<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[E9 Racer Stuff]]></title><description><![CDATA[<p dir="auto"><a href="https://flic.kr/p/XDo4A6" rel="nofollow ugc" class="plugin-markdown-hidden-link small link-danger"></a></p>
<p dir="auto"><img src="https://farm5.staticflickr.com/4433/36522637125_e31a09bc77_b.jpg" alt="DSC4294" class=" img-fluid img-markdown" /></p>
<p dir="auto"><a href="https://flic.kr/p/XreXwX" rel="nofollow ugc" class="plugin-markdown-hidden-link small link-danger"></a></p>
<p dir="auto"><img src="https://farm5.staticflickr.com/4393/36385257911_b638639d70_b.jpg" alt="DSC4323" class=" img-fluid img-markdown" /></p>
<p dir="auto"><a href="https://flic.kr/p/XovF5f" rel="nofollow ugc" class="plugin-markdown-hidden-link small link-danger"></a></p>
<p dir="auto"><img src="https://farm5.staticflickr.com/4398/36354374842_4113f59678_b.jpg" alt="DSC4326" class=" img-fluid img-markdown" /></p>
<p dir="auto"><a href="https://flic.kr/p/Xzh3ZU" rel="nofollow ugc" class="plugin-markdown-hidden-link small link-danger"></a></p>
<p dir="auto"><img src="https://farm5.staticflickr.com/4331/36476198486_1acebbf524_b.jpg" alt="DSC4364" class=" img-fluid img-markdown" /></p>
<p dir="auto"><a href="https://flic.kr/p/Wu4G1j" rel="nofollow ugc" class="plugin-markdown-hidden-link small link-danger"></a></p>
<p dir="auto"><img src="https://farm5.staticflickr.com/4425/35760847274_c128c1e21c_b.jpg" alt="DSC5315" class=" img-fluid img-markdown" /></p>
<p dir="auto"><a href="https://flic.kr/p/XKUuBH" rel="nofollow ugc" class="plugin-markdown-hidden-link small link-danger"></a></p>
<p dir="auto"><img src="https://farm5.staticflickr.com/4357/36596473655_f0caebdd7f_b.jpg" alt="DSC5318" class=" img-fluid img-markdown" /></p>
<p dir="auto"><a href="https://flic.kr/p/Xzh1om" rel="nofollow ugc" class="plugin-markdown-hidden-link small link-danger"></a></p>
<p dir="auto"><img src="https://farm5.staticflickr.com/4376/36476189696_45467b439e_b.jpg" alt="DSC4385" class=" img-fluid img-markdown" /></p>
<p dir="auto"><a href="https://flic.kr/p/XFPazj" rel="nofollow ugc" class="plugin-markdown-hidden-link small link-danger"></a></p>
<p dir="auto"><img src="https://farm5.staticflickr.com/4430/36550168056_87f2992e0f_b.jpg" alt="DSC5017" class=" img-fluid img-markdown" /></p>
<p dir="auto"><a href="https://flic.kr/p/XDohHi" rel="nofollow ugc" class="plugin-markdown-hidden-link small link-danger"></a></p>
<p dir="auto"><img src="https://farm5.staticflickr.com/4381/36522681275_9641c0498c_b.jpg" alt="DSC4247" class=" img-fluid img-markdown" /></p>
<p dir="auto"><a href="https://flic.kr/p/X3m79w" rel="nofollow ugc">https://flic.kr/p/X3m79w</a></p>
<p dir="auto">But what I REALLY wanted to look at and talk about is THIS:</p>
<p dir="auto"><a href="https://flic.kr/p/X3kDVu" rel="nofollow ugc" class="plugin-markdown-hidden-link small link-danger"></a></p>
<p dir="auto"><img src="https://farm5.staticflickr.com/4434/36126089930_d7276b387d_b.jpg" alt="DSC4287" class=" img-fluid img-markdown" /></p>
<p dir="auto"><a href="https://flic.kr/p/XDoo4Z" rel="nofollow ugc" class="plugin-markdown-hidden-link small link-danger"></a></p>
<p dir="auto"><img src="https://farm5.staticflickr.com/4406/36522699295_76255f7715_b.jpg" alt="DSC4240" class=" img-fluid img-markdown" /></p>
<p dir="auto">The caption is “Check out the extra belts; it's like that so they don't have to remove an axle if the belt breaks. Just cut the old belt off and slide the new one on.”</p>
<p dir="auto">Clever!</p>
<p dir="auto">But what are we seeing here?!? An axle driven alternator?!?</p>
<p dir="auto">-Less voltage loss from shorter wire run: Yes</p>
<p dir="auto">-Lower weight from shorter wire run: Yes</p>
<p dir="auto">-Better weight distribution because trunk: Yes</p>
<p dir="auto">-Must drive above ___ MPH to keep the</p>
<p dir="auto">battery charges: Probably</p>
<p dir="auto">-Isnt a source of parasitic drag: No, it still is and always will be.</p>
<p dir="auto">Any thoughts or info on this kind of setup?</p>
<p dir="auto">I do see an additional belt for what looks like a diff oil pump. I like that idea if it is under-driven enough to where you are always getting some flow, but arent stressing the pump at top speed.</p>
<p dir="auto">There are also 2 electric pumps visible which I assume are fuel pumps</p>
]]></description><link>https://wibimmers.com/topic/5097/e9-racer-stuff</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 05:52:53 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/5097.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 30 Nov 2017 03:21:37 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to E9 Racer Stuff on Tue, 12 Dec 2017 19:43:34 GMT]]></title><description><![CDATA[<p dir="auto">This is blasphemy. So much interesting things going on. I love all of it. I have never seen anything like that alternator before.</p>
