<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[1993 e34 M5 *junk shell* with full drivetrain]]></title><description><![CDATA[<p dir="auto">Hey boys.</p>
<p dir="auto">Some of you remember a while back I purchased a barn find e34 M5, I parted it out to the point where nothing of value is really left exterior and interior wise. The car has rust, and lots of it. I wanted to sell my M3 and rebuild the car, but the shell is just too rusty. I live in an apartment and was a little in over my head about pulling the drivetrain, so I'm gonna try to sell the shell with the drivetrain in it in classic ChrisO fashion. Every body panel is rusted or dented except the hood.</p>
<p dir="auto">Cluster said 190k but the engine history is unknown if it's had work at any point.</p>
<p dir="auto">Here's whats left</p>
<ul>
<li>99.9% e34 M5 engine bay, has basically everything in it that it came with from the factory</li>
<li>S38B36 Engine</li>
<li>Full Wiring harness</li>
<li>S38B36 ECU</li>
<li>S38B36 5-speed transmission</li>
<li>e34 M5 driveshaft</li>
<li>92/93 Large case 3.73 LSD </li>
<li>e34 M5 steering box</li>
<li>Full front and rear suspension and subframes (SLS deleted)</li>
<li>e34 M5 sway bars</li>
<li>e34 M5 brake calipers</li>
<li>Full all original exhaust</li>
</ul>
<p dir="auto">The engine needs work, the two outer cylinders were 130psi, and the 4 inner cylinders were about 60-70psi completely dry and cold, thats really all I know, I didn't do any further testing. Engine turns over fine. No oil/coolant mix in the rad hoses. Borescope showed no chunks missing out of the pistons or anything.  When I pulled the valve cover gasket it had a nice creamy oil mix in the head. PO put new oil in it, so the oil on the dipstick is normal. A few things I've noticed, the cam pulse sensor is broken, intake boot is ripped, and every vacuum line is dry rotted.</p>
<p dir="auto">Hydraulic system is holding pressure and the clutch engages/ disengages, and the brakes work. </p>
<p dir="auto">Comes with keys and the car will still crank if a battery is in it</p>
<p dir="auto">Would be everything you'd need to do a full M5 drivetrain and suspension swap. Will roll onto a trailer. Comes on DS2 wheels.</p>
<p dir="auto"><strong>$2800 firm!</strong> </p>
<p dir="auto">Actually $2500 someone come get it, The trans and diff are worth that alone, make money off me!!</p>
<p dir="auto">If anyone wants additional info or pics just shoot me a message, and of course anyone is free to come check it out!</p>
<p dir="auto"><a href="/assets/uploads/files/monthly_2019_11_IMG_7632.JPG.abc5491f251a004c09983d2be32ec36e.JPG"><img src="/assets/uploads/files/monthly_2019_11_IMG_7632.thumb.JPG.e124c1178f539f180adb19b843ab8e67.JPG" alt="IMG7632.JPG" class=" img-fluid img-markdown" width="1000" height="750" /></a></p>
<p dir="auto"><a href="/assets/uploads/files/monthly_2019_11_IMG_7635.JPG.98384264557b94b63b259ce47d96afca.JPG"><img src="/assets/uploads/files/monthly_2019_11_IMG_7635.thumb.JPG.f33d8218cc9085ed70b4ea9cb000255d.JPG" alt="IMG7635.JPG" class=" img-fluid img-markdown" width="1000" height="750" /></a></p>
<p dir="auto"><a href="/assets/uploads/files/monthly_2019_11_IMG_7634.JPG.01a63f3bce5fcd2227d6ebb98345bbcd.JPG"><img src="/assets/uploads/files/monthly_2019_11_IMG_7634.thumb.JPG.354a2ddc7b8eba666ffe4539ba450169.JPG" alt="IMG7634.JPG" class=" img-fluid img-markdown" width="1000" height="750" /></a></p>
