<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Timing Belt]]></title><description><![CDATA[<p dir="auto">I'm going to do a timing belt, misc belts, and water pump replacement first weekend of October on my 1990 325is.</p>
<p dir="auto">I should have all the tools necessary, including a 36mm cone wrench for the fan bolt. Any parts I'm missing or anything else I should do while I'm in there? I attached a screenshot of my shopping cart but it's tiny. Here's the list</p>
<p dir="auto">- Water Pump, Single Outlet (uses metal impeller) NOTE: Also use one 11-51-1-722-677-M17 gasket, 325/e/es/i/is/iC/iX (9/87-92)</p>
<p dir="auto">- Belt, for Wing Cell A/C Compressor, 13 X 810, 318i (1984-85), 325/e/es/i/is/iC/iX (1984-91), M3 (1987-91), 633CSi (1978-03/84)</p>
<p dir="auto">- Belt, Power Steering 10 X 825, E30 323i Euro, 325/e/es, 325i/is/iC/iX Brand: Contitech</p>
<p dir="auto">- Timing Belt Kit (includes tensioner), 325/e/es/i/is/iC/iX (1984-91), Brand: Contitech</p>
<p dir="auto">- Belt, Alternator 10 X 965, E30 325/e/es, 325i/is/iC/iX (1984-91) Brand: Contitech</p>
]]></description><link>https://wibimmers.com/topic/838/timing-belt</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 06:43:28 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/838.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 24 Sep 2012 18:48:02 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Timing Belt on Thu, 27 Sep 2012 05:07:43 GMT]]></title><description><![CDATA[<p dir="auto">I would recommend checking your vacuum lines, especially the one under the intake. The valve cover gasket and oil cap gasket are worth replacing, too.</p>
]]></description><link>https://wibimmers.com/post/9862</link><guid isPermaLink="true">https://wibimmers.com/post/9862</guid><dc:creator><![CDATA[need4speed1299]]></dc:creator><pubDate>Thu, 27 Sep 2012 05:07:43 GMT</pubDate></item><item><title><![CDATA[Reply to Timing Belt on Mon, 24 Sep 2012 19:48:02 GMT]]></title><description><![CDATA[<p dir="auto">I would replace the distributor cap and rotor if you are unsure of the age/condition.</p>
<p dir="auto">I am wishing I would have replaced my camshaft seal but didn't (just because I would hate for it to start leaking, get on the belt and have it jump a tooth / break prematurely)</p>
<p dir="auto">You may check into replacing the alternator mount bushing ( I have never done so but was surprised when I saw it marked down as a replacement part on some parts sites)</p>
<p dir="auto">It would be a good time to replace the coolant hoses up front.</p>
<p dir="auto">I personally would use RTV on the water pump gasket. The Bentley manual made no mention of it, some techs will say you dont need it, I thoroughly cleaned and prepped all my surfaces and ended up doing the timing belt job all over again the next day because it leaked.</p>
<p dir="auto">I spent a lot of time cleaning and de-greasing parts since it was when I first got my car. So the whole job took me about 6 hours start to finish working leisurely. But after I had to do it again (due to the leak) I had it all re-done in 2 hours.</p>
]]></description><link>https://wibimmers.com/post/9821</link><guid isPermaLink="true">https://wibimmers.com/post/9821</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Mon, 24 Sep 2012 19:48:02 GMT</pubDate></item></channel></rss>
