<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Idle Control Vavle question]]></title><description><![CDATA[<p dir="auto">I have a '95 318is, it has this idling problem where it revs up and down from 1000 to 2000 rpms. I heard that and new idle control vavle can do the trick. Do you guys know if this is true? and does anyone know if for e36's, if a idle control valve from a 328i is compatible with 318i? Also if anyone has a idle control valve for sale for a 318, please let me know:).</p>
]]></description><link>https://wibimmers.com/topic/818/idle-control-vavle-question</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 04:51:12 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/818.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 12 Sep 2012 19:59:19 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Idle Control Vavle question on Wed, 19 Sep 2012 04:25:54 GMT]]></title><description><![CDATA[<p dir="auto">FYI I cleaned it when I replaced the intake boot to ICV hose using that writeup. Try unplugging it and see what happens. Wouldn't doubt if there are more vacuum leaks either.</p>
]]></description><link>https://wibimmers.com/post/9737</link><guid isPermaLink="true">https://wibimmers.com/post/9737</guid><dc:creator><![CDATA[YoungCR]]></dc:creator><pubDate>Wed, 19 Sep 2012 04:25:54 GMT</pubDate></item><item><title><![CDATA[Reply to Idle Control Vavle question on Wed, 19 Sep 2012 01:53:09 GMT]]></title><description><![CDATA[<p dir="auto">Try unplugging your ICV. If your car revs up and holds it it's definitely the problem. That or a vacuum leak somewhere.</p>
]]></description><link>https://wibimmers.com/post/9736</link><guid isPermaLink="true">https://wibimmers.com/post/9736</guid><dc:creator><![CDATA[StewCrew]]></dc:creator><pubDate>Wed, 19 Sep 2012 01:53:09 GMT</pubDate></item><item><title><![CDATA[Reply to Idle Control Vavle question on Wed, 19 Sep 2012 01:02:18 GMT]]></title><description><![CDATA[<p dir="auto">Yea its a m42, sorry about that. I found this on cleaning the ICV if anyone needs to know how to do it too. <a href="http://forums.bimmerforums.com/forum/showthread.php?t=454501" rel="nofollow ugc">http://forums.bimmerforums.com/forum/showthread.php?t=454501</a></p>
]]></description><link>https://wibimmers.com/post/9735</link><guid isPermaLink="true">https://wibimmers.com/post/9735</guid><dc:creator><![CDATA[BMWben]]></dc:creator><pubDate>Wed, 19 Sep 2012 01:02:18 GMT</pubDate></item><item><title><![CDATA[Reply to Idle Control Vavle question on Wed, 12 Sep 2012 23:50:02 GMT]]></title><description><![CDATA[<p dir="auto">m42 correct?</p>
<p dir="auto">I could see the ICV being the problem for sure, you should just be able to clean your current one. And no I do not believe a 328 ICV would work.</p>
]]></description><link>https://wibimmers.com/post/9614</link><guid isPermaLink="true">https://wibimmers.com/post/9614</guid><dc:creator><![CDATA[GunMetalGrey]]></dc:creator><pubDate>Wed, 12 Sep 2012 23:50:02 GMT</pubDate></item></channel></rss>