<p dir="auto"><a href="/assets/uploads/files/monthly_2019_11_IMG_7648.JPG.f77d667f6681677bbe626cc5f7381fba.JPG"><img src="/assets/uploads/files/monthly_2019_11_IMG_7648.thumb.JPG.9d69f06f90e5457ee918f2ecd89615cb.JPG" alt="IMG7648.JPG" class=" img-fluid img-markdown" width="1000" height="750" /></a></p>
<p dir="auto"><a href="/assets/uploads/files/monthly_2019_11_IMG_5696.JPG.d838c975144886215078c7ebede6fbbe.JPG"><img src="/assets/uploads/files/monthly_2019_11_IMG_5696.thumb.JPG.16ed80a5c77c975f61f3551feceb3fe1.JPG" alt="IMG5696.JPG" class=" img-fluid img-markdown" width="1000" height="750" /></a></p>
<p dir="auto"><a href="/assets/uploads/files/monthly_2019_11_IMG_5697.JPG.4d9bf699ba4efdb51cbcfa756d983634.JPG"><img src="/assets/uploads/files/monthly_2019_11_IMG_5697.thumb.JPG.808528d59244be9e53264a8d4aeee921.JPG" alt="IMG5697.JPG" class=" img-fluid img-markdown" width="1000" height="750" /></a></p>
<p dir="auto"><a href="/assets/uploads/files/monthly_2019_11_IMG_7643.JPG.518f8e230f8f9898e5796c43ef18b399.JPG"><img src="/assets/uploads/files/monthly_2019_11_IMG_7643.thumb.JPG.71722cf8f0ee242cd67633418f0827da.JPG" alt="IMG7643.JPG" class=" img-fluid img-markdown" width="1000" height="750" /></a></p>
<p dir="auto"><a href="/assets/uploads/files/monthly_2019_11_IMG_5469.JPG.2b6670a87cd4ae7cf19af2ddf5af4a64.JPG"><img src="/assets/uploads/files/monthly_2019_11_IMG_5469.thumb.JPG.1fc7c0bd461110072695d35237ee2aec.JPG" alt="IMG5469.JPG" class=" img-fluid img-markdown" width="1000" height="750" /></a></p>
<p dir="auto"><a href="/assets/uploads/files/monthly_2019_11_IMG_7646.JPG.a9746e5375c924c9fb50cf671260c97b.JPG"><img src="/assets/uploads/files/monthly_2019_11_IMG_7646.thumb.JPG.86423bfb26ce00f48e1bc18944dd2fea.JPG" alt="IMG7646.JPG" class=" img-fluid img-markdown" width="1000" height="750" /></a></p>
<p dir="auto"><a href="/assets/uploads/files/monthly_2019_11_1982897849_IMG_5698_1_.JPG.af32d4ebf0fce142f8ac74c10353225a.JPG"><img src="/assets/uploads/files/monthly_2019_11_1327185862_IMG_5698_1_.thumb.JPG.83ccb52509ca5a507881768a3d4e8989.JPG" alt="IMG5698 (1).JPG" class=" img-fluid img-markdown" width="1000" height="750" /></a></p>
<p dir="auto"><a href="/assets/uploads/files/monthly_2019_11_IMG_7653.JPG.608298ce0c47ad70f2a56b6b71af079a.JPG"><img src="/assets/uploads/files/monthly_2019_11_IMG_7653.thumb.JPG.358a4774c244fbf62e0c9db91f52fc0b.JPG" alt="IMG7653.JPG" class=" img-fluid img-markdown" width="1000" height="750" /></a></p>
<p dir="auto"><a href="/assets/uploads/files/monthly_2019_11_IMG_7654.JPG.6c8c1c01d58701a58b582e9afeb9809c.JPG"><img src="/assets/uploads/files/monthly_2019_11_IMG_7654.thumb.JPG.eb15abfe07dc0327ada2ee719850162a.JPG" alt="IMG7654.JPG" class=" img-fluid img-markdown" width="1000" height="750" /></a></p>
<p dir="auto"><a href="/assets/uploads/files/monthly_2019_11_IMG_7652.JPG.1f1e1e0b1d239f11362ea1ff0d4c7099.JPG"><img src="/assets/uploads/files/monthly_2019_11_IMG_7652.thumb.JPG.f3ddc14c9c7d79947b5405065d9086f7.JPG" alt="IMG7652.JPG" class=" img-fluid img-markdown" width="1000" height="750" /></a></p>
<p dir="auto"><a href="/assets/uploads/files/monthly_2019_11_IMG_7637.JPG.7ab3f6e9979980c0a0c540cdfe91bcec.JPG"><img src="/assets/uploads/files/monthly_2019_11_IMG_7637.thumb.JPG.072de8b4b9157fa894a4af7083966034.JPG" alt="IMG7637.JPG" class=" img-fluid img-markdown" width="1000" height="750" /></a></p>
