<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Gauges (WB02, OIL, VOLT), e30 swap brakes, clutch master]]></title><description><![CDATA[<p dir="auto">AEM X-Series Wideband $130 - Uses the Bosch 4.9 sensor which is the fastest responding on the market. SOLD<br />
Ashtray pod with VDO electric oil pressure(includes sending unit) and volt meter $120</p>
<p dir="auto"><img src="https://i.imgur.com/3MHLYZU.jpg" alt="3MHLYZU.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">Chasebays brake booster eliminator AND brake line relocation kit $200 SOLD</p>
<p dir="auto">e30 pedal assembly (airbag)  with retrofitted wilwood 7/8" clutch master cylinder $75 PENDING</p>
<p dir="auto"><img src="https://i.imgur.com/XRKusAE.jpg" alt="XRKusAE.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="https://i.imgur.com/E2SD1E2.jpg" alt="E2SD1E2.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://wibimmers.com/topic/6100/gauges-wb02-oil-volt-e30-swap-brakes-clutch-master</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 04:03:17 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/6100.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 17 Aug 2020 19:56:23 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Gauges (WB02, OIL, VOLT), e30 swap brakes, clutch master on Sat, 05 Sep 2020 13:37:25 GMT]]></title><description><![CDATA[<p dir="auto">PM's on the brake pedal!</p>
]]></description><link>https://wibimmers.com/post/107444</link><guid isPermaLink="true">https://wibimmers.com/post/107444</guid><dc:creator><![CDATA[Jdesign]]></dc:creator><pubDate>Sat, 05 Sep 2020 13:37:25 GMT</pubDate></item><item><title><![CDATA[Reply to Gauges (WB02, OIL, VOLT), e30 swap brakes, clutch master on Wed, 02 Sep 2020 16:39:05 GMT]]></title><description><![CDATA[<p dir="auto">Sikky oil filter relocation kit ($175 new) - $80 Features 10AN lines/fittings and an oil filter mount with 3/4-16 oil filter threads. SOLD</p>
]]></description><link>https://wibimmers.com/post/107405</link><guid isPermaLink="true">https://wibimmers.com/post/107405</guid><dc:creator><![CDATA[Nick_08]]></dc:creator><pubDate>Wed, 02 Sep 2020 16:39:05 GMT</pubDate></item></channel></rss>
