<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Garage Floor Epoxy vs floor tiles?]]></title><description><![CDATA[<p dir="auto">Now that I actually have a garage space worth caring about (aka room for all of my shit), I'm thinking about getting something to protect the garage floor and make it look a little better.</p>
<p dir="auto">Anyone here have experience doing their own epoxy? Or has anyone installed those snazzy clip together plastic/rubber tiles?</p>
<p dir="auto">Epoxy would be significantly cheaper DIY, less than $400 for supplies + my time which is basically worthless.</p>
<p dir="auto">Tiles would be in excess of $1500.</p>
<p dir="auto"><img src="https://live.staticflickr.com/65535/49793279497_750cc1a2e1_b.jpg" alt="49793279497750cc1a2e1b.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="https://live.staticflickr.com/65535/49963093718_74198fd8e6_b.jpg" alt="4996309371874198fd8e6b.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://wibimmers.com/topic/6015/garage-floor-epoxy-vs-floor-tiles</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 04:02:05 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/6015.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 12 Jun 2020 20:22:22 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Garage Floor Epoxy vs floor tiles? on Wed, 15 Jul 2020 03:38:36 GMT]]></title><description><![CDATA[<p dir="auto">Only thing I have seen is grinding the concrete with floor sander that has diamond scuff abrasive on it. This will prep it for the new coating.</p>
]]></description><link>https://wibimmers.com/post/106858</link><guid isPermaLink="true">https://wibimmers.com/post/106858</guid><dc:creator><![CDATA[Bassboy3313]]></dc:creator><pubDate>Wed, 15 Jul 2020 03:38:36 GMT</pubDate></item><item><title><![CDATA[Reply to Garage Floor Epoxy vs floor tiles? on Tue, 14 Jul 2020 19:07:28 GMT]]></title><description><![CDATA[<p dir="auto">Does anyone have any advice for removing a sealant on a garage floor? I would love to do a coating of some type on it, but I'm 99% certain that when they poured our slab, they put a sealant on it. Water and oil seem to sit on top of the concrete rather than soak in and it has coloration in spots that doesn't look like standard concrete.</p>
]]></description><link>https://wibimmers.com/post/106856</link><guid isPermaLink="true">https://wibimmers.com/post/106856</guid><dc:creator><![CDATA[gilber33]]></dc:creator><pubDate>Tue, 14 Jul 2020 19:07:28 GMT</pubDate></item><item><title><![CDATA[Reply to Garage Floor Epoxy vs floor tiles? on Sun, 21 Jun 2020 13:23:43 GMT]]></title><description><![CDATA[<p dir="auto">^^^ Very helpful list, thanks!</p>
<p dir="auto">I do like the point that you can bring the tiles with, I'd not even considered that..</p>
]]></description><link>https://wibimmers.com/post/106587</link><guid isPermaLink="true">https://wibimmers.com/post/106587</guid><dc:creator><![CDATA[Ryan...]]></dc:creator><pubDate>Sun, 21 Jun 2020 13:23:43 GMT</pubDate></item><item><title><![CDATA[Reply to Garage Floor Epoxy vs floor tiles? on Sat, 20 Jun 2020 16:27:47 GMT]]></title><description><![CDATA[<p dir="auto">I have experience with a few surfaces and here is my input:</p>
<p dir="auto"><strong>Tiles</strong></p>
<p dir="auto">Pros</p>
<ul>
<li>more absorbant to impacts, comfortable to stand/walk on </li>
<li>you can take them with you when you relocate</li>
<li>you can replace ones that fail fairly easy</li>
<li>temperature - They are much better to lay on that concrete</li>
<li>can use right after install</li>
</ul>
<p dir="auto">Cons</p>
<ul>
<li>Liquids can leak through and stain or stink (gear lube) the surface underneath making it hard to clean up spills</li>
<li>most expensive</li>
<li>noise can be an issue depending on the underlayment</li>
<li>fitting around corners and mounting machines to the floor can be a challenge</li>
</ul>
<p dir="auto"><strong>Floor coating (paint)</strong></p>
<ul>
<li>very strong</li>
<li>easy to install</li>
<li>easy to clean up spills</li>
<li>fairly inexpensive</li>