<p dir="auto"><a href="/assets/uploads/files/monthly_2019_11_IMG_7645.JPG.434565aae0a61351dff698e105a7f36d.JPG"><img src="/assets/uploads/files/monthly_2019_11_IMG_7645.thumb.JPG.d9023c4eef06714fb148ddf626988ae7.JPG" alt="IMG7645.JPG" class=" img-fluid img-markdown" width="1000" height="750" /></a></p>
<p dir="auto"> <a href="/assets/uploads/files/monthly_2019_11_IMG_7638.JPG.8e73191257c7cdde9044fc1721286ed1.JPG"><img src="/assets/uploads/files/monthly_2019_11_IMG_7638.thumb.JPG.8ad9b53cf9bb2ae4a62a4ebc0ebec0b3.JPG" alt="IMG7638.JPG" class=" img-fluid img-markdown" width="1000" height="750" /></a></p>
<p dir="auto"><a href="/assets/uploads/files/monthly_2019_11_IMG_5321.JPG.01baa35b8f8806aab4668294c2d025f1.JPG"><img src="/assets/uploads/files/monthly_2019_11_IMG_5321.thumb.JPG.bc00661da7a32fe7b29b158606b8eb3b.JPG" alt="IMG5321.JPG" class=" img-fluid img-markdown" width="1000" height="750" /></a></p>
<p dir="auto"><a href="/assets/uploads/files/monthly_2019_11_IMG_6954.png.793834e095b53472a51cb0cf7486045f.png"><img src="/assets/uploads/files/monthly_2019_11_IMG_6954.thumb.png.df0e3a1f1d2516c75b063a89bc4e4a78.png" alt="IMG6954.png" class=" img-fluid img-markdown" width="422" height="750" /></a></p>
<p dir="auto"><a href="/assets/uploads/files/monthly_2019_11_IMG_6955.png.379a36fb69e567c656ac39a987a2a892.png"><img src="/assets/uploads/files/monthly_2019_11_IMG_6955.thumb.png.248becd1ecf134c490dc1c79baf3d516.png" alt="IMG6955.png" class=" img-fluid img-markdown" width="422" height="750" /></a></p>
<p dir="auto"><a href="/assets/uploads/files/monthly_2019_11_IMG_6956.png.cedd0ffe28889dd02c5a8a3ebe86796d.png"><img src="/assets/uploads/files/monthly_2019_11_IMG_6956.thumb.png.f6ab27a3180e6250438b28107d458a81.png" alt="IMG6956.png" class=" img-fluid img-markdown" width="422" height="750" /></a></p>
]]></description><link>https://wibimmers.com/topic/5784/1993-e34-m5-junk-shell-with-full-drivetrain</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 04:54:55 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/5784.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 30 Nov 2019 22:57:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 1993 e34 M5 *junk shell* with full drivetrain on Tue, 17 Mar 2020 20:46:31 GMT]]></title><description><![CDATA[<p dir="auto">Where yu located ? I am in Menasha WI,  send me a message 9203642373</p>
]]></description><link>https://wibimmers.com/post/104414</link><guid isPermaLink="true">https://wibimmers.com/post/104414</guid><dc:creator><![CDATA[Drgt5683]]></dc:creator><pubDate>Tue, 17 Mar 2020 20:46:31 GMT</pubDate></item><item><title><![CDATA[Reply to 1993 e34 M5 *junk shell* with full drivetrain on Mon, 02 Mar 2020 20:30:57 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/103845">Drgt5683 said:</a></strong></p>
<p dir="auto">Lmk if still intrested in the diff . I’m sure we can work something out , I will be primarily focused on engine for some time ..lots of work ahead </p>
<p dir="auto">Yes Still Interested in the diff.</p>
