<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Congrats!]]></title><description><![CDATA[<p dir="auto">Congrats <a class="plugin-mentions-user plugin-mentions-a" href="/user/suspenceful" aria-label="Profile: suspenceful">@<bdi>suspenceful</bdi></a> at dethroning <a class="plugin-mentions-user plugin-mentions-a" href="/user/patsbimmer1" aria-label="Profile: patsbimmer1">@<bdi>patsbimmer1</bdi></a> and claiming the title of “Fastest N54 in the World and Wisconsin“!</p>
<p dir="auto">You have certainly done more than just a piggyback and FBO to get there. Kudos, would be cool to see single digits.</p>
]]></description><link>https://wibimmers.com/topic/6008/congrats</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 09:23:36 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/6008.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 09 Jun 2020 01:47:59 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Congrats! on Thu, 11 Jun 2020 15:53:43 GMT]]></title><description><![CDATA[<p dir="auto">Thanks guys!</p>
<p dir="auto"><strong><a href="/post/106407">HipMF said:</a></strong></p>
<p dir="auto">As I'm sure you're aware, getting fast and consistent 60-foot times will be imperative if you intend to get into the 9s. Just like in road racing, if you're not fast out of the corner, you're losing time the whole way down the straightaway. The car seems to hook up pretty well off the line, but there's no way you can make the most out of the available traction just with your left foot. The difference between a good launch and a bad one will be down to millimeters and 1/10ths of a second. I'm not recommending this solution per-se, but it is one way to take the variables out of your launch:</p>
<p dir="auto"><img src="https://lh3.googleusercontent.com/proxy/oWv_V9ej0m-rQFbZncP6ZBRwVKAFs_PWa9IHjSZS8djpc23HuhKb1KB9hWqPCaaeCXnTkTWISUVXcWHCFjHLgjt1LuI2EbYkSKh-IcQ" alt="oWvV9ej0m-rQFbZncP6ZBRwVKAFsPWa9IHjSZS" class=" img-fluid img-markdown" /></p>
<p dir="auto">Yes, it's a screen-door closer connected to the clutch pedal. Obviously not the most elegant or highly engineered solution, but it allows you to just slip your foot off the clutch and the car launches itself. Crude for sure, but by adjusting the pivot point, you can get the right amount of clutch slip to keep the engine at the right power output for the traction that's available and it takes the human error out of the equation and allows you to dial in the launch. I'm sure there's a better solution out there, but the point is if you can't nail the launch, then the rest of your run is worthless, and unless you're some kind of 7th level Shaolin clutch guru, you're never gonna get a consistent launch just relying on your left leg.</p>
<p dir="auto">Believe it or not, I already tried an even more advanced version of a clutch slipping device about a year ago. Clearly you're not watching my videos (kidding) <img src="https://wibimmers.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f606.png?v=6c9209168ce" class="not-responsive emoji emoji-android emoji--laughing" style="height:23px;width:auto;vertical-align:middle" title=":laughing:" alt="😆" /></p>
<p dir="auto">Watch this video (I time-stamped it to start at the point I'm talking about the device):</p>
<p dir="auto">It didn't work as I wanted it too. Would slip too much even at the fastest slip point, and then would interfere with my shifting down the track even though it wasn't supposed to be.</p>
<p dir="auto">Great idea in theory, but I think I'll just try to train my legs as best I can. It'll never be perfect, but with these bias ply tires, I can almost dump the clutch like I did for my 1.59 60ft and the slicks will absorb the hit and propel forward. Completely different feeling than my radial tires, couldn't believe it 'til I used them.</p>
<p dir="auto"><strong><a href="/post/106409">B C said:</a></strong></p>
<p dir="auto">Do you launch in 1st or 2nd?</p>
<p dir="auto">1st. When I tried 2nd, it would bog every time.</p>