<li>mounting equipment to the floor is easy</li>
</ul>
<ul>
<li>color chips need to be added for traction which can make it hard to find nuts/bolts and small hardware </li>
<li>tends to be very slick when wet</li>
<li>you cant take it with when you relocate</li>
<li>you have to allow it to cure before parking or putting anything on it</li>
<li>still cold when laying on it</li>
</ul>
<p dir="auto"><strong>Concrete polish/sealing</strong></p>
<ul>
<li>not as slick as paint depending on sealant used</li>
</ul>
<ul>
<li>general install requires stages for a good finish</li>
</ul>
<p dir="auto">--- </p>
<p dir="auto">With that said my input is tiles are the best if its a home garage. You can always take them with you when you leave too. So the price is not as bad if you consider that you will have them for a very long time. If its a shop, coatings are normally the better answer because of clean-ability,  ability to mount lifts and other equipment, and less set up time.</p>
]]></description><link>https://wibimmers.com/post/106580</link><guid isPermaLink="true">https://wibimmers.com/post/106580</guid><dc:creator><![CDATA[Jdesign]]></dc:creator><pubDate>Sat, 20 Jun 2020 16:27:47 GMT</pubDate></item><item><title><![CDATA[Reply to Garage Floor Epoxy vs floor tiles? on Wed, 17 Jun 2020 02:42:39 GMT]]></title><description><![CDATA[<p dir="auto">Lots of good points being made here... I'm not necessarily confident I could do a quality DIY epoxy job.</p>
<p dir="auto">AFAIK my floor wasn't sealed, so maybe polishing it would be a nice option as well...</p>
]]></description><link>https://wibimmers.com/post/106527</link><guid isPermaLink="true">https://wibimmers.com/post/106527</guid><dc:creator><![CDATA[Ryan...]]></dc:creator><pubDate>Wed, 17 Jun 2020 02:42:39 GMT</pubDate></item><item><title><![CDATA[Reply to Garage Floor Epoxy vs floor tiles? on Mon, 15 Jun 2020 19:57:27 GMT]]></title><description><![CDATA[<p dir="auto">i guess it depends on what your priorities are on form and function. its kinda the old 'pick 2' thing:</p>
<p dir="auto">1. Durability</p>
<p dir="auto">2. Aesthetics</p>
<p dir="auto">3. Cost</p>
<p dir="auto">Personally, I'd never epoxy a floor in a state that is going to get frigid cold/snow &amp; salt melt all over it. Spend all that money than in a few years you have peeling/chipping. That would be annoying.</p>
<p dir="auto">If I had fresh concrete I'd be looking at polishing it over anything else. A polished concrete is really not that slippery when wet, its actually rated as 'slip resistant' floor in commercial applications. It is slippery when sand or other small media is on it, but how often is that kind of spill in a person's garage?</p>
]]></description><link>https://wibimmers.com/post/106508</link><guid isPermaLink="true">https://wibimmers.com/post/106508</guid><dc:creator><![CDATA[straight6pwr]]></dc:creator><pubDate>Mon, 15 Jun 2020 19:57:27 GMT</pubDate></item><item><title><![CDATA[Reply to Garage Floor Epoxy vs floor tiles? on Mon, 15 Jun 2020 19:09:29 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/106502">patsbimmer1 said:</a></strong></p>
<p dir="auto">the amount of filth that would gather under them and the cost would keep me away.</p>
<p dir="auto">But thats one of their selling points. They say you should pull them up and vacuum every 3 or so years. And they are easy to pull up if you drip oil under them.</p>
]]></description><link>https://wibimmers.com/post/106507</link><guid isPermaLink="true">https://wibimmers.com/post/106507</guid><dc:creator><![CDATA[Rekpoint]]></dc:creator><pubDate>Mon, 15 Jun 2020 19:09:29 GMT</pubDate></item><item><title><![CDATA[Reply to Garage Floor Epoxy vs floor tiles? on Mon, 15 Jun 2020 18:24:36 GMT]]></title><description><![CDATA[<p dir="auto">When I was with Blain's they started doing polished cement in parts of the newer service centers and warehouses and it could become slippery when wet or dusty.  This was with me wearing CAT slip resistant work boots.  I haven't experienced that with epoxy coatings.  When my dad owned his own painting business he did a few and his advice to me was it was pretty simple but if it is applied to a surface that was the slightest bit dirty you would have a longevity issue.  I've also seen these in professional shops with no issues as long as they are allowed to cure properly.</p>