]]></description><link>https://wibimmers.com/post/104137</link><guid isPermaLink="true">https://wibimmers.com/post/104137</guid><dc:creator><![CDATA[ThatRatRodProject]]></dc:creator><pubDate>Mon, 02 Mar 2020 20:30:57 GMT</pubDate></item><item><title><![CDATA[Reply to 1993 e34 M5 *junk shell* with full drivetrain on Sun, 09 Feb 2020 12:50:47 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/103247">ThatRatRodProject said:</a></strong></p>
<p dir="auto">I am Very interested the diff if you pick this up.</p>
<p dir="auto">Lmk if still intrested in the diff . I’m sure we can work something out , I will be primarily focused on engine for some time ..lots of work ahead</p>
]]></description><link>https://wibimmers.com/post/103845</link><guid isPermaLink="true">https://wibimmers.com/post/103845</guid><dc:creator><![CDATA[Drgt5683]]></dc:creator><pubDate>Sun, 09 Feb 2020 12:50:47 GMT</pubDate></item><item><title><![CDATA[Reply to 1993 e34 M5 *junk shell* with full drivetrain on Sat, 01 Feb 2020 19:05:07 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/103766">straight6pwr said:</a></strong></p>
<p dir="auto">holy shit! start a new thread, we want to see this beast</p>
<p dir="auto">I second this. This is awesome.</p>
]]></description><link>https://wibimmers.com/post/103773</link><guid isPermaLink="true">https://wibimmers.com/post/103773</guid><dc:creator><![CDATA[Rekpoint]]></dc:creator><pubDate>Sat, 01 Feb 2020 19:05:07 GMT</pubDate></item><item><title><![CDATA[Reply to 1993 e34 M5 *junk shell* with full drivetrain on Sat, 01 Feb 2020 13:55:30 GMT]]></title><description><![CDATA[<p dir="auto">holy shit! start a new thread, we want to see this beast</p>
]]></description><link>https://wibimmers.com/post/103766</link><guid isPermaLink="true">https://wibimmers.com/post/103766</guid><dc:creator><![CDATA[straight6pwr]]></dc:creator><pubDate>Sat, 01 Feb 2020 13:55:30 GMT</pubDate></item><item><title><![CDATA[Reply to 1993 e34 M5 *junk shell* with full drivetrain on Sat, 01 Feb 2020 13:13:32 GMT]]></title><description><![CDATA[<p dir="auto">Thanks to wibimmers for existing or I wouldn’t be building my dream engine ., as long as I continued to search ,I knew someday I’d find.</p>
<p dir="auto">project s38 build begins !🤮<img src="https://wibimmers.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f911.png?v=6c9209168ce" class="not-responsive emoji emoji-android emoji--money_mouth_face" style="height:23px;width:auto;vertical-align:middle" title="🤑" alt="🤑" /></p>
<p dir="auto"><a href="/assets/uploads/files/monthly_2020_02_5E372BE1-E30F-4645-B02B-E2CB8A171671.jpeg.3ab77c545b17f2ab1f4ccfb01fcec7dc.jpeg"><img src="/assets/uploads/files/monthly_2020_02_5E372BE1-E30F-4645-B02B-E2CB8A171671.thumb.jpeg.2c06b4e6fd469d3eb0a690dc688789ff.jpeg" alt="5E372BE1-E30F-4645-B02B-E2CB8A171671.jpeg" class=" img-fluid img-markdown" width="563" height="750" /></a></p>
<p dir="auto"><a href="/assets/uploads/files/monthly_2020_02_76CEB924-A636-4EB4-9297-03FC4715375D.jpeg.a45ca9433e61942550fb77f4168716e4.jpeg"><img src="/assets/uploads/files/monthly_2020_02_76CEB924-A636-4EB4-9297-03FC4715375D.thumb.jpeg.ea0acf57e3eec2d84e7cf32dd71239b2.jpeg" alt="76CEB924-A636-4EB4-9297-03FC4715375D.jpeg" class=" img-fluid img-markdown" width="563" height="750" /></a></p>
]]></description><link>https://wibimmers.com/post/103765</link><guid isPermaLink="true">https://wibimmers.com/post/103765</guid><dc:creator><![CDATA[Drgt5683]]></dc:creator><pubDate>Sat, 01 Feb 2020 13:13:32 GMT</pubDate></item><item><title><![CDATA[Reply to 1993 e34 M5 *junk shell* with full drivetrain on Mon, 30 Dec 2019 23:31:48 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/103237">Drgt5683 said:</a></strong></p>
