<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Closure]]></title><description><![CDATA[<p dir="auto"><img src="https://uploads.tapatalk-cdn.com/20170610/1f0d2995ea673c7a0e92b1b9052d5ffc.jpg" alt="1f0d2995ea673c7a0e92b1b9052d5ffc.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="https://uploads.tapatalk-cdn.com/20170610/135c4f98a7b6e288b16c11c44cdd3101.jpg" alt="135c4f98a7b6e288b16c11c44cdd3101.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="https://uploads.tapatalk-cdn.com/20170610/73772774d1dcdc378ca5845dadc5e4e1.jpg" alt="73772774d1dcdc378ca5845dadc5e4e1.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="https://uploads.tapatalk-cdn.com/20170610/ea72c7725576821f6d4e7cd35d260f72.jpg" alt="ea72c7725576821f6d4e7cd35d260f72.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">I pulled the pistons from 5 and 6.</p>
<p dir="auto">The problems I had were never about head gaskets and they were never about tuning. It was all about ring gap(thermal expansion makes the ends touch, buckle, and break out the ringland).</p>
<p dir="auto">The smooth pieces were found in the recess by the wrist pin, so they had dropped out below the oil ring and got rock-tumbled between the cylinder wall and wrist-pin recess for some time.</p>
<p dir="auto">I had made sure the engine builder knew this was for a boosted application and he acknowledged it and told me "The rule of thumb is ___ " wider per psi. But after checking the build sheet, he had set the gap to stock size.</p>
<p dir="auto">Stock cast pistons don't help the situation at all, but they weren't the root cause here.</p>
<p dir="auto">If I ever do a boosted setup again I will definitely spring for forged pistons, and will set the ring gaps myself.</p>
]]></description><link>https://wibimmers.com/topic/4881/closure</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 04:53:12 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/4881.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 10 Jun 2017 18:43:23 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Closure on Fri, 16 Jun 2017 15:17:45 GMT]]></title><description><![CDATA[<p dir="auto">Should have just added some of this. Would have sealed it right up!</p>
<p dir="auto"><img src="https://shop.advanceautoparts.com/wcsstore/CVWEB/staticproductimage//N3286/large/7120013_brl_1100_pri_larg.jpg" alt="Image result for headgasket fix" class=" img-fluid img-markdown" />  </p>
<p dir="auto">But all jokes aside, Im glad you figured it out. Knowing what the actual problem was , and that it wasn't your fault is a nice piece of mind.</p>
]]></description><link>https://wibimmers.com/post/80677</link><guid isPermaLink="true">https://wibimmers.com/post/80677</guid><dc:creator><![CDATA[Jdesign]]></dc:creator><pubDate>Fri, 16 Jun 2017 15:17:45 GMT</pubDate></item><item><title><![CDATA[Reply to Closure on Mon, 12 Jun 2017 01:05:17 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/80557">Jeff said:</a></strong></p>
<p dir="auto">Jesus and it only smoked a little?</p>
<p dir="auto">Smoked like a Snoop Dogg concert on April 20th.</p>
<p dir="auto">When i limped it as slow as possible you could still see and smell a cloud of burned oil behind the car . Any sort of throttle left a solid lingering cloud</p>
]]></description><link>https://wibimmers.com/post/80558</link><guid isPermaLink="true">https://wibimmers.com/post/80558</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Mon, 12 Jun 2017 01:05:17 GMT</pubDate></item><item><title><![CDATA[Reply to Closure on Mon, 12 Jun 2017 00:49:14 GMT]]></title><description><![CDATA[<p dir="auto">Jesus and it only smoked a little?</p>
]]></description><link>https://wibimmers.com/post/80557</link><guid isPermaLink="true">https://wibimmers.com/post/80557</guid><dc:creator><![CDATA[Jeff]]></dc:creator><pubDate>Mon, 12 Jun 2017 00:49:14 GMT</pubDate></item><item><title><![CDATA[Reply to Closure on Sun, 11 Jun 2017 15:55:36 GMT]]></title><description><![CDATA[<p dir="auto">Ran it.</p>
<p dir="auto">now errbody in the hood has lung cancer</p>
]]></description><link>https://wibimmers.com/post/80554</link><guid isPermaLink="true">https://wibimmers.com/post/80554</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Sun, 11 Jun 2017 15:55:36 GMT</pubDate></item><item><title><![CDATA[Reply to Closure on Sun, 11 Jun 2017 14:11:40 GMT]]></title><description><![CDATA[<p dir="auto">run it</p>