<p dir="auto">I have no experience with the flooring options but as stated above by REK, the amount of filth that would gather under them and the cost would keep me away.</p>
]]></description><link>https://wibimmers.com/post/106502</link><guid isPermaLink="true">https://wibimmers.com/post/106502</guid><dc:creator><![CDATA[patsbimmer1]]></dc:creator><pubDate>Mon, 15 Jun 2020 18:24:36 GMT</pubDate></item><item><title><![CDATA[Reply to Garage Floor Epoxy vs floor tiles? on Mon, 15 Jun 2020 14:14:10 GMT]]></title><description><![CDATA[<p dir="auto">My completely anecdotal and no experience comment is that Swiss tracks or similar products may be difficult for homes in our part of the country as the water/dirt and grime from snow will seep beneath them and get dirty quickly. <br />
 </p>
<p dir="auto">Is the concrete sealed in the garage? You could always just have the concrete polished and it would act in a similar nature to epoxy without the possibility of chipping. Would still have a more “finished” look to it and could be cleaned quite easily.</p>
]]></description><link>https://wibimmers.com/post/106495</link><guid isPermaLink="true">https://wibimmers.com/post/106495</guid><dc:creator><![CDATA[SteelBlue]]></dc:creator><pubDate>Mon, 15 Jun 2020 14:14:10 GMT</pubDate></item><item><title><![CDATA[Reply to Garage Floor Epoxy vs floor tiles? on Mon, 15 Jun 2020 13:51:25 GMT]]></title><description><![CDATA[<p dir="auto">I've been debating on this topic for awhile now.  I was totally on board with the epoxy leaning towards professional install just to make sure it was done right with a high quality product, but it does seem like there are a lot of quality DIY options.</p>
<p dir="auto">But......The use of epoxy still scares me.  I've seen it damaged from weld spatter, tire chirping, dropping heavy things on it, etc.  It seems like repairing epoxy is, at best, a band-aide and very visible.</p>
<p dir="auto">Racedeck or other similar snap tile is expensive, noisy, and doesn't handle jackstands, etc well.  Not to mention the disgusting underside that becomes a reality after a few years.</p>
<p dir="auto">I understand that my take-aways aren't the same for everyone and a quality debate could be made of any of them.  But.....I researched another idea and really like it.</p>
<p dir="auto">Armstrong VCT (Vinyl Composite Tile).  Basically the stuff Targets and Walmarts use on their floor.  It's relatively cheap, needs little prep, easy to install and very hardy.  It can be waxed (high end commercial waxes work best) and if you do damage a tile beyond what wax will fix, you can replace that tile.</p>
<p dir="auto">There are a lot of different colors and patterns you can use and they are readily available.  Another huge advantage is that you can do a section of your garage, then move stuff onto that section and do another section.  You don't have to completely clear out a space for days while the install happens.</p>
<p dir="auto">Just another thought to consider.</p>
]]></description><link>https://wibimmers.com/post/106493</link><guid isPermaLink="true">https://wibimmers.com/post/106493</guid><dc:creator><![CDATA[REKIII]]></dc:creator><pubDate>Mon, 15 Jun 2020 13:51:25 GMT</pubDate></item><item><title><![CDATA[Reply to Garage Floor Epoxy vs floor tiles? on Sun, 14 Jun 2020 14:47:31 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/106454">ChrisO said:</a></strong></p>
<p dir="auto">Damn, nice garage</p>
<p dir="auto">I'd be worried about jack stands on rubber tiles not sitting very flat or slicing into them</p>
<p dir="auto">The ones i mentioned are not rubber. They are a copolymer polypropylene plastic. GarageDeck and GarageTrac are both made by RaceDeck as well. Just some info to help compare options.</p>
