  4. E46 Touring Life
E46 Touring Life
87 Posts 11 Posters 1.6k Views 1 Watching
    I like how the wagon still towers over the coupe
      Touring makes it look so tiny and the touring isn't even big 😂
        So I've been having a rougher idle on the touring the past few weeks. I installed BMW Scanner and INPA on my spare laptop and connected it up. Cleared all the adaptations and scanned it for codes. These are what I pulled
        Error Code 106 - Control Vanos Mechanicall Outlet Blocked or Jammed
        Error Code 8 - Air Flow Meter
        Error Code 106 could if been a few different things, cam sensor, vanos seals, vanos solenoids, etc. I decided to start swapping parts off the Z3 coupe to diagnose the problem. Started with the exhaust side cam position sensor. Swapped the part, cleared adaptations and Error codes, fired it up. Luckily first try was a success! Cam sensor cleared the Error Code 106.
        For Error Code 8, I was going to swap MAFs, but unfortunately the 2.8L Z3 coupe MAF is the same size as the B25 MAF, not the B30 MAF. Decided to just go ahead a buy a new MAF off FCP Euro while purchasing tue new cam sensor and oring. Hopefully this is it and daily driving commences.
        After this, still gotta full up the AC system and good to go. 👍
          Replaced both cam sensors seemed to have fixed my idling issues which is awesome. Had a bad knocking sound on acceleration off a stop which I pinpointed to the driveshaft CSB and flex disc guibo. So off with the exhaust, heatshield and driveshaft for the third time. Replaced them and all is good now.
          Daily driver status commence!!
            Today a new owner got the opportunity to grab this touring and hopefully enjoy it as much as I have. This car was very enjoyable after the B30 and manual swap. It definitely didn't hurt the value either. Time for something new as a daily tho.
            Currently in the market for something different. Thinking either an e91 Touring or even a Mini Countryman S to have some boost back in my life while still being able to haul things. Any other suggestions are welcomed.
              My wife's car is an R60 Countryman S All4 and it's pretty fun to drive even with an automatic, good in the snow, and gets like 30mpg too. Not nearly as much room inside as the e91 (it's easily a foot shorter) but still can fit a decent amount of stuff inside with the back seats folded.
                That's definitely some good info, thanks! I was planning on going to see these three this weekend. Any insight always helps.
                https://www.facebook.com/marketplace/item/5490729274374093/
                https://www.facebook.com/marketplace/item/1303804813527857/
                https://www.facebook.com/marketplace/item/699095657848007/
