A purists nightmare - E46 drift build
How do you like the chassis mounted shifter? What engine mounts do you have?
I like it alot more than stock. Although I do wish I would have saved up for one with reverse lock out as I've tried shifting from 3rd to second on track and I cant seem to find it very well. But for $130 this shifter is awesome. And I have condor engine and trans mounts which I really like. Some do like them and some dont.
Got some parts in to repair the rear end situation. My auto 330 diff stubs along with both the axles I found in ebay showed up.
Unfortunately the driver side one (which has proven to be more difficult to find) isnt in the greatest of shape, it has some play but I guess we will she if she decides to leave the party at any point.
Going down to gurnee this weekend to pick up a 3.38 diff which should be fine although I would like to find another 3.46 as well. And I'll also be snagging another set of axles while i am down there as well.
Also have one more set of axles on the hook once i hear back about shipping from the guy
NO MORE BEING UN PREPARED!
In the mean time heres a few photos from in the rain at DD75
oooh tire sprayers. there were a lot of dirty windshields among the fwd crowd in high school.
looks like youre having a lot of fun, i love it!
Hahahah yes but these are not to help with burnouts or easier sliding lol just to help conserve tire life
UPDATE
Picked up the new diff last night along with some more auto 330 axles. The diff I picked up is a 3.38.
Unfortunately I found out that the threads on the axles are messed up and I cant for the life of me fix them and I've unfucked things like this before. I dont have a photo but it is what it is I suppose.
I was able to get the diff welded by a friend today as well and when I went to install one of the other spare axles I have I found out that the left wheel bearing is clapped out. So that needs to be replaced. Sucks because it was brand new when I built the car a year and a half ago but that's drifting! Haha
Heres a video of the wheel bearing. I'm really surprised I never heard any noises that indicated a bad bearing.
Always wondered how frequent whee bearing replacements would be with frequent track use. So far from those I have talked to its not frequent at all.
Skid Racing is a whole different story though im guessing
I dont think it's super common but who knows for sure haha I'm just glad I found it now rather than at the next event.
Thats bad. glad you caught it. sheesh.
Yea, I just dont understand how it wasmt making any noise.
update.
Some good news and some bad news.
Starting with the bad news, apparently I'm a dumbass and did a poor job dealing the new diff cover. Sooo out it needs to come again and be re-sealed.
The good news is my die came in to hopefully fix those 2 lower mileage axles that had fucked up threads.
AND IT WAS A SUCCESS
Thats a huge die LOL
was actually pretty cheap too haha. I did have to use a pipe wrench to turn it though I didn my have anything that went large enough at home. -
UPDATE.
Pulled both axles and the diff out last night. Which I'm starting to dislike how fast I can do it lmao. 15 minutes and all three parts were out, aside from jacking up the car.
So there are a few reasons for pulling all those out. Number 1 being that the diff needs to be resealed. Number 2 is that after I had gotten it up on stands again I was checking all the suspension and found that all 4 of the inner heims joints on my rear arms were worn and causing alot of play. So I ordered some new cheomoly ones from McMaster-carr. I also got those installed last night.
Now to add to the bad news, I originally put the car up on all 4 jackstands to solve the drivetrain clunking noise. And I found it.... the u joint has alot of play. Luckily I have a friend getting rid of a 330 driveshaft for cheap and it has a good u joint. While the rest of that driveshaft needs parts (csb and rear cv) I plan to swap the front half from the new driveshaft to my existing driveshaft which has a new csb from not long ago and a good rear cv.
Hopefully my plan works out....
Update.
Pulled apart 2 of my weds cerebus 2's to re lip them. I wish I could fit bigger lips but 1) I dont have the fender space and 2) I'd like to stay under a 10" wide wheel. So that being said I went from the original 2 inch lips to a 3 inch lip. What really kills me is the 6.5 inch barrels.
New on the left and original on the right.
And here's both completed.
Also pulled out my driveshaft.
My original one on the left and the one I picked up on the right.
The new to me driveshaft seems to have a better front half than my current one so my hope is that it will atleast last me for the rest of the season. The u-joint on my old one was really starting to make some noise.
And here is the 2 shafts made into one. I kept my original rear portion because the cv and the csb are still good.
Now I should be able to start putting the car back togeather!
hopefully the balance of those two unmatched driveshaft halves is acceptable!
It seemed to be driving at 40ish. We will see tonight as I will be headed up to shawano in a few hours.