]]></description><link>https://wibimmers.com/post/106471</link><guid isPermaLink="true">https://wibimmers.com/post/106471</guid><dc:creator><![CDATA[Bassboy3313]]></dc:creator><pubDate>Sun, 14 Jun 2020 14:47:31 GMT</pubDate></item><item><title><![CDATA[Reply to Garage Floor Epoxy vs floor tiles? on Sun, 14 Jun 2020 09:57:25 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">That's a good point... I'm not doing much labor on cars nowadays, no more project cars at the moment. </p>
<p dir="auto">I have considered leaving the 3rd stall without the tiles as it's where I park my motorcycles anyway. That could be my designated work area too should I need it.</p>
]]></description><link>https://wibimmers.com/post/106468</link><guid isPermaLink="true">https://wibimmers.com/post/106468</guid><dc:creator><![CDATA[Ryan...]]></dc:creator><pubDate>Sun, 14 Jun 2020 09:57:25 GMT</pubDate></item><item><title><![CDATA[Reply to Garage Floor Epoxy vs floor tiles? on Sat, 13 Jun 2020 19:55:56 GMT]]></title><description><![CDATA[<p dir="auto">Damn, nice garage</p>
]]></description><link>https://wibimmers.com/post/106454</link><guid isPermaLink="true">https://wibimmers.com/post/106454</guid><dc:creator><![CDATA[ChrisO]]></dc:creator><pubDate>Sat, 13 Jun 2020 19:55:56 GMT</pubDate></item><item><title><![CDATA[Reply to Garage Floor Epoxy vs floor tiles? on Sat, 13 Jun 2020 10:52:07 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/106448">YoungCR said:</a></strong></p>
<p dir="auto">It looks like a new garage correct? Have you looked into having the concrete polished and sealed instead? It doesn't look as fancy but it won't scratch off.</p>
<p dir="auto">Newish, built last November but only been used since April.  I have not looked into that, I'll add that to my research though!</p>
<p dir="auto"><strong><a href="/post/106449">Bassboy3313 said:</a></strong></p>
<p dir="auto">I am currently in the same boat as you. I looked into professional epoxy jobs for my 2.5 car garage and its around $2500-$3000. I then found GarageDeck interlocking tiles from <a href="http://bigfloors.com" rel="nofollow ugc">bigfloors.com</a>. To do the same floor would be $1050 shipped to my door and my labor to install is obviously free. Leaning towards the tiles myself. I'd also rather have solid tiles rather then the Swisstracks open tiles too in case there is a oil or gas spill. Easier cleanup with solid tiles. </p>
<p dir="auto">That does seem like it'd be a lot cheaper than the stuff I was looking at, and the easy install is a big plus... And cool color options/design change.</p>
<p dir="auto">So many options...</p>
]]></description><link>https://wibimmers.com/post/106450</link><guid isPermaLink="true">https://wibimmers.com/post/106450</guid><dc:creator><![CDATA[Ryan...]]></dc:creator><pubDate>Sat, 13 Jun 2020 10:52:07 GMT</pubDate></item><item><title><![CDATA[Reply to Garage Floor Epoxy vs floor tiles? on Sat, 13 Jun 2020 04:01:57 GMT]]></title><description><![CDATA[<p dir="auto">I am currently in the same boat as you. I looked into professional epoxy jobs for my 2.5 car garage and its around $2500-$3000. I then found GarageDeck interlocking tiles from <a href="http://bigfloors.com" rel="nofollow ugc">bigfloors.com</a>. To do the same floor would be $1050 shipped to my door and my labor to install is obviously free. Leaning towards the tiles myself. I'd also rather have solid tiles rather then the Swisstracks open tiles too in case there is a oil or gas spill. Easier cleanup with solid tiles.</p>
]]></description><link>https://wibimmers.com/post/106449</link><guid isPermaLink="true">https://wibimmers.com/post/106449</guid><dc:creator><![CDATA[Bassboy3313]]></dc:creator><pubDate>Sat, 13 Jun 2020 04:01:57 GMT</pubDate></item><item><title><![CDATA[Reply to Garage Floor Epoxy vs floor tiles? on Sat, 13 Jun 2020 02:59:23 GMT]]></title><description><![CDATA[<p dir="auto">It looks like a new garage correct? Have you looked into having the concrete polished and sealed instead? It doesn't look as fancy but it won't scratch off.</p>
