  4. new to me, 98 M3
new to me, 98 M3
173 Posts 18 Posters 3.3k Views 1 Watching
  • C
    C
    cpandrewschmidt
    Hi all, hope everyone is doing well.  Not a ton to report on the M3.  Got the new trunk on.  Looks much better.  Not 100% perfect unless you're very close to it and know what to look for. I like it.  Small m5 spoiler coming today.  😄
    Back to the vanos stuff.  Did it a 3rd time, confirmed chain movement was correct with compressed air.  All seemed fine.  Drove it for a couple weeks with no CEL.  Had at least 30-40 different start and stops over the time period, so DME had plenty of time to trip early on but didn't.  Then it came on again this week.  Ugh, same thing, mixture deviation bank 1, misfire cylinder 5.
    So, I did an experiment.  I changed coil pack (CP) to cylinder 2 and spark plug (SP) to cylinder 3.  Put known working CP and SP from cylinder 2 onto cylinder 5.
    Now I get misfire on cylinder 5 and 3 (where the spark plug went) but cylinder 2 is good with the CP off 5.  So, I know CP's are fine. (again all CP and SPs are new)
    Something appears to be happening on cylinder 5 that messes up the spark plugs.  I'm going to try to clear codes and reset DME adaptations, but leave everything where it is.  I'll see if they come back as 3 and 5 misfires again.  If so I'll move 5 spark plug to another location to see if that follows.
    Maybe something with the wiring harness or could be computer related?  Ugh.
    Would love to get this sorted out.  I don't have anyway to live monitor stuff while the engine is running to see if it is truly misfiring or look at other parameters.  I think that's the next step.
      what does the cylinder 5 spark plug look like compared to the others?
      I would be interested to see if by chance the o2 sensor connectors for bank 1 and 2 could have been mistakenly switched. I am not sure if  wiring lengths and locations would allow that to be possible or not.
      • C
        C
        cpandrewschmidt
        they all look same to me.  I'll take pictures next time I have it out to show you.  I'll be gone this weekend putting the vert into storage so won't have time to mess with it till Sunday.
        • C
          C
          cpandrewschmidt
          Hi all, quick question.  I replaced my RTABs this weekend.  After I got done I discovered some threads talking about preloading them.  I understand the concept and why to do it.  Now I just have to figure out the proper way with out the BMW tool.  Only it says use a straight edge and measure 8mm above the center of your hub.  My questions are:
          1.  my car is lowered.  Should i error slightly more than 8mm?
          2.  do you measure with the car fully jacked up?  won't different cars with different suspensions sag more or less than others, throwing off that 8mm measurement?
          3.  do you measure for below or above the center of the hub?
          I attached some pictures for reference of what I was doing.  I was going to measure above center of hub, but still unsure of question #2.  I think i tighten it too far off 8mm trying to account for my drop in suspension.  I was getting a bad shake this AM from the one side i messed with.  Will try to correct tonight.
          Thanks for the help for anyone who's done this.
            You replaced them with stock ones?  Just checking because poly ones rotate so it doesn't matter.
            • C
              C
              cpandrewschmidt
              yes, stock w/ limiters.  i got some tips on bimmerforums:
              "Don't fully tighten the bushings bolt.
              Install RTAB bracket to car, install wheel, lower car to ground.
              Drive the car back/forward 10ft or so so the suspension can settle.
              With a marker (pref a paint marker) reach into the RTAB bracket area and draw a line across the bracket relative to the trailing arm.
              Put the car back in the air, remove RTAB bracket and you should now be able to line the RTAB bracket to the line you just drew. Now tighten and torque the bushing bolt. Tada!"
                Another option that I would guess would work, is to determine just how far you are lowered from stock in the rear. That number is easy to find if you have lowering springs as it should be a published value, less so if you have adjustable suspension. If you've got coilovers, there are published values from BMW for stock ride height from the ground to the wheel arch (or something like that) that you can compare to. If I'm thinking correctly, measure down from the center of the hub by the amount you are lower from stock ,and then up 8mm from that point to set the preload relative to your ride height.
