:04:21 GMT</pubDate></item><item><title><![CDATA[Reply to AC and washer delete, now no interior lights, power locks,hazards or 13button OBC on Tue, 02 Oct 2012 03:20:58 GMT]]></title><description><![CDATA[<p dir="auto">Check all your fuses?</p>
]]></description><link>https://wibimmers.com/post/9981</link><guid isPermaLink="true">https://wibimmers.com/post/9981</guid><dc:creator><![CDATA[Boris3]]></dc:creator><pubDate>Tue, 02 Oct 2012 03:20:58 GMT</pubDate></item></channel></rss>
