<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Z3 3.0 Coupe auto to manual swap]]></title><description><![CDATA[<p dir="auto">Hey all,<br />
 </p>
<p dir="auto">My buddy just picked up a 2001 z3 coupe with a unfinished auto to manual swap.  Cuts RPM at 5k gives a shift selonoid b, lean bank 1 and lean bank 2 codes.  Have cleared memory on impa and no change.  Not sure if it has been reflashed.  No history on it.  Looks like some bridging between the brake wiring to something. have replaced fuel filter and doesnt seem to have vacuum leaks (will check more).  The abs is unhooked and no sensors on any corner. Any advice on this?</p>
]]></description><link>https://wibimmers.com/topic/6244/z3-3.0-coupe-auto-to-manual-swap</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 07:25:11 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/6244.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 01 Dec 2020 02:34:16 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Z3 3.0 Coupe auto to manual swap on Fri, 04 Dec 2020 19:22:16 GMT]]></title><description><![CDATA[<p dir="auto">Post the actual codes please. How long was the swap performed? Did it ever run good prior to the swap?</p>
]]></description><link>https://wibimmers.com/post/108318</link><guid isPermaLink="true">https://wibimmers.com/post/108318</guid><dc:creator><![CDATA[Jdesign]]></dc:creator><pubDate>Fri, 04 Dec 2020 19:22:16 GMT</pubDate></item><item><title><![CDATA[Reply to Z3 3.0 Coupe auto to manual swap on Tue, 01 Dec 2020 14:17:41 GMT]]></title><description><![CDATA[<p dir="auto">I dont suspect the lean codes relate to the swap. I would recommend, in this order:</p>
<p dir="auto">-see how the car drives with the MAF unplugged</p>
<p dir="auto">-check for intake leaks with a smoke test, namely intake boot. </p>
<p dir="auto">-check condition of spark plugs</p>
<p dir="auto">-replace fuel filter</p>
<p dir="auto">-replace MAF</p>
<p dir="auto">-replace O2 sensors</p>
<p dir="auto">-replace spark plugs and coils</p>
<p dir="auto">-replace/clean injectors</p>
<p dir="auto">It is most likely related to intake leaks but multiple weak areas can add up to a single issue</p>
]]></description><link>https://wibimmers.com/post/108277</link><guid isPermaLink="true">https://wibimmers.com/post/108277</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Tue, 01 Dec 2020 14:17:41 GMT</pubDate></item></channel></rss>