                As far as the vibration, unless your alignment is really out of whack, it is most likely that the new RTAB is 'uncovering' and issue elsewhere by transmitting vibrations that were previously being absorbed by the worn bushing.
                • C
                  C
                  cpandrewschmidt
                  note to my idiot self.  it usually helps with vibrations to actually tighten lug nuts.............
                  rtabs all better now.
                    At least you caught it before they came all the way off!!
                    • stealthbimmerS
                      stealthbimmerS
                      stealthbimmer
                      Or,
                      1997 328ic
                      • C
                        C
                        cpandrewschmidt
                        Morning all, time to pick your brains again.  So, I've never been able to figure out my CEL issue and I'm determined.  If you'd read back you'd notice car seems to run fine but I'm running rich.  Quick summary:  I get mixture deviation codes on banks 1 and 2 with negative fuel trims.  I'll clear codes and monitor the live data.  LTFT starts at zero then works its way to the -8.6% threshold fairly quickly where DME overrides and trips the CEL.  I've noticed bank 1 gets there about -1% more quickly than bank 2, but then they both eventually get to the -8.6%  I understand this to mean I don't have a vacuum leak as that would cause lean fuel trims (positive)  Plus I've tested numerous times with smoke for any intake leaks.
                        Things I've done within the last 3-8,000 miles: valve cover gasket, vanos seals, fixed intake boot leak, fuel filter, new FPR, all new O2 sensors, sent out injectors for testing (tested good, no leaks), spark plugs, boots, coil packs.  Unplug MAF and confirm idle change, so appears to be working.  Cam shaft position sensor.  The latest was the cam shaft position sensor.  Old one was definitely compromised. It had frayed exposed wires.  Light stayed off for 2 weeks and a lot of driving so I thought I found it.  Then, came back.  Same codes.
                        This brings me to a couple ideas.
                        1.  Possible exhaust leak - I've read if the leak is on the exhaust side before the o2 sensors that can cause rich conditions.  I'll be confirming tomorrow if there's a leak at the manifold or elsewhere.  Assuming that's ok onto my next ideas.
                        2.  When I got the car it was needing maintenance, valve cover leaked, intake, etc.  My thought is perhaps the tune was done with these leaks causing causing misleading lean conditions.  Now that I've patched them up, cleaned up fuel filter, fpr, etc it's just flowing that much better and running rich.  My question is does anyone here know if you can tune injectors to not run as much fuel?  Anyone here know how to for some $?
                        3.  DME compromised?  There's a guy on bimmerforums that'll re-flash the tune onto a new DME but that's $380 and i don't want to spend that if it's fine.  Car doesn't experience any other symptoms so I assume it's OK?
                        4.  Timing issue from vanos job.  I've done it now 3 times checking my work and using the compressed air to confirm movement.  Seems OK.  But with bank 1 showing signs first maybe intake CAM is still off?  Are there computers out there that can sense that?  I did job using blocks and all lines up.
                        5.  Coolant temp sensor?
                        I'm basically out of mechanical ideas to fix / test.  Only thing I haven't changed is the CCV.  I don't think that would cause a rich condition.  I've cleaned out ICV.  I was OK replacing all the other parts because they were maintenance items anyway, but now I'm out of things to fix.
                        Looking forward to hearing all your thoughts and wisdom!  Willing to pay money for help.  I just don't want to take to the deal because they'll do all the same things I've already done, unless their programs are more capable than what I have.
                        Thanks, Andrew
                        PS - detailed and put summer tires on, so you all can blame me if we get 6" of snow Friday night.
                          refresh my memory:
                          Has it ever run 100% correctly (no CEL, not too rich) since you have owned it?
