<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[break in oils for fresh rebuild]]></title><description><![CDATA[<p dir="auto">I know there is a lot of info about this out there and I have done my fair share of reading so I mostly understand what I need. Sense many people on here have rebuilt motors from the bottom up and have good experience with such, I just wanted to know what type oil you ended up running for the first start up and break in periods. So far I have looked at some break in oils (which just seems to be sae 30 with zinc additives) and I also know not to run a synthetic based oil as it prevents the rings from seating properly. What has been used successfully on others builds?</p>
<p dir="auto">Thanks!</p>
]]></description><link>https://wibimmers.com/topic/5316/break-in-oils-for-fresh-rebuild</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 05:46:58 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/5316.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 10 Jun 2018 17:09:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to break in oils for fresh rebuild on Wed, 04 Jul 2018 15:26:11 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/92952">6inarowmakesitgo! said:</a></strong></p>
<p dir="auto">Make sure you use plenty of zddp with every oil change </p>
<p dir="auto">Is this only necessary tell I reach 5 or 6,000 miles when I switch over to synthetic?</p>
]]></description><link>https://wibimmers.com/post/93051</link><guid isPermaLink="true">https://wibimmers.com/post/93051</guid><dc:creator><![CDATA[AsparagusMike]]></dc:creator><pubDate>Wed, 04 Jul 2018 15:26:11 GMT</pubDate></item><item><title><![CDATA[Reply to break in oils for fresh rebuild on Sat, 30 Jun 2018 18:24:48 GMT]]></title><description><![CDATA[<p dir="auto">Make sure you use plenty of zddp with every oil change</p>
]]></description><link>https://wibimmers.com/post/92952</link><guid isPermaLink="true">https://wibimmers.com/post/92952</guid><dc:creator><![CDATA[6inarowmakesitgo]]></dc:creator><pubDate>Sat, 30 Jun 2018 18:24:48 GMT</pubDate></item><item><title><![CDATA[Reply to break in oils for fresh rebuild on Mon, 11 Jun 2018 22:58:48 GMT]]></title><description><![CDATA[<p dir="auto">I shot my machinist a message yesterday about it and he also recommended brad penn for initially breaking in the motor. Said he's used it in every fresh rebuilt motor he has built.</p>
<p dir="auto">Looks like we got a winner!</p>
<p dir="auto">As always thx for your feedback guys, very much appreciate it.</p>
]]></description><link>https://wibimmers.com/post/92441</link><guid isPermaLink="true">https://wibimmers.com/post/92441</guid><dc:creator><![CDATA[AsparagusMike]]></dc:creator><pubDate>Mon, 11 Jun 2018 22:58:48 GMT</pubDate></item><item><title><![CDATA[Reply to break in oils for fresh rebuild on Mon, 11 Jun 2018 19:53:13 GMT]]></title><description><![CDATA[<p dir="auto"><a href="https://www.amazon.com/Brad-Penn-Oil-009-7120S-Engine/dp/B002RF8IN2" rel="nofollow ugc">https://www.amazon.com/Brad-Penn-Oil-009-7120S-Engine/dp/B002RF8IN2</a></p>
<p dir="auto">The 2 engine builders ive talked to that do it for a living told me to use Brad Penn oil, start it up and run the engine at 2000 rpm for 15 minutes. Drain the oil, add normal oil and consider it broken in.</p>
<p dir="auto">Heres something a little more official than the passed-along tribal knowledge that can wind up being something like "My uncle Ted used to drag race in his high school parking lot and his friend said to add kerosene to the air filter and bounce it off the rev limiter for 10 hours straight to break it in"  </p>
<p dir="auto"><a href="http://static.summitracing.com/global/images/instructions/atk%20engine%20break%20in.pdf" rel="nofollow ugc">http://static.summitracing.com/global/images/instructions/atk engine break in.pdf</a></p>
]]></description><link>https://wibimmers.com/post/92437</link><guid isPermaLink="true">https://wibimmers.com/post/92437</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Mon, 11 Jun 2018 19:53:13 GMT</pubDate></item><item><title><![CDATA[Reply to break in oils for fresh rebuild on Mon, 11 Jun 2018 12:44:47 GMT]]></title><description><![CDATA[<p dir="auto">I've used Royal Purple break in oil, it is a non synthetic with good additives.  I used it just because I use their HPS oil typically.</p>
]]></description><link>https://wibimmers.com/post/92416</link><guid isPermaLink="true">https://wibimmers.com/post/92416</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Mon, 11 Jun 2018 12:44:47 GMT</pubDate></item></channel></rss>