]]></description><link>https://wibimmers.com/post/80553</link><guid isPermaLink="true">https://wibimmers.com/post/80553</guid><dc:creator><![CDATA[HipMF]]></dc:creator><pubDate>Sun, 11 Jun 2017 14:11:40 GMT</pubDate></item><item><title><![CDATA[Reply to Closure on Sun, 11 Jun 2017 04:28:46 GMT]]></title><description><![CDATA[<p dir="auto">Well that is damn impressive.</p>
]]></description><link>https://wibimmers.com/post/80549</link><guid isPermaLink="true">https://wibimmers.com/post/80549</guid><dc:creator><![CDATA[patsbimmer1]]></dc:creator><pubDate>Sun, 11 Jun 2017 04:28:46 GMT</pubDate></item><item><title><![CDATA[Reply to Closure on Sun, 11 Jun 2017 03:36:17 GMT]]></title><description><![CDATA[<p dir="auto">See this is why cx racing turbos are junk</p>
]]></description><link>https://wibimmers.com/post/80543</link><guid isPermaLink="true">https://wibimmers.com/post/80543</guid><dc:creator><![CDATA[Daggerty]]></dc:creator><pubDate>Sun, 11 Jun 2017 03:36:17 GMT</pubDate></item><item><title><![CDATA[Reply to Closure on Sun, 11 Jun 2017 03:04:53 GMT]]></title><description><![CDATA[<p dir="auto">might as well email this to your builder with a 'friendly' message.</p>
<p dir="auto">glad you got an answer.</p>
]]></description><link>https://wibimmers.com/post/80541</link><guid isPermaLink="true">https://wibimmers.com/post/80541</guid><dc:creator><![CDATA[straight6pwr]]></dc:creator><pubDate>Sun, 11 Jun 2017 03:04:53 GMT</pubDate></item><item><title><![CDATA[Reply to Closure on Sun, 11 Jun 2017 01:43:00 GMT]]></title><description><![CDATA[<p dir="auto">As much as it sucks at least this chapter can be closed now as far as your build goes.</p>
]]></description><link>https://wibimmers.com/post/80537</link><guid isPermaLink="true">https://wibimmers.com/post/80537</guid><dc:creator><![CDATA[YoungCR]]></dc:creator><pubDate>Sun, 11 Jun 2017 01:43:00 GMT</pubDate></item><item><title><![CDATA[Reply to Closure on Sat, 10 Jun 2017 23:32:46 GMT]]></title><description><![CDATA[<p dir="auto">A little bit beyond the scope of some engine rebuild in a bottle <img src="/assets/uploads/files/emoticons_default_tongue.png" alt=":P" class=" img-fluid img-markdown" width="20" height="20" /></p>
<p dir="auto">But thats what a piston can look like and still hold 70 and 90 psi</p>
]]></description><link>https://wibimmers.com/post/80534</link><guid isPermaLink="true">https://wibimmers.com/post/80534</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Sat, 10 Jun 2017 23:32:46 GMT</pubDate></item><item><title><![CDATA[Reply to Closure on Sat, 10 Jun 2017 23:12:15 GMT]]></title><description><![CDATA[<p dir="auto">Glad you solved the mystery!</p>
]]></description><link>https://wibimmers.com/post/80533</link><guid isPermaLink="true">https://wibimmers.com/post/80533</guid><dc:creator><![CDATA[Boris3]]></dc:creator><pubDate>Sat, 10 Jun 2017 23:12:15 GMT</pubDate></item><item><title><![CDATA[Reply to Closure on Sat, 10 Jun 2017 22:32:27 GMT]]></title><description><![CDATA[<p dir="auto">Sucks man, I know the feeling. <br />
I didn't properly gap my first rings in the NV and I know that's what lead to it's demise. <br />
Live and learn!</p>
]]></description><link>https://wibimmers.com/post/80531</link><guid isPermaLink="true">https://wibimmers.com/post/80531</guid><dc:creator><![CDATA[GunMetalGrey]]></dc:creator><pubDate>Sat, 10 Jun 2017 22:32:27 GMT</pubDate></item><item><title><![CDATA[Reply to Closure on Sat, 10 Jun 2017 20:28:02 GMT]]></title><description><![CDATA[<p dir="auto">Should have done it yourself. Bummer.</p>
]]></description><link>https://wibimmers.com/post/80528</link><guid isPermaLink="true">https://wibimmers.com/post/80528</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Sat, 10 Jun 2017 20:28:02 GMT</pubDate></item><item><title><![CDATA[Reply to Closure on Sat, 10 Jun 2017 19:19:26 GMT]]></title><description><![CDATA[<p dir="auto"><img src="https://uploads.tapatalk-cdn.com/20170610/09cbe6c2749cb5aa9ef5d5bbda2d3b37.jpg" alt="09cbe6c2749cb5aa9ef5d5bbda2d3b37.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://wibimmers.com/post/80525</link><guid isPermaLink="true">https://wibimmers.com/post/80525</guid><dc:creator><![CDATA[KaiserRolls]]></dc:creator><pubDate>Sat, 10 Jun 2017 19:19:26 GMT</pubDate></item></channel></rss>
