  4. Re-engaging in the community!
45 Posts 15 Posters 716 Views 2 Watching
    Mods GTF in here
    @mods
    EDIT: I just realized it was already moved. Carry on gentlemen. Looking forward to progress and inpending compression test results
    • AJK430A
      AJK430A
      AJK430
      snap said:
      Mods GTF in here
      @mods
      Hahaha. Well i drove the car I pulled the engine out of.. Happened to do a few donuts on the way to the garage. Its strong.
      • AJK430A
        AJK430A
        AJK430
        Curious if anyone can help me identify these rear trailing arms by part number. Ive searched around and nothing comes up with this part number or any variation of it..
        They're thought to be off a 6 Cylinder Z3 for my 5 lug swap, I just want to confirm so I order the right bearings but nearly all of the trailing arm part numbers start with 333.
        These start with 385... if you drop the 7. Haha.
        The numbers end in 762 and 761 for right and left which is consistent with the other trailing arm part numbers ive found but nothing starting with 385... And those 7's look an awful lot like 1's...
        Im embarrassingly confused.
        Help PLEAAAAASE!
          Ouhhhf. Yeah IDK. Have you tried googleing or running the numbers in RealOEM?
            use the bearing opening in the trailing arm (or the existing bearing if its still in place) to figure this out. the 1.8 has a smaller bearing.
            z3 2.5 6cyl - Angular ball bearing 42mm x 75mm x 37mm
            z3 1.8 4cyl / 318ti - Angular ball bearing 39mm x 72mm x 37mm
            (inside diameter x outside diameter x depth)
