  4. Alpine White Zender Kit E24 633CSI
276 Posts 17 Posters 0 Views 1 Watching
    I thought it looked pretty good when I saw it, looking forward to the final result though. I will have to pick your brain when it comes time to making mine look better
    Good from a far, far from good. I'm not really a pro, but I enjoy learning. White is the easiest color to polish so im being pretty care free minus the fact I know the paint is thin. 😕
      Most of my cars have always been black. Paint correcting black SUCKS, and it's never clean anyways.
      After buying a white and silver car, I was amazed and how easy it is to detail them.
      Nice work so far! This stuff is tedious no matter which way you go about it.
        I agree, black cars are the worst, but they look so good when freshly polished.
        Thanks!
          Oven cleaner works amazingly well to remove painted on pinstripes FYI
            I will have to try that, it seems like you are not alone with that suggestion.
            "oven cleaner works well for this. If you use the spray type spray some into the cap and brush it on with a small paint brush. After a minute wipe it off with a damp rag and wash with soap and water. Oven cleaner will remove the striping paint but not injure the paint underneath as long as you don't leave it on too long. If you are trying to remove a red pigmented color on white or other light color be warned that 1-Shot will likely have stained the base paint.It is also dangerous to use this method on alklyd enamel;single stage paint or nitrocellulose lacquer. Urethanes don't seem to be affected very much but always try an out of the way spot to make sure it doesn't soften the paint"
            -The H.A.M.B.
            Sweet, exactly why I have to re-stripe the car.
              Still slowly polishing this into something respectable. Its a slow process as its not one of the more exciting things to do. I have most of the trim and side skirts off and have scrubbed and cleaned the seats and carpet. I haven't taken any pictures to share, but I will. I need to get it back on the lift and install all new belts, check the timing belt, and install the new shifter bushings.
                *timing chain
                  *timing chain
                  Further proving that I have not checked into it. LOL thanks Chris.
                  On another note, I allowed Earl to bring his car to my shop in order to help him make some progress. With that we were talking about this car and that I should add an additional decorative stripe to the car to help cover the aftermath of the pinstripe and add some "interest" to the car. This morning I made this quick Zender graphic based on the optional graphics available for the E21. I think the word Zender should be smaller, but its a good start.
                    *timing chain
                    “Further proving that I have not checked into it. LOL thanks Chris.”
                    [emoji16]
                    I do like the Zender stripe but make it REALLY 80’s with a yellow orange red gradient
                    (Searching for example)
                    Here we go
                      I think that would look great!! Especially if it were rolling on some super 80's wheels like centra type 7's or something like that, you aren't keeping the RS's right?
                        Yesss. I like that. I think I am going to go up and over the rear wing too. similar to this:
                        Image result for E12 m525iImage result for vintage livery race car 959
                        Im not sure about the RS's. Centras would be super cool but I think I will do something basic if I don't stick to the RS's. Like Style 5's or style 32's
                        01.jpgImage result for style 32's white e24
                          So I found out that if you remove 30 year old tint, you probably get cancer if you dont wear a respirator. I woke up with a sore throat after spending an hour inside a confined E24 with a steam cleaner and toxic fumes from old window tint adhesive.
                          Luckily, all the old purple tint came off in solid chunks. Unluckily, there is still large amounts of adhesive on the windows and the smell is still present, meaning I will have to return to finish the job.
                           Before:
                          During:
                          After:   *sorry that its hard to notice*
                            You have all the fun tools!
                              I just bought the steam cleaner to do the job. $50 new @ dealer cost. Apparently it can purify the water so you dont need to get distilled water like most steam cleaners. (I used distilled anyways not knowing this till I read the directions)  Blew my mind that it only takes 15seconds to heat the water and make steam.
                                That job is the worst!! If you still have adhesive all over the windows, ammonia worked super well getting mine cleaned up
                                  I have "tint adhesive remover" but last time I used that it was still a huge pain in the @#$. I will try ammonia.
                                    Nice! I didn't want to make a comment about the tint before, glad you removed it. I tried doing this on my old E36 and failed miserably.
                                      I have removed tint on a few cars. THIS car was the absolutely worst one I have dealt with. The worst part is I got sick and felt like I was going to die and haven't finished. I actually fear finishing the job now. I did open the windows to let the car fumigate and added an air neutralizer, so hopefully that helps.
                                        Put this on the lift last night. I got new V-belts on all the accessories, the tint adhesive off of two of the 5 windows, and started on the shift bushings. Slow progress is better than no progress!
                                        I tried to take better pictures with the tint removed but the glare and lighting was so bad I gave up. I will post more pictures soon!
                                          Picture fail, shifter success.
                                          I machined some new shifter bushings out of delrin and installed them. I swear I remember taking pictures before and after and how nice my new bushings were before I installed them. Now looking through my pictures they are no where to be found. All I have is a picture of the metal sleeves from the ones that were in the car.(that's all that was left) I got it all back together and it feels AMAZING now. Before it was so vague it felt fragile to shift in every gear.