<p dir="auto">Where you located ?? I can set this up for pick up exc , need my number to call me lmk?</p>
<p dir="auto">Located in Eau Claire, WI. Go ahead and shoot me a text and we can talk more?</p>
<p dir="auto">920-471-6321</p>
]]></description><link>https://wibimmers.com/post/103268</link><guid isPermaLink="true">https://wibimmers.com/post/103268</guid><dc:creator><![CDATA[ChrisO]]></dc:creator><pubDate>Mon, 30 Dec 2019 23:31:48 GMT</pubDate></item><item><title><![CDATA[Reply to 1993 e34 M5 *junk shell* with full drivetrain on Mon, 30 Dec 2019 04:21:40 GMT]]></title><description><![CDATA[<blockquote>
]]></description><link>https://wibimmers.com/post/103247</link><guid isPermaLink="true">https://wibimmers.com/post/103247</guid><dc:creator><![CDATA[ThatRatRodProject]]></dc:creator><pubDate>Mon, 30 Dec 2019 04:21:40 GMT</pubDate></item><item><title><![CDATA[Reply to 1993 e34 M5 *junk shell* with full drivetrain on Sat, 28 Dec 2019 23:00:36 GMT]]></title><description><![CDATA[<p dir="auto">Where you located ?? I can set this up for pick up exc , need my number to call me lmk?</p>
]]></description><link>https://wibimmers.com/post/103237</link><guid isPermaLink="true">https://wibimmers.com/post/103237</guid><dc:creator><![CDATA[Drgt5683]]></dc:creator><pubDate>Sat, 28 Dec 2019 23:00:36 GMT</pubDate></item><item><title><![CDATA[Reply to 1993 e34 M5 *junk shell* with full drivetrain on Sat, 28 Dec 2019 19:04:32 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/103222">Drgt5683 said:</a></strong></p>
<p dir="auto">This still available I would love to absolutely take the engine and drivetrain !!??</p>
<p dir="auto">Still available! Take it all and you can sell the diff to <a class="plugin-mentions-user plugin-mentions-a" href="/user/thatratrodproject" aria-label="Profile: ThatRatRodProject">@<bdi>ThatRatRodProject</bdi></a></p>
]]></description><link>https://wibimmers.com/post/103233</link><guid isPermaLink="true">https://wibimmers.com/post/103233</guid><dc:creator><![CDATA[ChrisO]]></dc:creator><pubDate>Sat, 28 Dec 2019 19:04:32 GMT</pubDate></item><item><title><![CDATA[Reply to 1993 e34 M5 *junk shell* with full drivetrain on Fri, 27 Dec 2019 03:06:58 GMT]]></title><description><![CDATA[<p dir="auto">This still available I would love to absolutely take the engine and drivetrain !!??</p>
]]></description><link>https://wibimmers.com/post/103222</link><guid isPermaLink="true">https://wibimmers.com/post/103222</guid><dc:creator><![CDATA[Drgt5683]]></dc:creator><pubDate>Fri, 27 Dec 2019 03:06:58 GMT</pubDate></item><item><title><![CDATA[Reply to 1993 e34 M5 *junk shell* with full drivetrain on Fri, 20 Dec 2019 14:28:12 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/103142">HipMF said:</a></strong></p>
<p dir="auto">Buy it and part it out? You'll get the diff for free and probably make some money on top of that as well.</p>
<p dir="auto">Very tempting. I just need room for it. I have a full shop. Might have to try and sell a car.</p>