]]></description><link>https://wibimmers.com/post/86056</link><guid isPermaLink="true">https://wibimmers.com/post/86056</guid><dc:creator><![CDATA[Jdesign]]></dc:creator><pubDate>Tue, 12 Dec 2017 19:43:34 GMT</pubDate></item><item><title><![CDATA[Reply to E9 Racer Stuff on Fri, 01 Dec 2017 01:29:16 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/85627">Snap said:</a></strong></p>
<p dir="auto">-Must drive above ___ MPH to keep the battery charges: Probably</p>
<p dir="auto">Alternators use juice from the battery to drive the stator, which in turn causes current to flow in the field. Regulation occurs by changing the current through the stator. This way, the field current can be kept constant over a wide range of speeds. I don't have any actual data, but supposing that an alternator charges well enough between 800 and 8000 rpm, then it should work equally well between 20 and 200 mph.</p>
<p dir="auto">Stress on the pump would only be an issue if there is some restriction in the circuit causing back pressure. If the pump is low-volume, and the lines and cooler are a reasonable diameter, there would be very little pressure in the system. Probably only a few psi, but I guess that depends on fluid viscosity... Guess it all depends how much flow is required to keep the temperature down to an acceptable level...</p>
<p dir="auto"><strong><a href="/post/85646">GunMetalGrey said:</a></strong></p>
<p dir="auto">How often do these guys break alternator belts?</p>
<p dir="auto">If it breaks once and causes you to lose a race, then that's one too many times.</p>
<p dir="auto">It's interesting seeing a slide gate for the throttle plates compared to the standard butterfly setup.</p>
<p dir="auto">Flat slide carbs were once common in motorcycles. I guess the logic is that when the throttle is wide open there is no obstruction in the intake path like a butterfly, and the air path through the throttle can match the runners (ie be round) unlike a round slide carb which widens in that area when the slide is pulled away.</p>
]]></description><link>https://wibimmers.com/post/85684</link><guid isPermaLink="true">https://wibimmers.com/post/85684</guid><dc:creator><![CDATA[HipMF]]></dc:creator><pubDate>Fri, 01 Dec 2017 01:29:16 GMT</pubDate></item><item><title><![CDATA[Reply to E9 Racer Stuff on Thu, 30 Nov 2017 21:45:23 GMT]]></title><description><![CDATA[<p dir="auto">Bummed I didn't get to see the CSL running around RA this past year. Hopefully next year! Such a cool car</p>
]]></description><link>https://wibimmers.com/post/85675</link><guid isPermaLink="true">https://wibimmers.com/post/85675</guid><dc:creator><![CDATA[YoungCR]]></dc:creator><pubDate>Thu, 30 Nov 2017 21:45:23 GMT</pubDate></item><item><title><![CDATA[Reply to E9 Racer Stuff on Thu, 30 Nov 2017 15:27:24 GMT]]></title><description><![CDATA[<p dir="auto">There is a lot of weird stuff going on here. </p>
<p dir="auto">How often do these guys break alternator belts? </p>
<p dir="auto">How did I not know about the M49?</p>
]]></description><link>https://wibimmers.com/post/85646</link><guid isPermaLink="true">https://wibimmers.com/post/85646</guid><dc:creator><![CDATA[GunMetalGrey]]></dc:creator><pubDate>Thu, 30 Nov 2017 15:27:24 GMT</pubDate></item><item><title><![CDATA[Reply to E9 Racer Stuff on Thu, 30 Nov 2017 07:34:46 GMT]]></title><description><![CDATA[<p dir="auto">For tension adjustment</p>
]]></description><link>https://wibimmers.com/post/85638</link><guid isPermaLink="true">https://wibimmers.com/post/85638</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Thu, 30 Nov 2017 07:34:46 GMT</pubDate></item><item><title><![CDATA[Reply to E9 Racer Stuff on Thu, 30 Nov 2017 04:30:28 GMT]]></title><description><![CDATA[<p dir="auto">Are those heim joints holding the alt up?</p>
]]></description><link>https://wibimmers.com/post/85632</link><guid isPermaLink="true">https://wibimmers.com/post/85632</guid><dc:creator><![CDATA[patsbimmer1]]></dc:creator><pubDate>Thu, 30 Nov 2017 04:30:28 GMT</pubDate></item><item><title><![CDATA[Reply to E9 Racer Stuff on Thu, 30 Nov 2017 03:38:33 GMT]]></title><description><![CDATA[<p dir="auto">I believe this to be the same engine which is installed in that car</p>
<p dir="auto">Today I learned that the M49 is an engine. I always thought it was just the M88 and S38 that wore the trumpets in the early cars</p>
]]></description><link>https://wibimmers.com/post/85630</link><guid isPermaLink="true">https://wibimmers.com/post/85630</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Thu, 30 Nov 2017 03:38:33 GMT</pubDate></item><item><title><![CDATA[Reply to E9 Racer Stuff on Thu, 30 Nov 2017 03:26:10 GMT]]></title><description><![CDATA[<p dir="auto">And I jizzed in my pants...</p>
]]></description><link>https://wibimmers.com/post/85628</link><guid isPermaLink="true">https://wibimmers.com/post/85628</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Thu, 30 Nov 2017 03:26:10 GMT</pubDate></item></channel></rss>
