<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M20 scratched cylinder]]></title><description><![CDATA[<p dir="auto">Replacing a piston that was damage (likely due to running lean) found this vertical scratch in the cylinder wall. I know it's not ideal, but interested in others thoughts. We have already honed the cylinder, I wouldn't say a fingernail catches but you can feel it.<img src="https://uploads.tapatalk-cdn.com/20170617/a8c31925caba488873f52c96e6d56df9.jpg" alt="a8c31925caba488873f52c96e6d56df9.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">Sent from my Nexus 5X using Tapatalk</p>
]]></description><link>https://wibimmers.com/topic/4889/m20-scratched-cylinder</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 06:27:41 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/4889.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 17 Jun 2017 16:26:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M20 scratched cylinder on Sat, 17 Jun 2017 21:10:16 GMT]]></title><description><![CDATA[<p dir="auto">The "rule of thumb" my engine builder used was bore x .005 for upper compression ring and bore x .0055 for the lower compression ring which resulted in a cringeworthily small .016" and .018" gaps.</p>
<p dir="auto">First of all use a piece of broken ring to make sure you clean all the carbon out of the grooves thoroughly.</p>
<p dir="auto">Very important</p>
<p dir="auto">The stock ring end gap for a stock non-boosted engine is</p>
<p dir="auto">.012"-.020" upper</p>
<p dir="auto">and .012"-.020" lower.</p>
<p dir="auto">Some boosted V8 guys run .025" upper and lower gaps. The ring manufacturers will have some guidance as well</p>
<p dir="auto">Personally I would go 020" upper and .022 lower at minimum. It was the lower rings that were wrecked the most from the thermal expansion on my engine.</p>
<p dir="auto"><img src="https://uploads.tapatalk-cdn.com/20170617/fec94b0712260ac7df12f37455bfbb12.jpg" alt="fec94b0712260ac7df12f37455bfbb12.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://wibimmers.com/post/80708</link><guid isPermaLink="true">https://wibimmers.com/post/80708</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Sat, 17 Jun 2017 21:10:16 GMT</pubDate></item><item><title><![CDATA[Reply to M20 scratched cylinder on Sat, 17 Jun 2017 20:14:45 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/80705">Snap said:</a></strong></p>
<p dir="auto">It isnt ideal, but boring it out and getting oversized pistons is not a budget-friendly situation.</p>
<p dir="auto">I say run it for now and if it ends up it has a little to much oil consumption/blowby/too little compression then you can buy a used engine or build another one on the side and do everything right.</p>
<p dir="auto">Yeah I think that is going to be the plan, slap it together and see what happens. Any opinions on ring gap?</p>
]]></description><link>https://wibimmers.com/post/80706</link><guid isPermaLink="true">https://wibimmers.com/post/80706</guid><dc:creator><![CDATA[madbim]]></dc:creator><pubDate>Sat, 17 Jun 2017 20:14:45 GMT</pubDate></item><item><title><![CDATA[Reply to M20 scratched cylinder on Sat, 17 Jun 2017 19:50:43 GMT]]></title><description><![CDATA[<p dir="auto">It isnt ideal, but boring it out and getting oversized pistons is not a budget-friendly situation.</p>
]]></description><link>https://wibimmers.com/post/80705</link><guid isPermaLink="true">https://wibimmers.com/post/80705</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Sat, 17 Jun 2017 19:50:43 GMT</pubDate></item></channel></rss>
