<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[m20 flywheels and clutches]]></title><description><![CDATA[<p dir="auto">I thought this would be simple, but the internet can't seem to come to a consensus about this one.</p>
<p dir="auto">Looking for a single-mass m20 flywheel and clutch. ECS Tuning and Pelican Parts both can't seem to decide what part number is what, or which one comes from which application.</p>
<p dir="auto">Don't really care if it's OEM or aftermarket, but I'm looking for light-ish flywheel and clutch to hold ~250 ft-lbs that will give stock-ish feel without rattle.</p>
<p dir="auto">Please help.</p>
<p dir="auto"><img src="https://i.imgur.com/g0VZAd6.png" alt="g0VZAd6.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://wibimmers.com/topic/5465/m20-flywheels-and-clutches</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 06:33:35 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/5465.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 12 Nov 2018 01:58:02 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to m20 flywheels and clutches on Tue, 05 Mar 2019 02:21:36 GMT]]></title><description><![CDATA[<p dir="auto">Ended up ordering the M20 RHD flywheel.</p>
<p dir="auto">It looks like the solution to the clutch conundrum comes from an S14, although ECS still can't seem to decide whether the disc is sprung or not...</p>
<p dir="auto"><img src="https://i.imgur.com/OKlAKkj.png" alt="OKlAKkj.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Edit: I guess it should be noted here that, according to the internet, the M20 flywheel, clutch and throwout bearing stack is slightly shorter than the M42 setup, which is why the longer e21 323i throwout bearing is normally required. Aaaaand the ring gear is different, which requires an M20 starter. Once I have everything in-hand I intend to assemble it all on the bench to make sure everything lines up between the stock M42 stuff and my hodge-podge setup.</p>
]]></description><link>https://wibimmers.com/post/97888</link><guid isPermaLink="true">https://wibimmers.com/post/97888</guid><dc:creator><![CDATA[HipMF]]></dc:creator><pubDate>Tue, 05 Mar 2019 02:21:36 GMT</pubDate></item><item><title><![CDATA[Reply to m20 flywheels and clutches on Tue, 13 Nov 2018 04:59:09 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/95801">m42b32 said:</a></strong></p>
<p dir="auto">For flywheels, RHD engineering makes what looks like a really nice steel flywheel for a good price. I believe <a class="plugin-mentions-user plugin-mentions-a" href="/user/matty" aria-label="Profile: MattY">@<bdi>MattY</bdi></a> has an M20 specific one he is going to put in his car so he could give some feedback on quality. They make one for the M42 that allows you to keep the stock starter and uses an M20 clutch disk/pressure plate.</p>
<p dir="auto"><a href="http://racehead.com.au/products-page/engine-components/bmw-light-flywheel-m50-m52-m42-m44/" rel="nofollow ugc">http://racehead.com.au/products-page/engine-components/bmw-light-flywheel-m50-m52-m42-m44/</a></p>
<p dir="auto">It's shiny <img src="https://wibimmers.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f602.png?v=6c9209168ce" class="not-responsive emoji emoji-android emoji--joy" style="height:23px;width:auto;vertical-align:middle" title="😂" alt="😂" /> we'll be installing it soonish but car isnt close to drivable</p>
]]></description><link>https://wibimmers.com/post/95822</link><guid isPermaLink="true">https://wibimmers.com/post/95822</guid><dc:creator><![CDATA[YoungCR]]></dc:creator><pubDate>Tue, 13 Nov 2018 04:59:09 GMT</pubDate></item><item><title><![CDATA[Reply to m20 flywheels and clutches on Mon, 12 Nov 2018 19:20:20 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">RHD engineering makes what looks like a really nice steel flywheel for a good price.</p>
<p dir="auto">I saw those, and the price seems astonishingly low considering the work that must go into making them. It's still an option, but I was actually worried it would be too light and cause trans rattle at idle. Not the worst problem to have, but I'd still like to avoid it if possible.</p>
]]></description><link>https://wibimmers.com/post/95804</link><guid isPermaLink="true">https://wibimmers.com/post/95804</guid><dc:creator><![CDATA[HipMF]]></dc:creator><pubDate>Mon, 12 Nov 2018 19:20:20 GMT</pubDate></item><item><title><![CDATA[Reply to m20 flywheels and clutches on Mon, 12 Nov 2018 18:27:43 GMT]]></title><description><![CDATA[<p dir="auto">For flywheels, RHD engineering makes what looks like a really nice steel flywheel for a good price. I believe <a class="plugin-mentions-user plugin-mentions-a" href="/user/matty" aria-label="Profile: MattY">@<bdi>MattY</bdi></a> has an M20 specific one he is going to put in his car so he could give some feedback on quality. They make one for the M42 that allows you to keep the stock starter and uses an M20 clutch disk/pressure plate.</p>
]]></description><link>https://wibimmers.com/post/95801</link><guid isPermaLink="true">https://wibimmers.com/post/95801</guid><dc:creator><![CDATA[m42b32]]></dc:creator><pubDate>Mon, 12 Nov 2018 18:27:43 GMT</pubDate></item><item><title><![CDATA[Reply to m20 flywheels and clutches on Mon, 12 Nov 2018 18:18:31 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/95794">Earl said:</a></strong></p>
<p dir="auto">It should all be in my build thread.</p>
<p dir="auto">That thread is 70 pages long <img src="https://wibimmers.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f612.png?v=6c9209168ce" class="not-responsive emoji emoji-android emoji--unamused" style="height:23px;width:auto;vertical-align:middle" title="😒" alt="😒" /></p>
<p dir="auto">I would just look up the part number for the flywheel on realoem, but I'd have to know what year/model to look at, and there is a lot of conflicting information about which cars were single-mass...</p>
<p dir="auto">Also, finish your car.</p>
<p dir="auto">Thanks.</p>
]]></description><link>https://wibimmers.com/post/95799</link><guid isPermaLink="true">https://wibimmers.com/post/95799</guid><dc:creator><![CDATA[HipMF]]></dc:creator><pubDate>Mon, 12 Nov 2018 18:18:31 GMT</pubDate></item><item><title><![CDATA[Reply to m20 flywheels and clutches on Mon, 12 Nov 2018 16:13:35 GMT]]></title><description><![CDATA[<p dir="auto">Assuming you want this for your m42? I did a lightened stock m20 single mass for my nice car and had to use an e21 323 throwout bearing I believe. It should all be in my build thread. Otherwise valeo and a few people make single mass setups that you could get lightened</p>
]]></description><link>https://wibimmers.com/post/95794</link><guid isPermaLink="true">https://wibimmers.com/post/95794</guid><dc:creator><![CDATA[Earl]]></dc:creator><pubDate>Mon, 12 Nov 2018 16:13:35 GMT</pubDate></item></channel></rss>
