<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Looking to rent RTAB tool]]></title><description><![CDATA[<p dir="auto">Looking to rent a RTAB tool if anyone has one laying around, hoping to stay within an hour of Green Bay</p>
]]></description><link>https://wibimmers.com/topic/5370/looking-to-rent-rtab-tool</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 07:41:53 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/5370.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 15 Aug 2018 00:17:17 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Looking to rent RTAB tool on Wed, 15 Aug 2018 07:45:54 GMT]]></title><description><![CDATA[<p dir="auto">​</p>
]]></description><link>https://wibimmers.com/post/93919</link><guid isPermaLink="true">https://wibimmers.com/post/93919</guid><dc:creator><![CDATA[Earl]]></dc:creator><pubDate>Wed, 15 Aug 2018 07:45:54 GMT</pubDate></item><item><title><![CDATA[Reply to Looking to rent RTAB tool on Wed, 15 Aug 2018 07:40:20 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/93911">ChrisO said:</a></strong></p>
<p dir="auto">Oh, I thought they were steel. I've seen people drill them out but I was thinking that it seemed horrible. I just don't want to cut into the trailing arm on accident</p>
<p dir="auto">I did mine caveman style and uses the drill bit to "saw" through the sleeve and it didn't hurt the arm at all. Just one of those things that you can do carefully. If you drill out enough rubber, you could also use a hammer and chisel to split the sleeve.</p>
]]></description><link>https://wibimmers.com/post/93918</link><guid isPermaLink="true">https://wibimmers.com/post/93918</guid><dc:creator><![CDATA[Earl]]></dc:creator><pubDate>Wed, 15 Aug 2018 07:40:20 GMT</pubDate></item><item><title><![CDATA[Reply to Looking to rent RTAB tool on Wed, 15 Aug 2018 00:57:24 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/93910">Earl said:</a></strong></p>
<p dir="auto">For an e36? The sleeves are aluminum so they come out fairly easily with a few drilled holes and some light Dremel work. If you're replacing with Poly you can usually grease them up and draw them in with a clamp </p>
]]></description><link>https://wibimmers.com/post/93911</link><guid isPermaLink="true">https://wibimmers.com/post/93911</guid><dc:creator><![CDATA[ChrisO]]></dc:creator><pubDate>Wed, 15 Aug 2018 00:57:24 GMT</pubDate></item><item><title><![CDATA[Reply to Looking to rent RTAB tool on Wed, 15 Aug 2018 00:50:16 GMT]]></title><description><![CDATA[<p dir="auto">For an e36? The sleeves are aluminum so they come out fairly easily with a few drilled holes and some light Dremel work. If you're replacing with Poly you can usually grease them up and draw them in with a clamp</p>
]]></description><link>https://wibimmers.com/post/93910</link><guid isPermaLink="true">https://wibimmers.com/post/93910</guid><dc:creator><![CDATA[Earl]]></dc:creator><pubDate>Wed, 15 Aug 2018 00:50:16 GMT</pubDate></item></channel></rss>