]]></description><link>https://wibimmers.com/post/103153</link><guid isPermaLink="true">https://wibimmers.com/post/103153</guid><dc:creator><![CDATA[ThatRatRodProject]]></dc:creator><pubDate>Fri, 20 Dec 2019 14:28:12 GMT</pubDate></item><item><title><![CDATA[Reply to 1993 e34 M5 *junk shell* with full drivetrain on Thu, 19 Dec 2019 19:28:38 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">True shit</p>
]]></description><link>https://wibimmers.com/post/103143</link><guid isPermaLink="true">https://wibimmers.com/post/103143</guid><dc:creator><![CDATA[Rekpoint]]></dc:creator><pubDate>Thu, 19 Dec 2019 19:28:38 GMT</pubDate></item><item><title><![CDATA[Reply to 1993 e34 M5 *junk shell* with full drivetrain on Thu, 19 Dec 2019 19:13:56 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/103141">ThatRatRodProject said:</a></strong></p>
<p dir="auto">If you ever turn this Into a part out. I will buy the diff in a heart beat. </p>
]]></description><link>https://wibimmers.com/post/103142</link><guid isPermaLink="true">https://wibimmers.com/post/103142</guid><dc:creator><![CDATA[HipMF]]></dc:creator><pubDate>Thu, 19 Dec 2019 19:13:56 GMT</pubDate></item><item><title><![CDATA[Reply to 1993 e34 M5 *junk shell* with full drivetrain on Thu, 19 Dec 2019 18:25:21 GMT]]></title><description><![CDATA[<p dir="auto">If you ever turn this Into a part out. I will buy the diff in a heart beat.</p>
]]></description><link>https://wibimmers.com/post/103141</link><guid isPermaLink="true">https://wibimmers.com/post/103141</guid><dc:creator><![CDATA[ThatRatRodProject]]></dc:creator><pubDate>Thu, 19 Dec 2019 18:25:21 GMT</pubDate></item><item><title><![CDATA[Reply to 1993 e34 M5 *junk shell* with full drivetrain on Mon, 02 Dec 2019 21:22:27 GMT]]></title><description><![CDATA[<p dir="auto">GLWS!! Thats a good price.</p>
]]></description><link>https://wibimmers.com/post/102946</link><guid isPermaLink="true">https://wibimmers.com/post/102946</guid><dc:creator><![CDATA[Jdesign]]></dc:creator><pubDate>Mon, 02 Dec 2019 21:22:27 GMT</pubDate></item><item><title><![CDATA[Reply to 1993 e34 M5 *junk shell* with full drivetrain on Sun, 01 Dec 2019 04:55:55 GMT]]></title><description><![CDATA[<p dir="auto">Finally !</p>
]]></description><link>https://wibimmers.com/post/102937</link><guid isPermaLink="true">https://wibimmers.com/post/102937</guid><dc:creator><![CDATA[Rekpoint]]></dc:creator><pubDate>Sun, 01 Dec 2019 04:55:55 GMT</pubDate></item><item><title><![CDATA[Reply to 1993 e34 M5 *junk shell* with full drivetrain on Sun, 01 Dec 2019 02:11:55 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/102934">SteelBlue said:</a></strong></p>
<p dir="auto">Can you have AAA send it to my shop?</p>
<p dir="auto">Lmfao we can work something out, new year, 1 long distance tow left 🥴</p>
]]></description><link>https://wibimmers.com/post/102935</link><guid isPermaLink="true">https://wibimmers.com/post/102935</guid><dc:creator><![CDATA[ChrisO]]></dc:creator><pubDate>Sun, 01 Dec 2019 02:11:55 GMT</pubDate></item><item><title><![CDATA[Reply to 1993 e34 M5 *junk shell* with full drivetrain on Sun, 01 Dec 2019 01:24:04 GMT]]></title><description><![CDATA[<p dir="auto">Can you have AAA send it to my shop?</p>
]]></description><link>https://wibimmers.com/post/102934</link><guid isPermaLink="true">https://wibimmers.com/post/102934</guid><dc:creator><![CDATA[SteelBlue]]></dc:creator><pubDate>Sun, 01 Dec 2019 01:24:04 GMT</pubDate></item></channel></rss>