]]></description><link>https://wibimmers.com/post/106448</link><guid isPermaLink="true">https://wibimmers.com/post/106448</guid><dc:creator><![CDATA[YoungCR]]></dc:creator><pubDate>Sat, 13 Jun 2020 02:59:23 GMT</pubDate></item><item><title><![CDATA[Reply to Garage Floor Epoxy vs floor tiles? on Sat, 13 Jun 2020 02:23:25 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/106443">The Full Banana said:</a></strong></p>
<p dir="auto">I did a polycuramine coating in my garage and am happy with it after 2 years of abuse so far.</p>
<p dir="auto">You can buy Rustoleum stuff off the shelf and they have two types: standard epoxy and polycuramine. The polycuramine is significantly more expensive, but I wouldn't put down their epoxy given what I've heard from friends who did it and saw it start chipping rather quickly. </p>
<p dir="auto"><a href="https://www.rustoleum.com/product-catalog/consumer-brands/rocksolid/garage-floor-kits/polycuramine-garage-floor-coating-kit" rel="nofollow ugc">https://www.rustoleum.com/product-catalog/consumer-brands/rocksolid/garage-floor-kits/polycuramine-garage-floor-coating-kit</a></p>
<p dir="auto">Good to know, I shall do more research into this polycuramine substance of which you speak.</p>
<p dir="auto">I'd hate to go through all the work of doing this right, only to have it peel/chip up on me in the next couple years..</p>
<p dir="auto"><strong><a href="/post/106446">Rekpoint said:</a></strong></p>
<p dir="auto">Yeah thats what Ive heard too.</p>
<p dir="auto">The go to tile solution everyone tends to go with are Swiss Tracks </p>
<p dir="auto"><a href="https://www.obsessedgarage.com/collections/garage-flooring" rel="nofollow ugc">https://www.obsessedgarage.com/collections/garage-flooring</a></p>
<p dir="auto">Those are the guys I was looking at. I could also save a little money by not doing the whole garage, but I think that'd end up looking pretty tacky..</p>
]]></description><link>https://wibimmers.com/post/106447</link><guid isPermaLink="true">https://wibimmers.com/post/106447</guid><dc:creator><![CDATA[Ryan...]]></dc:creator><pubDate>Sat, 13 Jun 2020 02:23:25 GMT</pubDate></item><item><title><![CDATA[Reply to Garage Floor Epoxy vs floor tiles? on Sat, 13 Jun 2020 01:59:42 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/106445">KaiserRolls said:</a></strong></p>
<p dir="auto">This. I’ve seen the cheap stuff chip within a few years almost every time </p>
]]></description><link>https://wibimmers.com/post/106446</link><guid isPermaLink="true">https://wibimmers.com/post/106446</guid><dc:creator><![CDATA[Rekpoint]]></dc:creator><pubDate>Sat, 13 Jun 2020 01:59:42 GMT</pubDate></item><item><title><![CDATA[Reply to Garage Floor Epoxy vs floor tiles? on Fri, 12 Jun 2020 22:42:17 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">This. I’ve seen the cheap stuff chip within a few years almost every time</p>
]]></description><link>https://wibimmers.com/post/106445</link><guid isPermaLink="true">https://wibimmers.com/post/106445</guid><dc:creator><![CDATA[KaiserRolls]]></dc:creator><pubDate>Fri, 12 Jun 2020 22:42:17 GMT</pubDate></item><item><title><![CDATA[Reply to Garage Floor Epoxy vs floor tiles? on Fri, 12 Jun 2020 21:38:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jdesign" aria-label="Profile: Jdesign">@<bdi>Jdesign</bdi></a> can probably weigh in on the tiles...</p>
]]></description><link>https://wibimmers.com/post/106444</link><guid isPermaLink="true">https://wibimmers.com/post/106444</guid><dc:creator><![CDATA[P_Roloff]]></dc:creator><pubDate>Fri, 12 Jun 2020 21:38:10 GMT</pubDate></item><item><title><![CDATA[Reply to Garage Floor Epoxy vs floor tiles? on Fri, 12 Jun 2020 20:58:56 GMT]]></title><description><![CDATA[<p dir="auto">I did a polycuramine coating in my garage and am happy with it after 2 years of abuse so far.</p>
]]></description><link>https://wibimmers.com/post/106443</link><guid isPermaLink="true">https://wibimmers.com/post/106443</guid><dc:creator><![CDATA[The Full Banana]]></dc:creator><pubDate>Fri, 12 Jun 2020 20:58:56 GMT</pubDate></item></channel></rss>