                          • C
                            C
                            cpandrewschmidt
                            Never not had a CEL. but i didn't know enough back then to look at fuel trim ratios.  was focused on vacuum leak stuff as that is what everyone always talks about.  Since I bought from out of state I assume previous owner cleared codes before selling.  1st thing I noticed were 02 sensors were actually disintegrated post CAT.  did those 1st but still didn't fix CEL.  Then did valve cover as that was leaking oil.  Then the rest of the list above as other preventative maintenance along the way.  Still haven't pin pointed it.  Ordered up a coolant temp sensor for the block as they are only $25 bucks.  Figured why not.  Will try to put that in tomorrow too, but supercharger might make that a difficult job.
                            • C
                              C
                              cpandrewschmidt
                              tried to check for exhaust leaks around manifold / before 02 sensors.  Nothing that I could find.  Couldn't get Coolant Temp sensor installed without removing supercharger.  Highly doubt it's that anyway.
                              So, really thinking this thing it just putting too much fuel into it since I can't think of anything else to check.  Everything else is solid, no leaks etc.  Guess that brings me back to what you all might know about tuning injectors?  I'm not 100% sure what ones i have.  They have a blue O ring on them.  Guess I'll have to pull one to confirm.
                              If there's anyone that can help with computer stuff that's where my knowledge stops.  Willing to pay for help!
                              Andrew
                                the only two things I can think of that would be worth trying at this point are:
                                get the brand/part number of the injectors so you can verify the flow rate. Then take a look at the chip in the ECU and see if it has any info that may help you match it to the injectors (may have a GIAC 24# label or something).
                                the next item is, have you tried the chip in another ecu in the car to rule out a wonky ecu?
                                • C
                                  C
                                  cpandrewschmidt
                                  Haven't swapped DME at all.  Don't have an extra, or a car to swap into.  Are there other ways to test DME?  When you say ECU, it's the same as the DME, right?
                                  For Injectors all I know about them if from when I sent them in.  He said "They are "weber style"  After cleaning The dynamic flow test ( 12 ms pulse width / 2400 rpm / 25 seconds ) had flow rates of 100 up to 104 cc.s across the board. The injector flow balance is now very close to 3.8 %.  He said they all performed flawless in all the tests and All of the injectors held pressures over 80 psi without leaking a drop, and their spray patterns were perfect."
                                  I'll pull one soon to get the model # off them.
                                  On my DME.  I pulled it a few weeks ago to look at it.  I've read about corrosion issues.  Sure enough, it was pretty corroded.  I thought that would be it.  Attached are before and after cleaning pictures, along with the "chip" side, which was clean.  I cleaned it real well with electrical cleaner.  No difference in how car performed and it did clean up well.  I would guess it was still OK, nothing looked fried on the chip side of things.  No visible burn through marks on the board.  Also, all live data systems like o2, stft, ltft, MAF etc all get readings when plugging in my code reader.  So, they appear to be reading fine.
                                    Yeah, DME/ECU, same thing depending on how german im feeling at the moment
                                    My mistake by saying " chip"  its OBD2 which means it needs a reflash to install the supercharger tune on it. Im not too worried about the ECU being bad. It would just be great to know for sure what size injectors are on there and what size the software is for as kind of a "back to square one" type of check. You can diagnose all you want but if the tuning is wrong for the injectors then you will never luck diagnosing it and throwing parts at it.
                                    @m42b32   can your newfound flashing skills come to play here? I dont remember seeing anything for injector size in Tuner Pro, but is there any way to verify injector size on the tune with what you have?
                                      @Daggerty you tuned your e36 with the stock DME right? Were you able to find definition files for your car or did you work around it? I have yet to find anything useful for ms41.2 (s52).
                                        Daggerty
                                        Yes the newest download is on romraider which for whatever reason it won't let me log on and the admin won't respond to my emails. I have some of the definitions.
                                        I don't know if I would be able to get anything of of the DME because big name tuning companies lock them or whatever. So Joe Shmoe, no pun intended, can't steal their tune.
                                          Daggerty
                                          One thought, knock sensor will pull timing which will change how the mixture burns changing afr. If you can get freeze frame data that would help out a lot.
