<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ZF 5spd Detent Replacement Tools]]></title><description><![CDATA[<p dir="auto">Hey guys! Anybody have the drift and puller tools to replace the 5th and reverse gear detent shift bushings? Looking to borrow the tools to replace them on my e46 ZF 5spd manual trans before swapping it in. Let me know! Thanks</p>
]]></description><link>https://wibimmers.com/topic/6141/zf-5spd-detent-replacement-tools</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 05:47:04 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/6141.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 15 Sep 2020 00:12:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to ZF 5spd Detent Replacement Tools on Fri, 18 Sep 2020 02:56:41 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/107583">Bassboy3313 said:</a></strong></p>
<p dir="auto">Correct. I just want to knock down any high spots that may have happened. Otherwise the new bushing can get deformed and the detent can stick again. Better safe than sorry, you know?</p>
<p dir="auto">Oh for sure, I just was more concerned if you had the revised pins lol</p>
]]></description><link>https://wibimmers.com/post/107585</link><guid isPermaLink="true">https://wibimmers.com/post/107585</guid><dc:creator><![CDATA[KaiserRolls]]></dc:creator><pubDate>Fri, 18 Sep 2020 02:56:41 GMT</pubDate></item><item><title><![CDATA[Reply to ZF 5spd Detent Replacement Tools on Fri, 18 Sep 2020 01:22:03 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/107578">m42b32 said:</a></strong></p>
<p dir="auto">As long as any damage doesn't protrude and deform the sleeve inward it shouldn't really matter as far as I'm aware</p>
]]></description><link>https://wibimmers.com/post/107583</link><guid isPermaLink="true">https://wibimmers.com/post/107583</guid><dc:creator><![CDATA[Bassboy3313]]></dc:creator><pubDate>Fri, 18 Sep 2020 01:22:03 GMT</pubDate></item><item><title><![CDATA[Reply to ZF 5spd Detent Replacement Tools on Thu, 17 Sep 2020 20:20:31 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/107577">KaiserRolls said:</a></strong></p>
<p dir="auto">Don’t the revised detent pins come with press in sleeves/bushings?? As long as the bore isn’t too mangled I wouldn’t be worried about it as the new detent will have a sleeve to ride in</p>
]]></description><link>https://wibimmers.com/post/107578</link><guid isPermaLink="true">https://wibimmers.com/post/107578</guid><dc:creator><![CDATA[m42b32]]></dc:creator><pubDate>Thu, 17 Sep 2020 20:20:31 GMT</pubDate></item><item><title><![CDATA[Reply to ZF 5spd Detent Replacement Tools on Thu, 17 Sep 2020 19:58:05 GMT]]></title><description><![CDATA[<p dir="auto">Don’t the revised detent pins come with press in sleeves/bushings?? As long as the bore isn’t too mangled I wouldn’t be worried about it as the new detent will have a sleeve to ride in</p>
]]></description><link>https://wibimmers.com/post/107577</link><guid isPermaLink="true">https://wibimmers.com/post/107577</guid><dc:creator><![CDATA[KaiserRolls]]></dc:creator><pubDate>Thu, 17 Sep 2020 19:58:05 GMT</pubDate></item><item><title><![CDATA[Reply to ZF 5spd Detent Replacement Tools on Thu, 17 Sep 2020 14:25:36 GMT]]></title><description><![CDATA[<p dir="auto">The first one was a bitch and a half. Made the mistake of not splitting the bushing completely down the seam. it came loose from the bore, but I was unable to pull it out due to the lower half not being folded in enough. It fell down into the trans, thought I was screwed. Eventually got it out tho. Second one came out super easy after learning from the first one. Now to just get some small files to clean up the bore walls. Then I can get the new ones in and finish up the trans work.</p>
]]></description><link>https://wibimmers.com/post/107570</link><guid isPermaLink="true">https://wibimmers.com/post/107570</guid><dc:creator><![CDATA[Bassboy3313]]></dc:creator><pubDate>Thu, 17 Sep 2020 14:25:36 GMT</pubDate></item><item><title><![CDATA[Reply to ZF 5spd Detent Replacement Tools on Tue, 15 Sep 2020 23:04:39 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/107553">Bassboy3313 said:</a></strong></p>
<p dir="auto">Just grabbed the drifts from Joe. Should definitely help with installing the new bushings. Just have to get creative to remove the detents and old bushings....</p>
<p dir="auto">It’s not too bad of a job, use some picks/screwdrivers/needle nose pliers and take your time</p>
]]></description><link>https://wibimmers.com/post/107554</link><guid isPermaLink="true">https://wibimmers.com/post/107554</guid><dc:creator><![CDATA[KaiserRolls]]></dc:creator><pubDate>Tue, 15 Sep 2020 23:04:39 GMT</pubDate></item><item><title><![CDATA[Reply to ZF 5spd Detent Replacement Tools on Tue, 15 Sep 2020 20:01:12 GMT]]></title><description><![CDATA[<p dir="auto">Just grabbed the drifts from Joe. Should definitely help with installing the new bushings. Just have to get creative to remove the detents and old bushings....</p>
]]></description><link>https://wibimmers.com/post/107553</link><guid isPermaLink="true">https://wibimmers.com/post/107553</guid><dc:creator><![CDATA[Bassboy3313]]></dc:creator><pubDate>Tue, 15 Sep 2020 20:01:12 GMT</pubDate></item><item><title><![CDATA[Reply to ZF 5spd Detent Replacement Tools on Tue, 15 Sep 2020 18:31:19 GMT]]></title><description><![CDATA[<p dir="auto">Can confirm that Joes tools work great</p>
]]></description><link>https://wibimmers.com/post/107552</link><guid isPermaLink="true">https://wibimmers.com/post/107552</guid><dc:creator><![CDATA[KaiserRolls]]></dc:creator><pubDate>Tue, 15 Sep 2020 18:31:19 GMT</pubDate></item><item><title><![CDATA[Reply to ZF 5spd Detent Replacement Tools on Tue, 15 Sep 2020 00:20:37 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/107542">m42b32 said:</a></strong></p>
<p dir="auto">I do!</p>
<p dir="auto">Sweet! I'll text ya! <img src="https://wibimmers.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f44d.png?v=6c9209168ce" class="not-responsive emoji emoji-android emoji--+1" style="height:23px;width:auto;vertical-align:middle" title="👍" alt="👍" /></p>
]]></description><link>https://wibimmers.com/post/107544</link><guid isPermaLink="true">https://wibimmers.com/post/107544</guid><dc:creator><![CDATA[Bassboy3313]]></dc:creator><pubDate>Tue, 15 Sep 2020 00:20:37 GMT</pubDate></item><item><title><![CDATA[Reply to ZF 5spd Detent Replacement Tools on Tue, 15 Sep 2020 00:17:01 GMT]]></title><description><![CDATA[<p dir="auto">I do!</p>
]]></description><link>https://wibimmers.com/post/107542</link><guid isPermaLink="true">https://wibimmers.com/post/107542</guid><dc:creator><![CDATA[m42b32]]></dc:creator><pubDate>Tue, 15 Sep 2020 00:17:01 GMT</pubDate></item></channel></rss>
