<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[e46 water pump recommendations]]></title><description><![CDATA[<p dir="auto">I have to replace my thermostat on the 330i and considering what to put on the "while I'm in there" list. For those that have replaced a water pump on an e46 any brand recommendations or warnings on which brands to avoid?</p>
]]></description><link>https://wibimmers.com/topic/5457/e46-water-pump-recommendations</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 05:51:12 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/5457.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 29 Oct 2018 15:20:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to e46 water pump recommendations on Fri, 09 Nov 2018 16:14:00 GMT]]></title><description><![CDATA[<p dir="auto">Went ahead and ordered the Saleri along with everything else for a full refresh. Boxes of parts are here. Now just have to find the time to do it.</p>
]]></description><link>https://wibimmers.com/post/95758</link><guid isPermaLink="true">https://wibimmers.com/post/95758</guid><dc:creator><![CDATA[Boris3]]></dc:creator><pubDate>Fri, 09 Nov 2018 16:14:00 GMT</pubDate></item><item><title><![CDATA[Reply to e46 water pump recommendations on Fri, 09 Nov 2018 15:02:12 GMT]]></title><description><![CDATA[<p dir="auto">I have seen both metal and composite ones fail. Besides that 99% of those were not my car and the owners always opted for the cheap replacement. ¯\_(ツ)_/¯</p>
<p dir="auto">I used a Saleri brand pump in my personal vehicle and never had a problem.</p>
]]></description><link>https://wibimmers.com/post/95750</link><guid isPermaLink="true">https://wibimmers.com/post/95750</guid><dc:creator><![CDATA[Jdesign]]></dc:creator><pubDate>Fri, 09 Nov 2018 15:02:12 GMT</pubDate></item><item><title><![CDATA[Reply to e46 water pump recommendations on Mon, 29 Oct 2018 21:32:59 GMT]]></title><description><![CDATA[<p dir="auto">Nice pump! $166 at BW compared to the close to $200 elsewhere. Would likely do this if tracking the e46.</p>
]]></description><link>https://wibimmers.com/post/95536</link><guid isPermaLink="true">https://wibimmers.com/post/95536</guid><dc:creator><![CDATA[Boris3]]></dc:creator><pubDate>Mon, 29 Oct 2018 21:32:59 GMT</pubDate></item><item><title><![CDATA[Reply to e46 water pump recommendations on Mon, 29 Oct 2018 19:49:42 GMT]]></title><description><![CDATA[<p dir="auto">They are a lot more money, around 200$, for a Stewart brand one.  I have bought a couple and they are really excellent.</p>
<p dir="auto"><a href="http://www.stewartwaterpumps.com/" rel="nofollow ugc">http://www.stewartwaterpumps.com/</a></p>
]]></description><link>https://wibimmers.com/post/95531</link><guid isPermaLink="true">https://wibimmers.com/post/95531</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Mon, 29 Oct 2018 19:49:42 GMT</pubDate></item><item><title><![CDATA[Reply to e46 water pump recommendations on Mon, 29 Oct 2018 17:59:55 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/95525">Boris3 said:</a></strong></p>
<p dir="auto">Thanks. Typically replace the pulley as well?</p>
<p dir="auto">I'm not totally sure on replacing them, though I don't think you need to replace it if it isn't damaged or anything (I haven't heard of failures, though I could be wrong on that). I replaced mine with ECS's aluminum pulley since the one that came with my motor was damaged, it certainly couldn't hurt.</p>
]]></description><link>https://wibimmers.com/post/95530</link><guid isPermaLink="true">https://wibimmers.com/post/95530</guid><dc:creator><![CDATA[m42b32]]></dc:creator><pubDate>Mon, 29 Oct 2018 17:59:55 GMT</pubDate></item><item><title><![CDATA[Reply to e46 water pump recommendations on Mon, 29 Oct 2018 16:20:43 GMT]]></title><description><![CDATA[<p dir="auto">Thanks. Typically replace the pulley as well?</p>
]]></description><link>https://wibimmers.com/post/95525</link><guid isPermaLink="true">https://wibimmers.com/post/95525</guid><dc:creator><![CDATA[Boris3]]></dc:creator><pubDate>Mon, 29 Oct 2018 16:20:43 GMT</pubDate></item><item><title><![CDATA[Reply to e46 water pump recommendations on Mon, 29 Oct 2018 15:36:08 GMT]]></title><description><![CDATA[<p dir="auto">I have been using the Saleri water pumps with composite propellers as they are the OEM supplier for the BMW pumps. The bearings are likely higher quality than a lot of the other aftermarket pumps and the composite impellers don't have the problems that the old plastic impellers did. They actually sound metallic if you tap on them. I put one in my e36 m3 when I redid the cooling system and had zero issues for 35k miles before I sold it. I put one on the M54 going into the e30 as well, though it hasn't done anything yet.</p>
]]></description><link>https://wibimmers.com/post/95521</link><guid isPermaLink="true">https://wibimmers.com/post/95521</guid><dc:creator><![CDATA[m42b32]]></dc:creator><pubDate>Mon, 29 Oct 2018 15:36:08 GMT</pubDate></item></channel></rss>
