<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[E30 Ignition Parts, will they fit?]]></title><description><![CDATA[<p dir="auto">I have the coil, cap, rotor, and plug wires from an '87 325, and I'm just wondering if they would work out for an '87 325is.</p>
]]></description><link>https://wibimmers.com/topic/644/e30-ignition-parts-will-they-fit</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 04:49:11 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/644.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 17 May 2012 23:14:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to E30 Ignition Parts, will they fit? on Fri, 18 May 2012 15:12:40 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong>Sagaris said:</strong></p>
<p dir="auto">From a 325e? Yes they will work but the eta wires do not have the impulse sensor on the #6 wire that the 325i does so all 6 injectors will fire simultaneously instead of batch fire (3 at a time). As a result the car will get a little worse fuel mileage.</p>
<p dir="auto">It's just a 325, but that car does have the b27. Thanks!</p>
]]></description><link>https://wibimmers.com/post/7270</link><guid isPermaLink="true">https://wibimmers.com/post/7270</guid><dc:creator><![CDATA[164353]]></dc:creator><pubDate>Fri, 18 May 2012 15:12:40 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Ignition Parts, will they fit? on Thu, 17 May 2012 23:30:17 GMT]]></title><description><![CDATA[<p dir="auto">From a 325e? Yes they will work but the eta wires do not have the impulse sensor on the #6 wire that the 325i does so all 6 injectors will fire simultaneously instead of batch fire (3 at a time). As a result the car will get a little worse fuel mileage.</p>
]]></description><link>https://wibimmers.com/post/7254</link><guid isPermaLink="true">https://wibimmers.com/post/7254</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Thu, 17 May 2012 23:30:17 GMT</pubDate></item></channel></rss>
