<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[AC blower problem]]></title><description><![CDATA[<p dir="auto">This is my first time posting. I have a 2000 740i that has several problems. It is actual my wife's car and she loves it. The A/C motor is growling and shuts off intermittently. I have preview the post as to how to remove and test the motor, but i would like to find out why the A/C system come off and on. Could it be that the fan motor is so bad that it is getting stuck and then restarting?</p>
<p dir="auto">I would appreciate any help as taking the dash off is no easy job and I would like to do it right the first time. I replaced the evaporator coil a few years back and had to take out almost the entire dash to get to it. </p>
<p dir="auto">.</p>
]]></description><link>https://wibimmers.com/topic/4752/ac-blower-problem</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 04:49:57 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/4752.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 04 Mar 2017 22:47:39 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to AC blower problem on Mon, 06 Mar 2017 23:08:26 GMT]]></title><description><![CDATA[<p dir="auto">Nice job on the DIY, Jeff. I had forgotten about this</p>
]]></description><link>https://wibimmers.com/post/77207</link><guid isPermaLink="true">https://wibimmers.com/post/77207</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Mon, 06 Mar 2017 23:08:26 GMT</pubDate></item><item><title><![CDATA[Reply to AC blower problem on Mon, 06 Mar 2017 20:43:23 GMT]]></title><description><![CDATA[<p dir="auto">With the E38 the top of the dash must come out to get to the blower motor.<br />
half the job of the heater core. Jeff did a write-up on here awhile ago.</p>
<p dir="auto">Not a hard job just tedious and time consuming. Be patient and take your time.<br />
a 2nd pair of hand will make the job much more painless.<br />
Expect to break a few clips and plan for it.</p>
<p dir="auto">replaced this with my son in about 3 hours.</p>
<p dir="auto">RobZR</p>
]]></description><link>https://wibimmers.com/post/77205</link><guid isPermaLink="true">https://wibimmers.com/post/77205</guid><dc:creator><![CDATA[RobZR]]></dc:creator><pubDate>Mon, 06 Mar 2017 20:43:23 GMT</pubDate></item><item><title><![CDATA[Reply to AC blower problem on Mon, 06 Mar 2017 12:24:11 GMT]]></title><description><![CDATA[<p dir="auto">I assume you are talking about the hvac blower?  Does it run and change speeds when you adjust it?  </p>
<p dir="auto">I am not sure how similar it is but I have replaced a blower motor on an e32, it would run and could hear it changing speed as you adjust the speed selector but was always too slow and sounded bad.  I can look for some pictures if you would like.  I replaced it from under the hood by moving the coolant reservoir and the covers.  It is tight but better than removing the entire dash to access the hvac box.</p>
]]></description><link>https://wibimmers.com/post/77181</link><guid isPermaLink="true">https://wibimmers.com/post/77181</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Mon, 06 Mar 2017 12:24:11 GMT</pubDate></item><item><title><![CDATA[Reply to AC blower problem on Sun, 05 Mar 2017 02:18:08 GMT]]></title><description><![CDATA[<p dir="auto">Welcome Bob!</p>
<p dir="auto">A quick search makes it appear to be a common issue on the E38 with a new blower motor resistor being the fix</p>
<p dir="auto"><a href="http://www.bimmerboard.com/forums/posts/31138" rel="nofollow ugc">http://www.bimmerboard.com/forums/posts/31138</a></p>
<p dir="auto">Im sure you are aware of <a href="http://E38.org" rel="nofollow ugc">E38.org</a> but if not it appears to be an immense vault of great info (where I found the link above)</p>
<p dir="auto"><a href="http://www.e38.org/" rel="nofollow ugc">http://www.e38.org/</a></p>
<p dir="auto">Probably a worthless post on my part since it sounds like you know what you are dealing with, but just attempting to be helpful</p>
]]></description><link>https://wibimmers.com/post/77157</link><guid isPermaLink="true">https://wibimmers.com/post/77157</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Sun, 05 Mar 2017 02:18:08 GMT</pubDate></item></channel></rss>
