  3. General Technical
  4. M52 or S52 in an E30
47 Posts 15 Posters 0 Views 1 Watching
    "M3 engine" in the title and yet STILL no engine bay pics. People confuse the shit out of me
      Thats a nice find, Earl
      Ive made offers on 2 cheap M3s but the sellers are holding them for other buyers.
      My friend in high school was told his E30 325is had "an M engine" when he bought it, hopefully this seller isnt also that mental
        a picture of an ///M Power beauty cover still doesn't mean it is 100% s5x 😄
          True. Doesn't change the fact every sale ad should include an engine pic. Especially if you mention it in the title.
            Also true=)
              I have never driven a swapped car so I can't comment on that part of it, but I think there is value in "doing it once" and getting the S52 right off the bat as they are only going to get more expensive. No matter what you do with the M52 it will always be a little bit short of the S52 (unless you do an M54 rotating assembly), so if your goal is maximizing performance from an NA 24v, might as well get the S52 now versus wanting one later. If you can find a wrecked M3 for a reasonable price and have the time/space to take it apart, you can keep the S52/zf combo, part out the rest and end up with a decent deal on a motor/trans.
                I was honestly expecting more M52 votes. Extremely valid point about doing it right ONCE, which actually goes both ways. I could do an M52 swap right by refreshing everything and be able to get it together and driving this summer. To do the same for an S52 I may have to save my pennies and shoot for completion next year.
                  buy the motor, stuff it in, than worry about fixing stuff/refreshing later. the point is to drive these cars, right? or am i doing it wrong?
                  you won't have done any extra work this way. youll just have the pull the motor one time in the future for your refresh.
                    The time aspect is what you have to think about if you are just gonna throw an engine in and worry about it later. You may not have the time to work on it later, but have the time to do it correctly right now and get it over with. That's just my thought.
                      Clearly you don't understand the WIBimmers crowd. Most members actually prefer a non-running BMW that is constantly being worked on.
                      • retoropakR
                        retoropakR
                        retoropak
                        Stroke m52 to 3.0 with the m54 rotating assembly. That way you can refresh the m52 with new bearings and gaskets and still be cheaper than s52.
                        It just happened that i have m52 i that don't need[emoji39]
                        Or m50nv stroked to 3.0 with m54 bits and run crazy cam and itbs. Oh i just realized that i have n50nv too that i might get rid off [emoji848][emoji6]
                          Stock E36 328i (M52) baseline vs. same car with M50 manifold, S52 cams, tune, air filter, intake elbow, asc delete, stock exhaust
                          Add headers and exhaust for additional gains.
                          The hp/$ quotient is strong
                            Oh man...you have me thinking bad thoughts now
                            That's over a grand for 40hp though=(
                              It is convenient that the heads are no different between m5x and s5x.  So by swapping cams you have the full thing rather than still being limited by smaller ports or other differences.
                              Just an FYI early (OBD1) heads have different cam trays and lifters that don't fit the late cams that have the extra balancing material between the lobes.  The profiles are the same between OBD1 and OBD2 but the OBD2 cams are thicker.  Just a heads up, it looks like you aren't considering an M50 anyway but just in case.
                                Yep, M52 or bust. They are newer than an M50, more powerful than an M50, and basically the same price. $1000 for 40 whp is easy to deal with when you are already doing an OBD1 build and have to buy the tune and manifold anyways.
                                The Supersprint replica headers I bought were $87 shipped, new. Tune was $200, manifold was $75, cams were $400
                                Just need to pick up the M52 now
                                  Wow, the prices on those sure went up!
                                    I think the cheapest I have ever found them was $250 but yes, the ///MPower tax is becoming an epidemic. Now i just have to keep from breaking them [emoji58]
                                      It's a 2 person job to remove/install them.  One to hold the cam with a wrench so it doesn't turn and another to tighten the cap where the pressure is.  Then you can put all of the other caps on before releasing it from turning, assuming you don't have the fancy cam tool.  I have done it with no special tools one time and would try it again but be careful.  Or maybe I am way more careful than I need to be.
                                        I have A fancy cam tool
                                          The blocks for locking the squares?  Or the cam installation tool?