]]></description><link>https://wibimmers.com/post/106429</link><guid isPermaLink="true">https://wibimmers.com/post/106429</guid><dc:creator><![CDATA[suspenceful]]></dc:creator><pubDate>Thu, 11 Jun 2020 15:53:43 GMT</pubDate></item><item><title><![CDATA[Reply to Congrats! on Wed, 10 Jun 2020 17:06:58 GMT]]></title><description><![CDATA[<p dir="auto">Congrats man. Time to call up black magic for a custom slipper clutch</p>
]]></description><link>https://wibimmers.com/post/106418</link><guid isPermaLink="true">https://wibimmers.com/post/106418</guid><dc:creator><![CDATA[KaiserRolls]]></dc:creator><pubDate>Wed, 10 Jun 2020 17:06:58 GMT</pubDate></item><item><title><![CDATA[Reply to Congrats! on Wed, 10 Jun 2020 13:55:24 GMT]]></title><description><![CDATA[<p dir="auto">granny shifting, not double clutching like you should.</p>
]]></description><link>https://wibimmers.com/post/106410</link><guid isPermaLink="true">https://wibimmers.com/post/106410</guid><dc:creator><![CDATA[straight6pwr]]></dc:creator><pubDate>Wed, 10 Jun 2020 13:55:24 GMT</pubDate></item><item><title><![CDATA[Reply to Congrats! on Wed, 10 Jun 2020 10:40:23 GMT]]></title><description><![CDATA[<p dir="auto">Do you launch in 1st or 2nd?</p>
]]></description><link>https://wibimmers.com/post/106409</link><guid isPermaLink="true">https://wibimmers.com/post/106409</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Wed, 10 Jun 2020 10:40:23 GMT</pubDate></item><item><title><![CDATA[Reply to Congrats! on Wed, 10 Jun 2020 03:35:21 GMT]]></title><description><![CDATA[<p dir="auto">As I'm sure you're aware, getting fast and consistent 60-foot times will be imperative if you intend to get into the 9s. Just like in road racing, if you're not fast out of the corner, you're losing time the whole way down the straightaway. The car seems to hook up pretty well off the line, but there's no way you can make the most out of the available traction just with your left foot. The difference between a good launch and a bad one will be down to millimeters and 1/10ths of a second. I'm not recommending this solution per-se, but it is one way to take the variables out of your launch:</p>
]]></description><link>https://wibimmers.com/post/106407</link><guid isPermaLink="true">https://wibimmers.com/post/106407</guid><dc:creator><![CDATA[HipMF]]></dc:creator><pubDate>Wed, 10 Jun 2020 03:35:21 GMT</pubDate></item><item><title><![CDATA[Reply to Congrats! on Wed, 10 Jun 2020 01:13:43 GMT]]></title><description><![CDATA[<p dir="auto">Gotta give props where they're due. 10 second quarters is fast with any car, especially with a manual. Nice work.</p>
]]></description><link>https://wibimmers.com/post/106404</link><guid isPermaLink="true">https://wibimmers.com/post/106404</guid><dc:creator><![CDATA[HipMF]]></dc:creator><pubDate>Wed, 10 Jun 2020 01:13:43 GMT</pubDate></item><item><title><![CDATA[Reply to Congrats! on Tue, 09 Jun 2020 18:22:14 GMT]]></title><description><![CDATA[<p dir="auto">Thanks @B C! Still on a piggyback tune tho <img src="https://wibimmers.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f606.png?v=6c9209168ce" class="not-responsive emoji emoji-android emoji--laughing" style="height:23px;width:auto;vertical-align:middle" title=":laughing:" alt="😆" /></p>
<p dir="auto">Shooting for 9's by the end of the year. Will post more info in my build thread soon.</p>
]]></description><link>https://wibimmers.com/post/106396</link><guid isPermaLink="true">https://wibimmers.com/post/106396</guid><dc:creator><![CDATA[suspenceful]]></dc:creator><pubDate>Tue, 09 Jun 2020 18:22:14 GMT</pubDate></item><item><title><![CDATA[Reply to Congrats! on Tue, 09 Jun 2020 02:39:35 GMT]]></title><description><![CDATA[<p dir="auto">I guess I can FINALLY admit defeat and gracefully pass along my crown.  Congratulations!</p>
]]></description><link>https://wibimmers.com/post/106390</link><guid isPermaLink="true">https://wibimmers.com/post/106390</guid><dc:creator><![CDATA[patsbimmer1]]></dc:creator><pubDate>Tue, 09 Jun 2020 02:39:35 GMT</pubDate></item></channel></rss>
