WIbimmers Off Topic Thread
Still has it.
Has an m20
I wanna have a touring so bad. SOOOO bad. Yes.
You fo realz chad?
Well, this is how my qualifications went:
30/31
** keep in mind, I was just aiming to pass, not get super tight groupings etc **
The miss to the left was when I rushed a 7 yard Harries Technique drill (flashlight in left hand, wrapped underneath right hand holding weapon) where we had to fire two rounds, reload, and fire two more rounds in 10 seconds. Turns out 10 seconds is plenty of time
The gut shot was my first 45ft shot standing, and the left arm pit was from the 45ft prone position.
Not too bad, but it could def use some work lol
The company I work for is run by fucking idiots. Fact.
They moved me to the patrol division "because we're shorthanded, plus, it'll get you more hours which you've been asking for."
Well, if my next two weeks on the schedule are any indication, my future here will be damn short. I dropped from 36 hours a week (with a 10 minute drive to work), to 31 hours a week + a new 30 minute drive to work.
There's one small spot of surface rust on the rear quarter panel above the tire. Should be a relatively easy touch up job. Other than that, it looks pretty dang clean for the age/mileage!
Door panels are a little loose, seats have a lot of scratches on them, no tears though.
^Those door panels are normal. They have standoffs that snap off and you can't order them. There is a guy possibly making them on 318ti.org
That bubble on the wheel well is an e36 thing and isn't as bad on Ti's. Just sand it and get some alpine touchup=D Watch right under the hatch too where it meets the body. That is the major trouble spots on Ti's. The seat scratches should be able to be fixed with leatherique. How is the carpet? If you need someone to clean it I know how to get everything out and clean it good since I did that already. Also, if she has any other issues I can help since im the Ti guy=D watch the rear springs and see if a coil is snapped off. That's very common aswell as destroyed rear subframe bushings.
Ryan... said:
My gf just agreed to buy a 95 318ti, alpine white, 5 speed, with M-technic package for $3k
someone said:
They drive perfectly fine with snapped springs. It just happens. I am changing out my rear springs soon and can always just give them to you when I do;)
Ok that would make sense, it drives perfectly fine, no bouncing/swaying over bumps or at hwy speeds.
wasnt m3 said:
yes sir, tis the car
My m42 goes vroom, those m42's go .... Nowhere
