<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Emissions test]]></title><description><![CDATA[<p dir="auto">Random question...is there a way to pass emissions test without removing the catless downpipes? I currently have JB4. I've heard both yea and no.</p>
]]></description><link>https://wibimmers.com/topic/5234/emissions-test</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 06:44:42 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/5234.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 30 Mar 2018 02:23:54 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Emissions test on Fri, 30 Mar 2018 14:54:35 GMT]]></title><description><![CDATA[<p dir="auto">If you pick a county that doesn't emissions test you won't have to take it. You can change it at the DMV if your car isn't up for registration.</p>
<p dir="auto"><a href="/assets/uploads/files/monthly_2018_03_IMG_1784.GIF.86563e90c7f500762f57f5f8a3629c89.GIF"><img src="/assets/uploads/files/monthly_2018_03_IMG_1784.GIF.86563e90c7f500762f57f5f8a3629c89.GIF" alt="IMG1784.GIF" class=" img-fluid img-markdown" width="435" height="249" /></a></p>
]]></description><link>https://wibimmers.com/post/90013</link><guid isPermaLink="true">https://wibimmers.com/post/90013</guid><dc:creator><![CDATA[Daggerty]]></dc:creator><pubDate>Fri, 30 Mar 2018 14:54:35 GMT</pubDate></item><item><title><![CDATA[Reply to Emissions test on Fri, 30 Mar 2018 14:47:30 GMT]]></title><description><![CDATA[<p dir="auto">I just had to have my M3 tested a few weeks back.</p>
<p dir="auto">The Milwaukee area tests are only a scan, so if your car has a working CEL/it isn't throwing any codes that set it off, and the readiness monitors are showing ready/set (2001+ can't have more than 1 not set, '96-2000 can't have more than 2), you should be able to pass. If you have an OBD2 scanner you should be able to check these on your own.</p>
<p dir="auto">Here is some good info on pass criteria: <a href="http://www.wisconsinvip.org/wivippublic/pages/Content.aspx?ID=6" rel="nofollow ugc">http://www.wisconsinvip.org/wivippublic/pages/Content.aspx?ID=6</a></p>
]]></description><link>https://wibimmers.com/post/90011</link><guid isPermaLink="true">https://wibimmers.com/post/90011</guid><dc:creator><![CDATA[m42b32]]></dc:creator><pubDate>Fri, 30 Mar 2018 14:47:30 GMT</pubDate></item><item><title><![CDATA[Reply to Emissions test on Fri, 30 Mar 2018 14:01:40 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/89985">Gustavo said:</a></strong></p>
<p dir="auto">Random question...is there a way to pass emissions test without removing the catless downpipes? I currently have JB4. I've heard both yea and no. </p>
<p dir="auto">Based on the scan I did on your car i'd say you might be fine.  It didn't pull any emissions code when I scanned it and I don't think there is any sniffer test done anymore.  It's been awhile since I've had to get emissions testing done.</p>
]]></description><link>https://wibimmers.com/post/90003</link><guid isPermaLink="true">https://wibimmers.com/post/90003</guid><dc:creator><![CDATA[patsbimmer1]]></dc:creator><pubDate>Fri, 30 Mar 2018 14:01:40 GMT</pubDate></item></channel></rss>
