  4. Lifted E30 V2
Lifted E30 V2
670 Posts 25 Posters 1 Views 1 Watching
    Head gasket and head bolts have been received.
    Waiting on the head to come back from the machine shop and then it's reassembly time.
    I'm still hoping to ice race this weekend if the event isn't cancelled.
      How much for the inspection and machine work?
        $60
          That sounds like a great deal=) Wasn't the place you used for your exhaust manifold was it?😆
            Hahaha, nope! I won't set foot in that place again.
            It's a local guy that has always done my motor work, and does it at a good cost and his work is always great.
              haha just foolin=) Did they end up getting you that new manifold?
                Shiny head!
                I got it all assembled and it still overheated, so either I'm bad at bleeding m20 cooling systems or something is wonky.
                I took the thermostat out and it still started creeping past 1/2 at idle, so I replaced the clutch fan. Shall test all of that tonight.
                This car resulted in this picture, it makes dealing with constant issues easier.
                  PBR? Did Andy buy something from you?
                    lol, nope! That's Mikes beer of choice.
                      pbr is pretty good for cheap light beer. better than lite or bud or other terrible domestic light beers.
                      on topic - i'm sure you know how to bleed one of these cars, but what process are you going through exactly?
                      i just bled my e30 before winter and it took probably 4 cycles of: start car - warms up - massage radiator hoses -  starts to creep past 1/2 - shut it off - let it cool - open the cap - more coolant - repeat.
                        FWIW, my cluster reads more than half. Shooting the t stat housing always comes back around 195F +\- 5
                        Which is close enough for me, currently using a 92C t stat so it's right about where it should be. I'm sure the ground nut and 30 year old electronics arent being helpful.
                        Also why I'm installing an actual temp gauge this winter...
                          I actually have little knowledge in terms of bleeding m20 systems, as I am more familiar with e46 and 318 style bleeding.
                          I know that it's not just the temp gauge as the radiator wasn't getting hot previously.
                          I found a few articles on it and will give it another couple goes tonight, after putting the thermostat back in. I may add a hole to that for bleeding ease.
                            Let's get @suspenceful to chime in about how bud light tastes!
                              I held back my comments. But now that you've asked for it... I'd snort Bud Light before drinking PBR through my mouth.
                              Bud Light is the best light domestic beer by far.
                              PS: I thought you didn't drink when you were angry? 👀
                                Well who wouldn't be willing to snort water?;)
                                It amuses me that you actually think I got angry about the whole situation!
                                  Technically, PBR isn't a "light" beer, although they make that too...
                                  I only drink it because I'm a hipster.
                                      Tried a couple of things last night and got it to not overheat quickly like it had before, but it still crept over half.
                                      When I stopped I noticed that the hoses seemed to have a bit more pressure than what I would assume to be normal, and the radiator still wasn't getting full coolant flow.
                                      Going to re-bleed and try again.
                                        Does the car still have heat or did you loop it? Could be a clogged up heater core?
                                          Car has heat, heat works quite well.
