<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA['86 M20B27 engine and accessories from swap]]></title><description><![CDATA[<p dir="auto">*** Everything is sold ***</p>
<p dir="auto">Thank you!</p>
<p dir="auto">Doing an s52 swap, so this clean well maintained and complete 86 325e drivetrain is for sale. Approx 200k miles.</p>
<p dir="auto">Recent work done in the last 1k miles:<br />
- Timing Belt<br />
- Water pump<br />
- Valve adjustment <br />
- Spark plugs <br />
- Coolant change <br />
- New oil pan, gasket and oil 20w50<br />
- Pan also has return line fitting installed for future turbo drain. </p>
<p dir="auto">Parts available:<br />
-m20 2.7 engine complete with all accessories, AFM, Ecu and harness</p>
<p dir="auto">-g260 5 speed transmission and shifter</p>
<p dir="auto">-5 speed driveshaft w/new center bearing</p>
<p dir="auto">-Full exhaust with stainless magnaflow muffler</p>
<p dir="auto">-Steering rack</p>
<p dir="auto">-Brake booster </p>
<p dir="auto">$300 for everything. I can help load the engine into your vehicle. Feel free to ask any questions.</p>
<p dir="auto">Blake Minson is doing the swap for me, and has the parts at his shop in Belvidere, Illinois (Rockford area) </p>
<p dir="auto">(815) 980-9663    <a href="https://rockford.craigslist.org/pts/d/bmw-e30-m20-27-engine-5-speed/6722488531.html" rel="nofollow ugc">https://rockford.craigslist.org/pts/d/bmw-e30-m20-27-engine-5-speed/6722488531.html</a></p>
<p dir="auto">Thanks!</p>
<p dir="auto">-Tim</p>
]]></description><link>https://wibimmers.com/topic/5444/86-m20b27-engine-and-accessories-from-swap</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 07:25:19 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/5444.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 16 Oct 2018 18:52:43 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to '86 M20B27 engine and accessories from swap on Mon, 22 Oct 2018 14:17:59 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/95362">gilber33 said:</a></strong></p>
<p dir="auto">So swap transmission and driveshaft and my shift assembly and all is good? </p>
<p dir="auto">Yeah, it's the whole package which is pretty slick.<br />
Well worth the $300!</p>
]]></description><link>https://wibimmers.com/post/95392</link><guid isPermaLink="true">https://wibimmers.com/post/95392</guid><dc:creator><![CDATA[GunMetalGrey]]></dc:creator><pubDate>Mon, 22 Oct 2018 14:17:59 GMT</pubDate></item><item><title><![CDATA[Reply to '86 M20B27 engine and accessories from swap on Fri, 19 Oct 2018 22:22:44 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/95357">GunMetalGrey said:</a></strong></p>
<p dir="auto">Not the case unfortunately. <br />
325e chassis use a large flange guibo and subsequently a large flange driveshaft. <br />
You will either need to get an adapter guibo (small bolt circle for driveshaft, large B.C. for trans) or switch the driveshaft.</p>
<p dir="auto">But it looks like he is also selling the driveshaft that was in the car, so if you grab both you're good to go!</p>
<p dir="auto">So swap transmission and driveshaft and my shift assembly and all is good?</p>
]]></description><link>https://wibimmers.com/post/95362</link><guid isPermaLink="true">https://wibimmers.com/post/95362</guid><dc:creator><![CDATA[gilber33]]></dc:creator><pubDate>Fri, 19 Oct 2018 22:22:44 GMT</pubDate></item><item><title><![CDATA[Reply to '86 M20B27 engine and accessories from swap on Fri, 19 Oct 2018 16:55:20 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/95354">jc43089 said:</a></strong></p>
<p dir="auto">Same transmission, <strong>no different parts required</strong>.  Getrag G260</p>
]]></description><link>https://wibimmers.com/post/95357</link><guid isPermaLink="true">https://wibimmers.com/post/95357</guid><dc:creator><![CDATA[GunMetalGrey]]></dc:creator><pubDate>Fri, 19 Oct 2018 16:55:20 GMT</pubDate></item><item><title><![CDATA[Reply to '86 M20B27 engine and accessories from swap on Fri, 19 Oct 2018 14:29:37 GMT]]></title><description><![CDATA[<p dir="auto">Same transmission, no different parts required.  Getrag G260</p>
]]></description><link>https://wibimmers.com/post/95354</link><guid isPermaLink="true">https://wibimmers.com/post/95354</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Fri, 19 Oct 2018 14:29:37 GMT</pubDate></item><item><title><![CDATA[Reply to '86 M20B27 engine and accessories from swap on Fri, 19 Oct 2018 13:14:56 GMT]]></title><description><![CDATA[<p dir="auto">Would that transmission bolt up to an 89 i M20B25? </p>
<p dir="auto">I've read they're all pretty interchangeable, just a matter of selecting the right clutch, driveshaft, etc.</p>
]]></description><link>https://wibimmers.com/post/95352</link><guid isPermaLink="true">https://wibimmers.com/post/95352</guid><dc:creator><![CDATA[gilber33]]></dc:creator><pubDate>Fri, 19 Oct 2018 13:14:56 GMT</pubDate></item><item><title><![CDATA[Reply to '86 M20B27 engine and accessories from swap on Thu, 18 Oct 2018 13:38:23 GMT]]></title><description><![CDATA[<p dir="auto">Good deal. GLWS</p>
]]></description><link>https://wibimmers.com/post/95327</link><guid isPermaLink="true">https://wibimmers.com/post/95327</guid><dc:creator><![CDATA[Jdesign]]></dc:creator><pubDate>Thu, 18 Oct 2018 13:38:23 GMT</pubDate></item></channel></rss>
