<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[E30 front strut mounts]]></title><description><![CDATA[<p dir="auto">Hi all. I recently replaced my front upper strut mounts on the e30. I seem to have worse vibration after the install than before. </p>
<p dir="auto">Are they directional in any way? I thought they could only go in one way with the way the bolts line up to the holes, but I guess I'm not positive. I noticed the notch out of the metal but didn't pay attention to its direction when I pulled the old ones. </p>
<p dir="auto">Thanks for the help</p>
]]></description><link>https://wibimmers.com/topic/5378/e30-front-strut-mounts</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 04:00:48 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/5378.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 16 Aug 2018 20:28:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to E30 front strut mounts on Thu, 16 Aug 2018 21:33:43 GMT]]></title><description><![CDATA[<p dir="auto">E30 strut mounts are the same part number for left and right, and the bolt pattern only allows them to be installed one way from what I remember. When does the vibration occur and is it random? A failing strut mount usually knocks over bumps as the bearing or rubber wears out, or becomes notchy while turning the wheel back and forth. Its possible that a new/stiffer mount is transferring more of the vibration from something else in the suspension compared to the old mount?</p>
]]></description><link>https://wibimmers.com/post/93945</link><guid isPermaLink="true">https://wibimmers.com/post/93945</guid><dc:creator><![CDATA[m42b32]]></dc:creator><pubDate>Thu, 16 Aug 2018 21:33:43 GMT</pubDate></item></channel></rss>
