<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[E30 fixed camber plates]]></title><description><![CDATA[<p dir="auto">Anyone have experience with fixed camber plates on e30’s? I’d like to make the car handle a little better for next summer and minimize the extra wear I’m getting on the outside edge of the stickier tires I put on. Basically, anything to look out for, any good brands, advice?</p>
]]></description><link>https://wibimmers.com/topic/5190/e30-fixed-camber-plates</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 04:54:03 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/5190.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 22 Feb 2018 17:02:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to E30 fixed camber plates on Thu, 22 Feb 2018 17:32:09 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/88571">El Snapo said:</a></strong></p>
<p dir="auto">Dont forget offset control arm bushings. They increase dynamic camber change</p>
<p dir="auto">Those will also probably be in the cards eventually, but if I do the CABs I’m gonna refresh the entire front end, and I really don’t know if I have the time/energy/funds to do that this summer. I guess we’ll see haha.</p>
]]></description><link>https://wibimmers.com/post/88574</link><guid isPermaLink="true">https://wibimmers.com/post/88574</guid><dc:creator><![CDATA[P_Roloff]]></dc:creator><pubDate>Thu, 22 Feb 2018 17:32:09 GMT</pubDate></item><item><title><![CDATA[Reply to E30 fixed camber plates on Thu, 22 Feb 2018 17:28:39 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/88570">m42b32 said:</a></strong></p>
<p dir="auto">I have a set on my car. I like them, though I haven't driven my car without them installed to compare. Only downsides I've seen is that they will raise the front of the car by the thickness of the plate, and you likely won't be able to run e90 drop hats if you use them. Not sure what brand mine are as I got them with my suspension, but they're likely all pretty similar. They don't add a ton of camber, maybe around 1 degree, since you are limited by the diameter of the stock springs. If you can get a set fairly inexpensively, I'd say go for it. </p>
<p dir="auto">Gotcha. Yeah I’m gonna try to find some used if I can, although ill still probably pick up a set if I can’t. It looks like they’re around $130 at most places, and I can get up to around 1.25 degrees at most.</p>
]]></description><link>https://wibimmers.com/post/88573</link><guid isPermaLink="true">https://wibimmers.com/post/88573</guid><dc:creator><![CDATA[P_Roloff]]></dc:creator><pubDate>Thu, 22 Feb 2018 17:28:39 GMT</pubDate></item><item><title><![CDATA[Reply to E30 fixed camber plates on Thu, 22 Feb 2018 17:25:56 GMT]]></title><description><![CDATA[<p dir="auto">Dont forget offset control arm bushings. They increase dynamic camber change</p>
]]></description><link>https://wibimmers.com/post/88571</link><guid isPermaLink="true">https://wibimmers.com/post/88571</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Thu, 22 Feb 2018 17:25:56 GMT</pubDate></item><item><title><![CDATA[Reply to E30 fixed camber plates on Thu, 22 Feb 2018 17:13:07 GMT]]></title><description><![CDATA[<p dir="auto">I have a set on my car. I like them, though I haven't driven my car without them installed to compare. Only downsides I've seen is that they will raise the front of the car by the thickness of the plate, and you likely won't be able to run e90 drop hats if you use them. Not sure what brand mine are as I got them with my suspension, but they're likely all pretty similar. They don't add a ton of camber, maybe around 1 degree, since you are limited by the diameter of the stock springs. If you can get a set fairly inexpensively, I'd say go for it.</p>
]]></description><link>https://wibimmers.com/post/88570</link><guid isPermaLink="true">https://wibimmers.com/post/88570</guid><dc:creator><![CDATA[m42b32]]></dc:creator><pubDate>Thu, 22 Feb 2018 17:13:07 GMT</pubDate></item></channel></rss>
