  4. Lifted E30 V2
Lifted E30 V2
670 Posts 25 Posters 1 Views 1 Watching
    Seriously?
    WHAT
    THE
    FUCK.
    I would be beyond frustrated.
      Yeah that’s infuriating. If they won’t back their work then see if Badger Diesel is willing to work on it. They list VW idi injection pump rebuilds on their site for $400. I have over 10k miles on a rebuilt pump from them with no issues.
        Alright, it seems like there is slight confusion on what pumps are having problems, which is understandable lol.
        The leaking pump is the pump that came from the e28 I recently bought, I knew it was leaking fuel, but thought that seal was fine. It wasn't.
        I ordered some standard rotary seals instead of the fancy $20+ bmw part number, because they're the same thing. I likely will have one tonight to the tune of $3.
        I dropped off the pump that I had bought on ebay "rebuilt" (20 years ago) at the shop yesterday, the ones that bench tested it and said it was fine, but didn't work when I tried it. He is going to open it up and see if anything is sticking and test it again. I made it clear that I've already given them $600 to make sure it worked and it doesn't, so I'm not interested in paying to have this one corrected.
        thanks for the badger diesel suggestion!
          I grabbed one of the seals yesterday from a local supplier, but when I got to the shop I found that the old seal was a double lip, and I had gotten a single lip.
          The one I ordered online was a two lip seal, and that shows up tonight. Shall press that in and see if it is leaking from anywhere else, if not I shall proceed forward!
            Ohhh yes! Closer and closer!
             Image result for diesel smoke animated gif
              New seal in, no fuel pouring out.
              I am looking forward to going to the shop tonight.
              Need to hook up the oil cooler lines, add the few wires that it needs, time the motor, and then attempt the bleeding process.
              Interesting note, the E28 downpipe fits the e30 chassis quite well, so I've got the start of the new exhaust as well!
                Stacks, please.
                  Stacks, please.
                  Ain't gonna happen.
                  After much delay, it has finally become useful.
                  It bled air pretty damn quick this time!
                  This motor is clearly in much better shape, it turns over by hand smoother and doesn't run on 5 cyl until it warms up like the other motor. I think long term I will put the new pump and injectors on this motor, but I will wait till I get the other motor running with those parts.
                  I forgot that I need to fix the heater core valve so I wasn't going to fill it with coolant knowing that it was going to leak into the cabin.
                  Hooked up some of the other stuff, alternator, power steering, those kinds of things. I need to get under the car and connect the driveshaft and such, but that always takes motivation because who likes crawling under cars anymore.
                  I'm stoked to have this running and I can't wait to go roll some coal!
                  • AsparagusMikeA
                    AsparagusMikeA
                    AsparagusMike
                      Do a burnout.
                        So Efffing STOKED.
                          Awwww yeahhh!!!
                            Pulled this little guy out last night, hoping to fix my coolant leak in the cabin.
                            Drilled the heads of the rivets off an opened it up, weird little thing.
                            This part is what normally cracks and leaks, but there were no cracks to be found.
                            It's out of focus which is annoying
                            I put the two halves back together with some machine screws, after cleaning up any sealing areas.
                            I put it back in the car, and am crossing my fingers that it doesn't leak. I need to remember to plug it back in as well.
                            Motor looking like a hot mess as always!
                            I'm looking into running a water/air intercooler due to space and piping constraints, but the only downside is that they aren't cheap! I wish there was more room to pipe an intercooler inlet and outlet to the same side on these chassis!
                            Until next time!
                              T
                              O
                              P
                              M
                              O
                              U
                              N
                              T
                              Do it.
                                I came here ready to talk about not doing a top mount.
                                You did not disappoint.
                                  in the two heater valves i've opened up, it was the seal between top and bottom that had disintegrated. considering this seal is not a part you can buy separate, and it's a really strange size, i wasn't able to fix them. i figured maybe i'd buy a sheet of rubber and cut my own, but i gave in and bought a 3rd used unit instead.
                                    This is good to know, as I was wondering what to do if it continues leaking.
                                    There was a bit of buildup on the seal so I cleaned that all off, maybe that was the problem all along.
                                      Did you inspect the green o-ring on this pipe? I had a dribble coming from mine and fixed it with a new o-ring. I think they shrink over time.
                                        Daggerty
                                        You can by rubber washers for sink screens and drill them out.
                                          I had replaced all the o rings when I did the heater core, but I will be watching the o rings closely this time.
