<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[A few things to pass on]]></title><description><![CDATA[<p dir="auto">A few things I am in no longer need of.</p>
<p dir="auto">The things I list below here have just about 3500 miles on them that I had used in my NA s52 swap.</p>
<p dir="auto">95a Revshift polyurethane E30 Sub frame bushings... $45</p>
<p dir="auto">Selling because my car is lower then stock and therefore needed the modified bushings to lift the rear subframe and fix some of the negative camber. They have only been trimmed down on the one side to make room for a wrench for the eccentric adjusters. Still in awesome shape and ride very comfortably!</p>
<p dir="auto"><a href="/assets/uploads/files/monthly_2019_04_20190216_150433.jpg.8da9dfdd3e2c38afe7477c180890ddcb.jpg"><img src="/assets/uploads/files/monthly_2019_04_20190216_150433.thumb.jpg.50f235813397e020cd742f35cef88468.jpg" alt="20190216150433.jpg" class=" img-fluid img-markdown" width="1000" height="750" /></a></p>
<p dir="auto">OBD1 413 Red label ECU with TRM performance chip... $150 (Chip alone was $250 brand new)</p>
<p dir="auto">Chip specs:</p>
<p dir="auto">OBD1 S52</p>
<p dir="auto">21 lb injectors</p>
<p dir="auto">91 octane</p>
<p dir="auto">Stock MAF</p>
<p dir="auto">7k rev limiter</p>
<p dir="auto">Stock Cam</p>
<p dir="auto">LTW Flywheel</p>
<p dir="auto"><a href="/assets/uploads/files/monthly_2019_04_20190216_150548.jpg.0a237393991fe1244fbe240314161a36.jpg"><img src="/assets/uploads/files/monthly_2019_04_20190216_150548.thumb.jpg.efcdd3d20c95f27cdff198e65db5ab82.jpg" alt="20190216150548.jpg" class=" img-fluid img-markdown" width="1000" height="750" /></a></p>
<p dir="auto">Now for the things that are not from the 3500 mile group.</p>
<p dir="auto">M50 valve covers... $15 each <strong>(1 left)</strong></p>
<p dir="auto"><a href="/assets/uploads/files/monthly_2019_04_20190418_174003.jpg.4d64aaa608f468d6d4a05f7b098b557f.jpg"><img src="/assets/uploads/files/monthly_2019_04_20190418_174003.thumb.jpg.1c3a36e574a43456be700f38a673c306.jpg" alt="20190418174003.jpg" class=" img-fluid img-markdown" width="1000" height="750" /></a></p>
<p dir="auto">S52 oil filter housing... $25</p>
<p dir="auto">Went with the S54 filter housing for the oil cooler setup. Has been bead blasted. Unfortunately ran into a small issue with bimmerworld's faulty sending unit distribution block banjo bolt being to short which had ended up pulling a few threads when I removed it to install their revised one that was longer to avoid that issue. New bolt still threaded in and was able to be torqued to spec, never had any leaks.</p>
<p dir="auto"><a href="/assets/uploads/files/monthly_2019_04_20190418_174108.jpg.eddfd6878c80336ef41dafcad5cf8f38.jpg"><img src="/assets/uploads/files/monthly_2019_04_20190418_174108.thumb.jpg.150c2d82d88042afe648f2c33e420431.jpg" alt="20190418174108.jpg" class=" img-fluid img-markdown" width="1000" height="750" /></a></p>
<p dir="auto"><a href="/assets/uploads/files/monthly_2019_04_20190418_174123.jpg.92089f651f4d9e6380146a8be589280e.jpg"><img src="/assets/uploads/files/monthly_2019_04_20190418_174123.thumb.jpg.f4b785aed9ec119b8d9c405594cb0d77.jpg" alt="20190418174123.jpg" class=" img-fluid img-markdown" width="563" height="750" /></a></p>
<p dir="auto">U.S. E30 Grills... $25</p>
<p dir="auto"><a href="/assets/uploads/files/monthly_2019_04_20190418_174318.jpg.a35589e2df1542f80850acd44385e580.jpg"><img src="/assets/uploads/files/monthly_2019_04_20190418_174318.thumb.jpg.b01f8a047a151cb5d469fdada83cbbef.jpg" alt="20190418174318.jpg" class=" img-fluid img-markdown" width="1000" height="750" /></a></p>
<p dir="auto">E30 Windshield Washer reservoir with pump... $15</p>
<p dir="auto"><a href="/assets/uploads/files/monthly_2019_04_20190418_174024.jpg.18f9e9f6c25b554120f53102bf0b3cac.jpg"><img src="/assets/uploads/files/monthly_2019_04_20190418_174024.thumb.jpg.a1a7e5f70786b50f4a3c223931ca0060.jpg" alt="20190418174024.jpg" class=" img-fluid img-markdown" width="1000" height="750" /></a></p>
<p dir="auto">Let me know what you need!</p>
]]></description><link>https://wibimmers.com/topic/5599/a-few-things-to-pass-on</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 04:53:56 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/5599.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 19 Apr 2019 13:29:18 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to A few things to pass on on Tue, 14 May 2019 00:50:46 GMT]]></title><description><![CDATA[<p dir="auto">Bump. ECU bracket and intake boot sold!</p>
]]></description><link>https://wibimmers.com/post/99500</link><guid isPermaLink="true">https://wibimmers.com/post/99500</guid><dc:creator><![CDATA[AsparagusMike]]></dc:creator><pubDate>Tue, 14 May 2019 00:50:46 GMT</pubDate></item><item><title><![CDATA[Reply to A few things to pass on on Wed, 24 Apr 2019 14:41:02 GMT]]></title><description><![CDATA[<p dir="auto">Might be interested in the ECU bracket and intake boot.</p>
]]></description><link>https://wibimmers.com/post/99092</link><guid isPermaLink="true">https://wibimmers.com/post/99092</guid><dc:creator><![CDATA[SteelBlue]]></dc:creator><pubDate>Wed, 24 Apr 2019 14:41:02 GMT</pubDate></item><item><title><![CDATA[Reply to A few things to pass on on Wed, 24 Apr 2019 05:20:59 GMT]]></title><description><![CDATA[<p dir="auto">Bump</p>
]]></description><link>https://wibimmers.com/post/99082</link><guid isPermaLink="true">https://wibimmers.com/post/99082</guid><dc:creator><![CDATA[AsparagusMike]]></dc:creator><pubDate>Wed, 24 Apr 2019 05:20:59 GMT</pubDate></item></channel></rss>
