<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M54b30 from 530i into a 330i]]></title><description><![CDATA[<p dir="auto">Im failry new to the bmw scene and i just purchased a 2001 330i with an engine that decided to eat a cam. Intake cam on cyl 4,5 and 6 was completely dry and cracked the rear 2 cam caps. I picked up another m54b30 that was from a 530i. </p>
<p dir="auto">I know that I will need to swap over the oil pan from the 330i engine along with the engine mount brackets. Is there anything else that will need to be swapped over that I may have missed in my research? The intake manifold on the 530i engine has a positive battery post on it whereas the 330i does not and im guessing thats because its mounted on the passenger side of the engine bay. Will i need to swap the manifolds as well?</p>
<p dir="auto">Thanks in advance for any info!</p>
]]></description><link>https://wibimmers.com/topic/4901/m54b30-from-530i-into-a-330i</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 05:45:48 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/4901.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 22 Jun 2017 23:37:54 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M54b30 from 530i into a 330i on Thu, 22 Jun 2017 23:47:08 GMT]]></title><description><![CDATA[<p dir="auto">If you need to compare any part numbers check <a href="http://www.realoem.com" rel="nofollow ugc">www.realoem.com</a></p>
]]></description><link>https://wibimmers.com/post/80917</link><guid isPermaLink="true">https://wibimmers.com/post/80917</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Thu, 22 Jun 2017 23:47:08 GMT</pubDate></item></channel></rss>
