<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[E30 Z3 antenna conversion, grommet issues]]></title><description><![CDATA[<p dir="auto">Has anyone done the Z3 fixed antenna conversion on their e30?  Reason I ask is that the Z3 grommet (#65218389698) is too small/loose on my 318is to the point that i can easily push the entire thing through the hole in the body. The R3v threads on this always talk about the grommet being a tight fit and mine is anything but. Slathered around it with black RTV for now to try and get a watertight seal but wondering if there is a different grommet I should be using. Posted the question on R3v but figured maybe someone here has insight?</p>
]]></description><link>https://wibimmers.com/topic/4871/e30-z3-antenna-conversion-grommet-issues</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 06:27:32 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/4871.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 02 Jun 2017 22:47:59 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to E30 Z3 antenna conversion, grommet issues on Tue, 06 Jun 2017 19:37:06 GMT]]></title><description><![CDATA[<p dir="auto">Yeow. Thanks for this. Just did a quick search and the issue with constant draw seems to be the red power wire. Luckily I used the white.</p>
<p dir="auto"><a href="http://www.r3vlimited.com/board/showthread.php?t=342230" rel="nofollow ugc">http://www.r3vlimited.com/board/showthread.php?t=342230</a></p>
]]></description><link>https://wibimmers.com/post/80385</link><guid isPermaLink="true">https://wibimmers.com/post/80385</guid><dc:creator><![CDATA[Boris3]]></dc:creator><pubDate>Tue, 06 Jun 2017 19:37:06 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Z3 antenna conversion, grommet issues on Tue, 06 Jun 2017 16:53:46 GMT]]></title><description><![CDATA[<p dir="auto">I did this on the e28 and although I can't help with the grommet as it was a long time ago. I did kill a bunch of batteries in the car as the Z3 part that hooks to power draws all the time. Just a heads up.</p>
]]></description><link>https://wibimmers.com/post/80382</link><guid isPermaLink="true">https://wibimmers.com/post/80382</guid><dc:creator><![CDATA[merl]]></dc:creator><pubDate>Tue, 06 Jun 2017 16:53:46 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Z3 antenna conversion, grommet issues on Sat, 03 Jun 2017 02:50:54 GMT]]></title><description><![CDATA[<p dir="auto">4 different types... lovely. I obviously got the wrong one. Thanks!</p>
]]></description><link>https://wibimmers.com/post/80301</link><guid isPermaLink="true">https://wibimmers.com/post/80301</guid><dc:creator><![CDATA[Boris3]]></dc:creator><pubDate>Sat, 03 Jun 2017 02:50:54 GMT</pubDate></item><item><title><![CDATA[Reply to E30 Z3 antenna conversion, grommet issues on Sat, 03 Jun 2017 02:17:48 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">The next thing you will need is a grommet to hold the base in place. When i called the dealer and asked for the grommet for a z3, they told me there were 4 different types. So i asked about the grommet for the 318ti and they had that one so i used it. It works perfectly and i don't know the difference between it and the ones from the z3. </p>
<p dir="auto">318ti part #65218362369</p>
<p dir="auto">maybe this answers your question?</p>
]]></description><link>https://wibimmers.com/post/80300</link><guid isPermaLink="true">https://wibimmers.com/post/80300</guid><dc:creator><![CDATA[straight6pwr]]></dc:creator><pubDate>Sat, 03 Jun 2017 02:17:48 GMT</pubDate></item></channel></rss>
