<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[E30 Differential LSD]]></title><description><![CDATA[<p dir="auto">What are the different ratios for the E30 LSD diff. I have one here that looks like a 3:40</p>
]]></description><link>https://wibimmers.com/topic/537/e30-differential-lsd</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 05:42:14 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/537.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 17 Mar 2012 17:23:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to E30 Differential LSD on Sun, 18 Mar 2012 20:42:57 GMT]]></title><description><![CDATA[<p dir="auto">Yes, marked Input pinion and marked axel bearing to housing. And it lines up to around 3:40</p>
]]></description><link>https://wibimmers.com/post/6040</link><guid isPermaLink="true">https://wibimmers.com/post/6040</guid><dc:creator><![CDATA[Ted]]></dc:creator><pubDate>Sun, 18 Mar 2012 20:42:57 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Differential LSD on Sun, 18 Mar 2012 14:00:23 GMT]]></title><description><![CDATA[<p dir="auto">and you are sure its a 3.46? was the e30 owned by someone who upgraded it in the past?</p>
<p dir="auto">i couldnt say that all of the diffs from the e28 and e24 are compatible, i think some were large case and wouldnt work.</p>
]]></description><link>https://wibimmers.com/post/6037</link><guid isPermaLink="true">https://wibimmers.com/post/6037</guid><dc:creator><![CDATA[straight6pwr]]></dc:creator><pubDate>Sun, 18 Mar 2012 14:00:23 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Differential LSD on Sun, 18 Mar 2012 04:07:48 GMT]]></title><description><![CDATA[<p dir="auto">Therefore the diffs from the e24 and e28 are interchangeable with the E30. This one came out from a 1990 325is.</p>
]]></description><link>https://wibimmers.com/post/6035</link><guid isPermaLink="true">https://wibimmers.com/post/6035</guid><dc:creator><![CDATA[Ted]]></dc:creator><pubDate>Sun, 18 Mar 2012 04:07:48 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Differential LSD on Sun, 18 Mar 2012 03:00:47 GMT]]></title><description><![CDATA[<p dir="auto">the 3:46 diff didnt come with e30s. i think E24/E28s had them back in the day, and the newer ones from the z3/mcoupe are also compatible.</p>
]]></description><link>https://wibimmers.com/post/6033</link><guid isPermaLink="true">https://wibimmers.com/post/6033</guid><dc:creator><![CDATA[straight6pwr]]></dc:creator><pubDate>Sun, 18 Mar 2012 03:00:47 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Differential LSD on Sun, 18 Mar 2012 01:11:10 GMT]]></title><description><![CDATA[<p dir="auto">How much?</p>
]]></description><link>https://wibimmers.com/post/6031</link><guid isPermaLink="true">https://wibimmers.com/post/6031</guid><dc:creator><![CDATA[Earl]]></dc:creator><pubDate>Sun, 18 Mar 2012 01:11:10 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Differential LSD on Sat, 17 Mar 2012 23:53:55 GMT]]></title><description><![CDATA[<p dir="auto">^^^ i dont know <img src="/assets/uploads/files/emoticons_default_sad.png" alt=":(" class=" img-fluid img-markdown" width="20" height="20" /></p>
<p dir="auto">but earl i do have a 4.10 LSD that came off a z3...or z4 if you want to buy it. just sitting on my parts car.</p>
]]></description><link>https://wibimmers.com/post/6030</link><guid isPermaLink="true">https://wibimmers.com/post/6030</guid><dc:creator><![CDATA[mystere30]]></dc:creator><pubDate>Sat, 17 Mar 2012 23:53:55 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Differential LSD on Sat, 17 Mar 2012 22:24:04 GMT]]></title><description><![CDATA[<p dir="auto">Does any one know where a 3:45 LSD came from, which E30 models</p>
]]></description><link>https://wibimmers.com/post/6029</link><guid isPermaLink="true">https://wibimmers.com/post/6029</guid><dc:creator><![CDATA[Ted]]></dc:creator><pubDate>Sat, 17 Mar 2012 22:24:04 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Differential LSD on Sat, 17 Mar 2012 22:23:28 GMT]]></title><description><![CDATA[<p dir="auto">I have a 4:10 LSD E30</p>
]]></description><link>https://wibimmers.com/post/6028</link><guid isPermaLink="true">https://wibimmers.com/post/6028</guid><dc:creator><![CDATA[Ted]]></dc:creator><pubDate>Sat, 17 Mar 2012 22:23:28 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Differential LSD on Sat, 17 Mar 2012 22:20:00 GMT]]></title><description><![CDATA[<p dir="auto">4.45 LSD came from active sport TI's</p>
<p dir="auto">I need an LSD. I have an open 4.45</p>
<p dir="auto">I want a 4.10 or 4.27</p>
]]></description><link>https://wibimmers.com/post/6025</link><guid isPermaLink="true">https://wibimmers.com/post/6025</guid><dc:creator><![CDATA[Earl]]></dc:creator><pubDate>Sat, 17 Mar 2012 22:20:00 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Differential LSD on Sat, 17 Mar 2012 19:59:11 GMT]]></title><description><![CDATA[<p dir="auto">Tag is rusted. Got it from rotating the diff. What models carry this diff.</p>
]]></description><link>https://wibimmers.com/post/6022</link><guid isPermaLink="true">https://wibimmers.com/post/6022</guid><dc:creator><![CDATA[Ted]]></dc:creator><pubDate>Sat, 17 Mar 2012 19:59:11 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Differential LSD on Sat, 17 Mar 2012 18:22:16 GMT]]></title><description><![CDATA[<p dir="auto">where did you get this LSD? 3.40 is not a diff ratio, but the 3.46 is close. how did you determine that number, by the tag or by rotating the diff?</p>
<p dir="auto">heres the best list i could compile:</p>
<p dir="auto">e30 U.S. OE LSDs:</p>
<p dir="auto">2.93</p>
<p dir="auto">2.79</p>
<p dir="auto">3.73</p>
<p dir="auto">3.91</p>
<p dir="auto">4.10</p>
<p dir="auto">4.27</p>
<p dir="auto">4.45</p>
<p dir="auto">others (from other models/etc):</p>
<p dir="auto">3.46</p>
<p dir="auto">3.25</p>
<p dir="auto">on an unrelated note, how much fun would a 4.45 diff be? torque monster!</p>
]]></description><link>https://wibimmers.com/post/6019</link><guid isPermaLink="true">https://wibimmers.com/post/6019</guid><dc:creator><![CDATA[straight6pwr]]></dc:creator><pubDate>Sat, 17 Mar 2012 18:22:16 GMT</pubDate></item></channel></rss>
