  4. Neglected wood becomes speaker cabinet
28 Posts 7 Posters 557 Views 1 Watching
    check out this video...
    Finally got around to watching the whole thing. I don't think his test methodology really applies to the problem I usually have, except maybe test #2. He keeps working with the joints, pulling them apart, and then sticking them back together until they don't stick anymore. The issue I usually have is that I glue two pieces together, then glue on four more pieces, and then realize I need to go back and adjust the first joint and it won't budge regardless of the number of eff bombs or hammer blows that are applied to it. Most of my joints are in the snug to tight range which is why I say that test #2 is probably most relevant. Based on the strength tests from the Fine Woodworking article, I could probably just loosen up my joints and would get better working time and adequate strength, but that's really not my style, so I think next time I will give hide glue a try.
    Despite the fact that I have some gaps, I'm really not disappointed with the glue-up. Normally these kind of mistakes really irk me, but for some reason this time around it really doesn't bother me much.
    The best:
    The worst:
    Side view of "the worst":
    Back side:
    Not bad joinery for an amateur... Actually having access to the correct tools for the job really makes it easier than what I'm used to dealing with.
      that's a great job! i really like the mirrored grain on the back panel. and that 'worst' mitered corner is not bad at all. i like wood projects better when you can see signs that the craftsman is human. some carpenters who take it to a level of precision like they are building space ships for NASA.  I always leave mistakes and imperfections and i'm OK with it.
      i understand your problem now. the solution may be to glue less joints at a time, and ironically, keep using the fast setting glue. it also allows you to trim the pieces if necessary during the process.  woodworking is a test of patience. i have a set of small corner clamps for small projects like this that work great for 90 deg corners. https://www.amazon.com/Wolfcraft-3051000-Corner-Clamps-Pieces/dp/B001W7ARXK/ref=sr_1_46?keywords=corner+clamps&qid=1579063215&sr=8-46
        That face is awesome! I hope that it doesn't end up completely covered.
        Also, I fully expected you to be making these with a hand saw, hand planer, and some form of hand drill after having seen your car projects completed with basic tools!
          I have a couple project ideas that I intend to build completely by hand, but they're things I don't mind looking a little more crude. This project I was trying to have turn out all perfect like it was a NASA space ship or something. 😃 Anyway, I had to try out the fancy tools since they're just sitting there...
          Also, for future reference, saying "hand planer" is analogous, to calling records "vinyls". It's something young people do that makes us old people cringe a little bit. It's just a "plane". "Hand plane" is okay. "Hand planer" though... it's too much. I can't do it.
            but since I've cut my hand with a plane I think it it has become a "hand planer".
              I still think that would be a "hand plane", since "wood plane" sounds better than "wood planer". A "wood planer" sounds like the power tool version in my mind...
              The anguish languish is the cause of much suffering.
                Hit the nail on the head
                ^that is just me not want to admit being wrong
                Anyway, don't slice your hands with tools, though I do enjoy a nice red stain!
                  I don't know the word nerd terms, but I think the distinction is who's doing the work. If I use a plane, then I'm the planer, not the tool. If I stick a board in a machine and it does the planing for me, then it's the planer and I'm the planer operator.
                  I think in Dan's example the tool is a hand plane and he's a hand planer.
                  Words...
