<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[E36 ZF Transmission output shaft flange torque spec]]></title><description><![CDATA[<p dir="auto">Does anyone know what this is supposed to be? I have searched and have not gotten much of a clear answer on this.</p>
]]></description><link>https://wibimmers.com/topic/5396/e36-zf-transmission-output-shaft-flange-torque-spec</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 04:01:29 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/5396.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 03 Sep 2018 23:55:04 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to E36 ZF Transmission output shaft flange torque spec on Tue, 04 Sep 2018 18:07:12 GMT]]></title><description><![CDATA[<p dir="auto">Yes, I have since learned the 2 stage torque procedure and have not had another failure.</p>
]]></description><link>https://wibimmers.com/post/94276</link><guid isPermaLink="true">https://wibimmers.com/post/94276</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Tue, 04 Sep 2018 18:07:12 GMT</pubDate></item><item><title><![CDATA[Reply to E36 ZF Transmission output shaft flange torque spec on Tue, 04 Sep 2018 12:40:58 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/94267">straight6pwr said:</a></strong></p>
<p dir="auto">From the e34 bentley, which specifies one torque spec for the range of manual transmissions, even though ZF and Getrag were used. I highlighted the specs in red below. </p>
<p dir="auto">Output shaft oil seal, replacing<br />
(transmission installed)</p>
<p dir="auto">1. Remove complete exhaust system. See 180 Exhaust<br />
System.</p>
<p dir="auto">2. Disconnect driveshaft from transmission. See 260<br />
Driveshaft.</p>
<p dir="auto">3. Remove output shaft flange.<br />
• Bend back and remove nut lockplate. See Fig. 2.<br />
• Hold flange steady and remove the collar nut (use 30<br />
mm thin-walled . deep socket).<br />
• Remove flange. If necessary. use a puller.</p>
<p dir="auto">4. Using a seal remover or screwdriver. pry out old seal.<br />
Lubricate new seal with oil and drive into place.</p>
<p dir="auto">CAUTION DO not damage the transmission case housing<br />
when prying out the old seal.A damagedcase can<br />
result in oil leaks.</p>
<p dir="auto">5. Reinstall flange to output shaft (and shims. if applicable).<br />
Coat bearing surface of collar nut with sealer and<br />
install nul.</p>
<p dir="auto">NOTE -<br />
• BMW recommends the use of a sealer such as Loctite<br />
242 when installing the collar nut to prevent oil<br />
from leaking past the threaded shaft.</p>
<p dir="auto">• On Getrag S5D 250 G transmission. BMW recommends<br />
heating the output flange to about 176'F to aid in installation.</p>
<p dir="auto">6. Tighten collar nut in two stages. Install new lockplate.<br />
Bend tabs into flange grooves.<br />
lightening Torques</p>
<p dir="auto">• Output flange to output shaft<br />
stage I 190 Nm (140 ft-Ib)<br />
stage II (after loosening) 120 Nm (89 fl-Ib)</p>
<p dir="auto">The two stage tightening is what I have read before as well, so I think this is what I will need to do.</p>
<p dir="auto"><strong><a href="/post/94268">jc43089 said:</a></strong></p>
<p dir="auto">If you over tighten it I found out that the transmission case will explode and lock up eventually.  Typically this will happen when your wife is driving with her mom to get their hair done before your sister-in-law's wedding.</p>
<p dir="auto">It always happens at the most convenient times.</p>
]]></description><link>https://wibimmers.com/post/94272</link><guid isPermaLink="true">https://wibimmers.com/post/94272</guid><dc:creator><![CDATA[SteelBlue]]></dc:creator><pubDate>Tue, 04 Sep 2018 12:40:58 GMT</pubDate></item><item><title><![CDATA[Reply to E36 ZF Transmission output shaft flange torque spec on Tue, 04 Sep 2018 12:16:04 GMT]]></title><description><![CDATA[<p dir="auto">If you over tighten it I found out that the transmission case will explode and lock up eventually.  Typically this will happen when your wife is driving with her mom to get their hair done before your sister-in-law's wedding.</p>
]]></description><link>https://wibimmers.com/post/94268</link><guid isPermaLink="true">https://wibimmers.com/post/94268</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Tue, 04 Sep 2018 12:16:04 GMT</pubDate></item><item><title><![CDATA[Reply to E36 ZF Transmission output shaft flange torque spec on Tue, 04 Sep 2018 05:32:57 GMT]]></title><description><![CDATA[<p dir="auto">From the e34 bentley, which specifies one torque spec for the range of manual transmissions, even though ZF and Getrag were used. I highlighted the specs in red below. </p>
System.</p>
Driveshaft.</p>
install nul.</p>
]]></description><link>https://wibimmers.com/post/94267</link><guid isPermaLink="true">https://wibimmers.com/post/94267</guid><dc:creator><![CDATA[straight6pwr]]></dc:creator><pubDate>Tue, 04 Sep 2018 05:32:57 GMT</pubDate></item><item><title><![CDATA[Reply to E36 ZF Transmission output shaft flange torque spec on Tue, 04 Sep 2018 02:53:27 GMT]]></title><description><![CDATA[<p dir="auto">This should be listed in a e36 Bentley.</p>
]]></description><link>https://wibimmers.com/post/94266</link><guid isPermaLink="true">https://wibimmers.com/post/94266</guid><dc:creator><![CDATA[YoungCR]]></dc:creator><pubDate>Tue, 04 Sep 2018 02:53:27 GMT</pubDate></item></channel></rss>
