<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[E30 - Upgrading injectors / tune]]></title><description><![CDATA[<p dir="auto">I am looking to upgrade my E30 from a performance prospect w/o getting too crazy. Based on previous thread conversations its sounds like a Mark D chip w/19lb injectors is the way to go. Late last year I swapped out the ECU for a 173 so should be all set to get started. This is where I need a little help. I cant seem to find the injectors I need. What else do I need to purchase for the injector swap?</p>
<p dir="auto">Planned Tune: <a href="http://www3.sympatico.ca/mdsylva/products.htm" rel="nofollow ugc">http://www3.sympatico.ca/mdsylva/products.htm</a> (91 octane, 6900 RPM, 19lb injector)</p>
<p dir="auto">Car: 1988 325i convertible</p>
<p dir="auto">Car thread:</p>
]]></description><link>https://wibimmers.com/topic/5564/e30-upgrading-injectors-tune</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 06:36:18 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/5564.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 07 Mar 2019 16:27:28 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to E30 - Upgrading injectors / tune on Thu, 07 Mar 2019 22:02:44 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/97917">snap said:</a></strong></p>
<p dir="auto"><a href="http://maksinjection.com/?product=bosch-0280-155-746-19-injectors-set-of-6" rel="nofollow ugc">http://maksinjection.com/?product=bosch-0280-155-746-19-injectors-set-of-6</a></p>
<p dir="auto">There are a few different injectors that would, I have run about 7 different types of injectors and for an M20 with chip tune, these are the best.</p>
<p dir="auto">﻿﻿ maksinjection can be mediocre in communication or product quality. ive dealt with them on 4 or so occasions. I have had injectors they have serviced that were stuck open. They replaced them but at times they were difficult to contact. </p>
<p dir="auto">﻿﻿ Ultimately﻿ they are cheap and worth﻿ the gamble.﻿</p>
<p dir="auto">﻿ Otherwise search for Bosch 0280 155 746 injectors on Ebay and see if you can find a matched set from a reputable shop like <a href="http://injector-rehab.com" rel="nofollow ugc">injector-rehab.com</a> or others</p>
<p dir="auto">﻿ This is all a good upgrade but you will get used to the power pretty shortly and need more. </p>
<p dir="auto">Thanks @snap . Agreed on the power problem, at some point I switch to the E39 M5 when speed, handling, and power are craved. That being said the E30 is still my most entertaining car.</p>
]]></description><link>https://wibimmers.com/post/97922</link><guid isPermaLink="true">https://wibimmers.com/post/97922</guid><dc:creator><![CDATA[vbhargava]]></dc:creator><pubDate>Thu, 07 Mar 2019 22:02:44 GMT</pubDate></item><item><title><![CDATA[Reply to E30 - Upgrading injectors / tune on Thu, 07 Mar 2019 17:21:51 GMT]]></title><description><![CDATA[<p dir="auto"><a href="http://maksinjection.com/?product=bosch-0280-155-746-19-injectors-set-of-6" rel="nofollow ugc">http://maksinjection.com/?product=bosch-0280-155-746-19-injectors-set-of-6</a></p>
<p dir="auto">maksinjection can be mediocre in communication or product quality. ive dealt with them on 4 or so occasions. I have had injectors they have serviced that were stuck open. They replaced them but at times they were difficult to contact. </p>
<p dir="auto">Ultimately they are cheap and worth the gamble.</p>
<p dir="auto">Otherwise search for Bosch 0280 155 746 injectors on Ebay and see if you can find a matched set from a reputable shop like <a href="http://injector-rehab.com" rel="nofollow ugc">injector-rehab.com</a> or others</p>
<p dir="auto">This is all a good upgrade but you will get used to the power pretty shortly and need more.</p>
]]></description><link>https://wibimmers.com/post/97917</link><guid isPermaLink="true">https://wibimmers.com/post/97917</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Thu, 07 Mar 2019 17:21:51 GMT</pubDate></item></channel></rss>
