  4. Build Thread: 2015 BMW M3 (Lots of Photos & Videos!)
45 Posts 12 Posters 846 Views 1 Watching
    I’m really glad you were able to make it out man. If you keep at it you will no doubt improve. Autox is by far the cheapest/safest way to comfortably push a car.
    I would try and keep 9/3 hand position on the wheel as much as possible. Avoid shuffle steering as the inputs tend to be jerky and can upset the car, I only overhand the wheel if it is super necessary on tight stuff. Line choice will get better with more seat time and definitely walk the course a few times. Looking ahead/through the corner towards the exit/apex whatever helped me a lot when I first started. Getting the car in the right position will help you not ruin the next 3 corners type of thing. I try to avoid “coasting” as much as possible. Either on throttle/braking/maintenance throttle. On RA Motorolex it’s super slick so I try not to be Hard on the brakes while doing large steering inputs.  For slaloms I usually ignore the first cone and try to make that a braking marker (depending on the course Obviously, but RA they can usually be ignored because the slalom “entrance” usually lines up with a corner exit)
    I am by no means in a position to instruct and still am a Certified noob as well, but that’s some of the stuff I have picked up on riding with people that are way faster than me.
    when they allow ride alongs, 100% get in someone’s car/grab an instructor
      Certified noob
      Can you be my Certified Noob coach when I start AutoXing myself? ❤️
        Kudos on getting out and enjoying your car. Did you drive with stability control on or off? ( I didnt get a chance to watch the whole video yet. There was 1 crash at my last visit to Blackhawk farms by a guy in an F80 that switched stability control off. The immense torque of those cars seems challenging to control.  If M-Dynamic mode is still a think its probably a good way to go especially as it provides understeer correction as well, not just oversteer.  On my E46 I didn't detect any stability control intervention with the more lenient ZCP/CSL  "M-Track mode" on.
        I drove with stability control on for the first couple laps. My friends convinced me to turn it off for the last couple laps, but you're right, it's a lot of immediate torque to try to control. I talk about it in the video, but the S55 power comes on so abruptly. It's almost like an on/off switch... all motor then tons of boost/torque. It's not very predictable until you get a ton of seat time. I can see why someone crashed with it off at Blackhawk.
        Well I'll be at Shawano this weekend to give it another shot! I'll definitely keep all of those tips in mind. Thanks for the insight.
        Sounds like they'll be allowing ride alongs on Sunday 😄
          You are probably already familiar with it as you are much more knowledgable about cameras, and video editing, but the Track Addict app and Race Render software are fun and can make for some valuable additions to video footage.
          http://racerender.com/TrackAddict/Features.html
          the Bluetooth OBD2 dongle I use on mine doesn’t really have an adequate sample rate but its the cheapest one and was really only made for diagnostics (Carista). Anyways, it syncs with gopro cameras which is cool
            I've been meaning to look into this more! Gonna have to check it out and see if I can get anything setup before auto-x on Sunday.
